    4. DWD Adapter log: ReferenceError: lat is not defined
    UNSOLVED DWD Adapter log: ReferenceError: lat is not defined
    • wendy2702
      wendy2702 last edited by
      im Syslog meines ioBroker erscheint dieser Eintrag für den DWD Adapter:
      Apr  4 09:10:00 iobroker bash[126]: 2020-04-04 09:10:00.027  - #033[32minfo#033[39m: host.iobroker instance system.adapter.dwd.0 started with pid 26630
      Apr  4 09:10:01 iobroker bash[126]: (node:26630) UnhandledPromiseRejectionWarning: ReferenceError: lat is not defined
      Apr  4 09:10:01 iobroker bash[126]:     at adapter.getForeignObjectAsync.then.sys_conf (/opt/iobroker/node_modules/iobroker.dwd/main.js:260:114)
      Apr  4 09:10:01 iobroker bash[126]:     at process._tickCallback (internal/process/next_tick.js:68:7)
      Apr  4 09:10:01 iobroker bash[126]: (node:26630) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
      Apr  4 09:10:01 iobroker bash[126]: (node:26630) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
      Apr  4 09:10:02 iobroker bash[126]: 2020-04-04 09:10:02.628  - #033[32minfo#033[39m: host.iobroker instance system.adapter.dwd.0 terminated with code 0 (NO_ERROR)
      Gibt auch schon ein Github issue dazu https://github.com/ioBroker/ioBroker.dwd/issues/43
      Aber vielleicht kennt hier jemand das Problem und hat eine Lösung. Über die Forensuche bin ich leider nicht fündig geworden...
      agross created this issue in ioBroker/ioBroker.dwd
      closed Lots of errors regarding "lat" not being defined #43
      dwd error log reference
