    4. Fehler bei start des web adapters....
    UNSOLVED Fehler bei start des web adapters....
      andyb last edited by andyb
      beim start des web adapters bekomme ich folgende Logeinträge. Vis etc lassen sich auch nicht mehr aufrufen.
      host.iob2	2020-03-30 12:05:28.699	info	Restart adapter system.adapter.web.0 because enabled
      host.iob2	2020-03-30 12:05:28.699	info	instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at Zlib.processCallback (zlib.js:557:8)
      host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at InflateRaw.afterTransform (_stream_transform.js:94:3)
      host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at onwrite (_stream_writable.js:476:7)
      host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at afterWrite (_stream_writable.js:485:3)
      host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
      host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
      host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
      host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
      web.0	2020-03-30 12:05:28.168	info	(10228) Terminated (NO_ERROR): Without reason
      web.0	2020-03-30 12:05:28.167	info	(10228) terminating
      web.0	2020-03-30 12:05:28.115	info	(10228) terminated http server on port 8082
      web.0	2020-03-30 12:05:28.113	error	(10228) TypeError: Cannot read property 'isValidUTF8' of undefined at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29 at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7 at /opt/io
      web.0	2020-03-30 12:05:28.113	error	(10228) uncaught exception: Cannot read property 'isValidUTF8' of undefined
      web.0	2020-03-30 12:05:28.071	info	(10228) ==>Connected system.user.admin from ::ffff:192.168.1.3
      web.0	2020-03-30 12:05:27.281	info	(10228) <==Disconnect system.user.admin from ::ffff:192.168.1.3 vis.0
      web.0	2020-03-30 12:05:27.237	info	(10228) ==>Connected system.user.admin from ::ffff:192.168.1.3
      web.0	2020-03-30 12:05:27.006	info	(10228) http server listening on port 8082
      web.0	2020-03-30 12:05:27.002	info	(10228) socket.io server listening on port 8082
      web.0	2020-03-30 12:05:26.627	info	(10228) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.19.0
      host.iob2	2020-03-30 12:05:24.763	info	instance system.adapter.web.0 started with pid 10228
      host.iob2	2020-03-30 12:04:54.742	info	Restart adapter system.adapter.web.0 because enabled
      host.iob2	2020-03-30 12:04:54.741	info	instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
      host.iob2	2020-03-30 12:04:54.741	error	Caught by controller[0]: at Zlib.processCallback (zlib.js:557:8)
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at InflateRaw.afterTransform (_stream_transform.js:94:3)
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at onwrite (_stream_writable.js:476:7)
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at afterWrite (_stream_writable.js:485:3)
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
      host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
      host.iob2	2020-03-30 12:04:54.739	error	Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
      web.0	2020-03-30 12:04:54.098	info	(10198) Terminated (NO_ERROR): Without reason
      web.0	2020-03-30 12:04:54.097	info	(10198) terminating
      web.0	2020-03-30 12:04:54.044	info	(10198) terminated http server on port 8082
      web.0	2020-03-30 12:04:54.042	error	(10198) TypeError: Cannot read property 'isValidUTF8' of undefined at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29 at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7 at /opt/io
      web.0	2020-03-30 12:04:54.042	error	(10198) uncaught exception: Cannot read property 'isValidUTF8' of undefined
      web.0	2020-03-30 12:04:54.000	info	(10198) ==>Connected system.user.admin from ::ffff:192.168.1.3
      web.0	2020-03-30 12:04:41.297	info	(10198) http server listening on port 8082
      web.0	2020-03-30 12:04:41.293	info	(10198) socket.io server listening on port 8082
      web.0	2020-03-30 12:04:40.924	info	(10198) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.19.0
      host.iob2	2020-03-30 12:04:38.785	info	instance system.adapter.web.0 started with pid 10198
      host.iob2	2020-03-30 12:04:38.764	info	"system.adapter.web.0" enabled
      Edit: die Fehler kommen nicht beim Start des web adapters, erst beim Aufrufen von Vis!?🤷‍♂️
      web adapter
