    2. English
    3. Visualization
    4. VIS formula in Object ID SOLVED
      ap2017 last edited by ap2017
      I am using WeatherCustom widget, is there a way to convert temperature from Celsius to Fahrenheit, for example by using formula in Temperature ID. Something like
      (ObjectID *9/5)+32
      ![6b39a171-bae5-4d64-9c66-9103fb6a7a71-image.png]
      (/assets/uploads/files/1585194027712-6b39a171-bae5-4d64-9c66-9103fb6a7a71-image.png)
      Apparently, this feature works only for widgets with HTML property. It will be great to clarify it in VIS Wiki
      CrunkFX 1 Reply Last reply Reply Quote 0
      • CrunkFX
        CrunkFX Forum Testing @ap2017 last edited by CrunkFX
        @ap2017 Install the Javascript Adapter and in Userdata.0 create a new Datapoint as Number.
        The goto Javascript and create a new "Javascript".
        Insert this and Edit for your needs:
        on({id: 'accuweather.0.Current.Temperature'/* <<< This has to be your AccuWeather Temp. No matter which one*/, change: "ne"}, function (obj) {
          setState("0_userdata.0.New_Object"/*<<<This has to be your new Datapoint*/, (getState("accuweather.0.Current.Temperature"/*<<< This has to be the same AccuWeather Temp. as above*/).val * (9 / 5) + 32), true);
        then goto VIS and select the Object created in Userdata.0
        A 1 Reply Last reply Reply Quote 2
          ap2017 @CrunkFX last edited by
          @CrunkFX Thank you. Can same be done by binding ObjectID in widget? Something like:
          {objectID;*(9);/(5);+(32);} For some reason it does not work for me.
          Dutchman 1 Reply Last reply Reply Quote 0
          • Dutchman
            Dutchman Developer Most Active Administrators @ap2017 last edited by Dutchman
            @ap2017 sagte in VIS formula in Object ID:
            Yes you can just use bindings in vis for calculations.
            “ You can use this pattern in any text, like
            My calculations with {objectID1;operation1;operation2;...} are {objectID2;operation3;operation4;...}
            or color calculations:
            #{objectRed;/(100);*(255);HEX2}{objectGreen;HEX2}{objectBlue;HEX2}
            https://github.com/ioBroker/ioBroker.vis
            vis
