    4. Breaking Change bei MQTT Adapter 2.1+ via Websockets?
    UNSOLVED Breaking Change bei MQTT Adapter 2.1+ via Websockets?
      blumfisch last edited by
      Re: MQTT >1.5 funktioniert bei mir nicht mehr
      Hallo, wäre toll, wenn mir jemand helfen könnte:
      Wenn ich iobroker MQTT Adapter v2.1 installiere
      bringt meine Javascript Webseite, die sich über den Paho-Client via Websockets im lokalen Netz auf Port 1884 beim iobroker MQTT Server 2.1 anmelden möchte:
      client = new Paho.MQTT.Client("192.168.178.101", Number(1884), "/ws", "MeineMQTTWebseite");
      den MQTT Adapter mit folgender Fehlermeldung zum Absturz:
      host.ioBroker-RasPi	2020-04-06 11:08:14.131	info	Restart adapter system.adapter.mqtt.0 because enabled
      host.ioBroker-RasPi	2020-04-06 11:08:14.130	error	instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      host.ioBroker-RasPi	2020-04-06 11:08:14.130	error	Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
      host.ioBroker-RasPi	2020-04-06 11:08:14.130	error	Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
      host.ioBroker-RasPi	2020-04-06 11:08:14.129	error	Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
      host.ioBroker-RasPi	2020-04-06 11:08:14.129	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
      host.ioBroker-RasPi	2020-04-06 11:08:14.129	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
      host.ioBroker-RasPi	2020-04-06 11:08:14.129	error	Caught by controller[0]: at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
      host.ioBroker-RasPi	2020-04-06 11:08:14.128	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
      host.ioBroker-RasPi	2020-04-06 11:08:14.128	error	Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
      host.ioBroker-RasPi	2020-04-06 11:08:14.127	error	Caught by controller[0]: at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:756:30)
      host.ioBroker-RasPi	2020-04-06 11:08:14.126	error	Caught by controller[0]: TypeError: stream.setTimeout is not a function
      mqtt.0	2020-04-06 11:08:13.639	info	(9969) terminating
      mqtt.0	2020-04-06 11:08:13.582	warn	(9969) Terminated (UNCAUGHT_EXCEPTION): Without reason
      mqtt.0	2020-04-06 11:08:12.484	error	(9969) TypeError: stream.setTimeout is not a function at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:756:30) at Connection.emit (events.js:198:13)
      mqtt.0	2020-04-06 11:08:12.483	error	(9969) uncaught exception: stream.setTimeout is not a function
      mqtt.0	2020-04-06 11:08:12.287	info	(9969) Client [LAB_CountdownHTML] connected with secret 1586164092263_8980
      mqtt.0	2020-04-06 11:08:11.883	info	(9969) Starting MQTT -WebSocket' server on port 1884
      mqtt.0	2020-04-06 11:08:11.882	info	(9969) Starting MQTT ' server on port 1883
      mqtt.0	2020-04-06 11:08:10.235	info	(9969) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.19.0
      host.ioBroker-RasPi	2020-04-06 11:08:07.573	info	instance system.adapter.mqtt.0 started with pid 9969
      • Das passiert ERST seit dieser Version (irgendwo ab 2.1?)
      • Mit MQTT Adapter 2.0.4 funktioniert alles einwandfrei. (2.0.5. und 2.0.6 nicht getestet)
      • Verschiedene ESP8266 Mikrocontroller melden sich auf Port 1883 (OHNE Websockets) in allen Versionen an, ohne dass es zu Problemen kommt.
      • Leider kann ich Paho nicht sagen, sich ebenfalls auf 1883 anzumelden und keine Websockets zu verwenden. Vielleicht gehts, aber ich weiß nicht wie.
      • Alles andere ist gleich geblieben. Ich benutze KEIN SSL.
      => Es müsste also daran liegen, dass sich im iobroker-MQTT-Adapter 2.1 irgendwas geändert hat, was den Port 1884 und Websockets angeht.
      Frage ist: Was und kann sich das mal jemand angucken? Ich kann sonst ja nicht mehr updaten und muss Iobroker einfrieren.
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3 + x64
      Arbeitsspeicher: 1GB
      Festplattenart: SSD
      Betriebssystem: Raspbian/Windows (Webseite)
      Node-Version: v10.19.0
      Nodejs-Version: v10.19.0
      NPM-Version: 6.13.7
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link Re: MQTT >1.5 funktioniert bei mir nicht mehr
        blumfisch @blumfisch last edited by
        Auch mit den neuesten Updates:
        socket.io 2.1.2 auf 3.0.6
        und nochmals MQTT Broker/Client 2.0.4 auf 2.1.1
        kommt es zum sofortigen Absturz, wenn sich meine Webseite über Websockets/Port 1884 beim MQTT Broker anmeldet.
        Gleiche Fehlermeldung wie oben.
        Erst wenn ich MQTT wieder zurück auf 2.0.4 installiere, funktioniert alles wieder. Socket.io Version scheint nicht relevant zu sein.
        Weiß vielleicht jemand, wo ich sonst um Hilfe fragen könnte?
        Auf Github habe ich schon seit geraumer Zeit ein Issue eröffnet, aber da meldet sich auch niemand.
        Hier nochmal die Fehlermeldung iobroker Logs mit MQTT Version 2.1.1:
        host.ioBroker-RasPi	2020-05-04 10:06:54.647	error	instance system.adapter.mqtt.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
        host.ioBroker-RasPi	2020-05-04 10:06:54.645	error	Caught by controller[0]: at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
        host.ioBroker-RasPi	2020-05-04 10:06:54.644	error	Caught by controller[0]: at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
        host.ioBroker-RasPi	2020-05-04 10:06:54.644	error	Caught by controller[0]: at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
        host.ioBroker-RasPi	2020-05-04 10:06:54.644	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
        host.ioBroker-RasPi	2020-05-04 10:06:54.643	error	Caught by controller[0]: at Object.onceWrapper (events.js:286:20)
        host.ioBroker-RasPi	2020-05-04 10:06:54.643	error	Caught by controller[0]: at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
        host.ioBroker-RasPi	2020-05-04 10:06:54.642	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
        host.ioBroker-RasPi	2020-05-04 10:06:54.642	error	Caught by controller[0]: at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
        host.ioBroker-RasPi	2020-05-04 10:06:54.641	error	Caught by controller[0]: at Connection.emit (events.js:198:13)
        host.ioBroker-RasPi	2020-05-04 10:06:54.640	error	Caught by controller[0]: at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:756:30)
        host.ioBroker-RasPi	2020-05-04 10:06:54.638	error	Caught by controller[0]: TypeError: stream.setTimeout is not a function
        mqtt.0	2020-05-04 10:06:53.460	info	(6894) terminating
        mqtt.0	2020-05-04 10:06:53.405	warn	(6894) Terminated (UNCAUGHT_EXCEPTION): Without reason
        mqtt.0	2020-05-04 10:06:52.026	error	at Connection.Readable.push (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:245:10)
        mqtt.0	2020-05-04 10:06:52.026	error	at readableAddChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:278:11)
        mqtt.0	2020-05-04 10:06:52.026	error	at addChunk (/opt/iobroker/node_modules/readable-stream/lib/_stream_readable.js:291:12)
        mqtt.0	2020-05-04 10:06:52.026	error	at Connection.emit (events.js:198:13)
        mqtt.0	2020-05-04 10:06:52.026	error	at Object.onceWrapper (events.js:286:20)
        mqtt.0	2020-05-04 10:06:52.026	error	at Connection.<anonymous> (/opt/iobroker/node_modules/mqtt-connection/connection.js:53:12)
        mqtt.0	2020-05-04 10:06:52.026	error	at Connection.emitPacket (/opt/iobroker/node_modules/mqtt-connection/connection.js:10:8)
        mqtt.0	2020-05-04 10:06:52.026	error	at Connection.client.on.options (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:756:30)
        mqtt.0	2020-05-04 10:06:52.026	error	(6894) TypeError: stream.setTimeout is not a function
        mqtt.0	2020-05-04 10:06:52.025	error	(6894) uncaught exception: stream.setTimeout is not a function
        mqtt.0	2020-05-04 10:06:51.784	info	(6894) Client [SCHATZ-COUNTDOWN-70185] connected with secret 1588579611759_4423
        mqtt.0	2020-05-04 10:06:51.321	info	(6894) Starting MQTT -WebSocket' server on port 1884
        mqtt.0	2020-05-04 10:06:51.319	info	(6894) Starting MQTT ' server on port 1883
        mqtt.0	2020-05-04 10:06:49.412	info	(6894) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.19.0
        Und hier das gleiche Verhalten mit MQTT Version 2.0.4:
        mqtt.0	2020-05-04 10:07:28.228	info	(7360) Client [SCHATZ-COUNTDOWN-70185] subscribes on topic "SCHATZ/"
        mqtt.0	2020-05-04 10:07:28.023	info	(7360) Client [SCHATZ-COUNTDOWN-70185] connected with secret 1588579648006_4897
        mqtt.0	2020-05-04 10:07:14.470	info	(7360) Starting MQTT -WebSocket' server on port 1884
        mqtt.0	2020-05-04 10:07:14.467	info	(7360) Starting MQTT ' server on port 1883
        mqtt.0	2020-05-04 10:07:12.709	info	(7360) starting. Version 2.0.4 in /opt/iobroker/node_modules/iobroker.mqtt, node: v10.19.0
        Danach keine Fehlermeldung. Es läuft und läuft.
        mqtt mqtt adapter server port 1884 websockets
