    2. Русский
    3. ioBroker
    4. ioBroker драйвера
    5. Драйвер Apple HomeKit
      creo last edited by
      Не стартует адаптер, перелистал немецкую ветку но побороть ошибку не получилось:
      host-server 2016-08-20 16:38:33.667 error instance system.adapter.homekit.0 terminated with code 0 (OK)
      homekit-0 2016-08-20 16:38:33.658 info terminating
      TypeError: 2016-08-20 16:38:33.653 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:323:16)
      TypeError: 2016-08-20 16:38:33.653 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:247:12)
      TypeError: 2016-08-20 16:38:33.653 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      TypeError: 2016-08-20 16:38:33.653 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-08-20 16:38:33.653 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8)
      TypeError: 2016-08-20 16:38:33.653 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError: 2016-08-20 16:38:33.653 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      TypeError: 2016-08-20 16:38:33.653 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError: 2016-08-20 16:38:33.653 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError: 2016-08-20 16:38:33.653 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:184:29)
      TypeError: 2016-08-20 16:38:33.653 error Cannot read property 'native' of undefined
      uncaught 2016-08-20 16:38:33.651 error exception: Cannot read property 'native' of undefined
      • Alex1808
        Alex1808 last edited by
        а node какая установлена?
          Haus last edited by
          @creo:
          ! host-server 2016-08-20 16:38:33.667 error instance system.adapter.homekit.0 terminated with code 0 (OK) homekit-0 2016-08-20 16:38:33.658 info terminating TypeError: 2016-08-20 16:38:33.653 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:323:16) TypeError: 2016-08-20 16:38:33.653 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:247:12) TypeError: 2016-08-20 16:38:33.653 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20) TypeError: 2016-08-20 16:38:33.653 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-08-20 16:38:33.653 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8) TypeError: 2016-08-20 16:38:33.653 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) TypeError: 2016-08-20 16:38:33.653 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15) TypeError: 2016-08-20 16:38:33.653 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12) TypeError: 2016-08-20 16:38:33.653 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9) TypeError: 2016-08-20 16:38:33.653 error at Socket. (/opt/iobroker/node_modules/iobroker.homekit/main.js:184:29) TypeError: 2016-08-20 16:38:33.653 error Cannot read property 'native' of undefined uncaught 2016-08-20 16:38:33.651 error exception: Cannot read property 'native' of undefined `
          Примечание: на некоторых системах требуется дополнительный пакет sudo apt-get install libavahi-compat-libdnssd-dev
          Здесь смотрел http://forum.iobroker.net/viewtopic.php?f=16&t=3401
            creo last edited by
            нода 4,5
            libavahi-compat-libdnssd-dev - установлен
              creo last edited by
              Пробовал менять Node, не помогает (
