    4. [gelöst]ioBroker upgrade - ('Invalid version of %s. Required %s', adapter, adapters[adapter]);
      pix last edited by
      nachdem ich meinen macmini wieder flot gemacht habe, wollte ich mal aus der Konsole ein paar Updates machen.
      ./iobroker upgrade
      ````brachte allerdings eine Fehlermeldung
      MacMini-Ethernet:iobroker pix$ ./iobroker upgrade
      /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:89
      if (!semver.satisfies(that.main.objects['system.host.' + that.main.currentHost].common.installedVersion, adapters[adapter])) return _('Invalid version of %s. Required %s', adapter, adapters[adapter]);
      TypeError: Cannot read property 'objects' of undefined
      at checkDependencies (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:89:48)
      at Upgrade.upgradeAdapter (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:173:29)
      at Upgrade.upgradeAdapterHelper (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup/setupUpgrade.js:51:14)
      at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/setup.js:1156:37
      at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:458:27
      at _getRepositoryFile (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:422:23)
      at null._onTimeout (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/tools.js:403:29)
      at Timer.listOnTimeout (timers.js:92:15)
      Pix
        Js-controller 0.11.2 ?
        Falls nicht, bitte updaten.
          Heinzelmaennchen last edited by
          Hallo Bluefox,
          wie hier http://forum.iobroker.net/viewtopic.php … 507#p32422 schon beschrieben kommt bei mir ein:
          root@castor:~# cd /opt/iobroker/
          root@castor:/opt/iobroker# iobroker upgrade
          (node) warning: possible EventEmitter memory leak detected. 11 error listeners added. Use emitter.setMaxListeners() to increase limit.
          Trace
              at TLSSocket.addListener (events.js:239:js-contorller ist auf dem aktuelle17)
              at TLSSocket.Readable.on (_stream_readable.js:680:33)
              at Request. <anonymous>(/opt/iobroker/node_modules/npm-registry-client/lib/request.js:153:7)
              at emitOne (events.js:77:13)
              at Request.emit (events.js:169:7)
              at ClientRequest. <anonymous>(/opt/iobroker/node_modules/request/request.js:791:10)
              at emitOne (events.js:82:20)
              at ClientRequest.emit (events.js:169:7)
              at tickOnSocket (_http_client.js:502:7)
              at onSocketNT (_http_client.js:514:5)</anonymous></anonymous>
          js-controller ist 0.11.2
          npm -v
          2.15.8
          node -v
          v4.4.7
          Ich habe keine Ahnung was ich noch machen kann.
            pix last edited by
            @Bluefox:
            Falls nicht, bitte updaten. `
            Das war das Problem. Controller manuell erneuert (ist http://www.iobroker.net/?page_id=3074&lang=de erklärt)
            Ich dachte, der Controller wird auch mit diesem Befehl ( <size size="85">iobroker upgrade</size> ) erneuert.
            Danke, alles wieder gut. 😛
            Pix
              @Heinzelmaennchen:
              Hallo Bluefox,
              Trace
              npm -v
              2.15.8
              node -v
              v4.4.7
              Ich habe keine Ahnung was ich noch machen kann. `
              Ist schon seltsam.
              Erst probiere js-controller neu zu installieren.
              Dann versuch mal die Adapter gezielt updaten.
              "iobroker upgrade admin" z.B.
                Wenn ich das mache, kommt:
                Adapter "admin" js up to date.
                Obwohl in der Adapter Übersicht 1.4.0 steht, aber in github die Versionsnummer 1.4.1 angeboten werden sollte.
                  paul53 last edited by
                  @Bluefox:
                  "iobroker upgrade admin" `
                  @Heinzelmaennchen:
                  Obwohl in der Adapter Übersicht 1.4.0 steht, aber in github die Versionsnummer 1.4.1 angeboten werden sollte. `
                  mit "iobroker upgrade admin" wird die letzte in https://www.npmjs.com/ veröffentlichte Version (1.4.0) installiert. Die Installation von github geht anders.
