    4. JavaScript Adapter 3.0.0 Fehlerhaft
      kleinerDrache last edited by
      update läuft durch aber beim starten kommt :
      host-jarvis	2016-08-27 22:36:43.835	info	Restart adapter system.adapter.javascript.0 because enabled
      host-jarvis	2016-08-27 22:36:43.830	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
      javascript-0	2016-08-27 22:36:43.736	info	terminating
      TypeError:	2016-08-27 22:36:43.618	error	at Zlib.callback (zlib.js:625:5)
      TypeError:	2016-08-27 22:36:43.618	error	at TransformState.afterTransform (_stream_transform.js:54:12)
      TypeError:	2016-08-27 22:36:43.618	error	at afterTransform (_stream_transform.js:79:3)
      TypeError:	2016-08-27 22:36:43.618	error	at WritableState.onwrite (_stream_writable.js:89:5)
      TypeError:	2016-08-27 22:36:43.618	error	at onwrite (_stream_writable.js:345:7)
      TypeError:	2016-08-27 22:36:43.618	error	at afterWrite (_stream_writable.js:354:3)
      TypeError:	2016-08-27 22:36:43.618	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/PerMessageDeflate.js:247:5
      TypeError:	2016-08-27 22:36:43.618	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:361:7
      TypeError:	2016-08-27 22:36:43.618	error	at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:477:18
      TypeError:	2016-08-27 22:36:43.618	error	at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:816:10)
      TypeError:	2016-08-27 22:36:43.618	error	at WebSocket.emit (events.js:172:7)
      TypeError:	2016-08-27 22:36:43.618	error	at emitTwo (events.js:87:13)
      TypeError:	2016-08-27 22:36:43.618	error	at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:418:14)
      TypeError:	2016-08-27 22:36:43.618	error	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:132:10)
      TypeError:	2016-08-27 22:36:43.618	error	at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8)
      TypeError:	2016-08-27 22:36:43.618	error	at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8)
      TypeError:	2016-08-27 22:36:43.618	error	at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2016-08-27 22:36:43.618	error	at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-08-27 22:36:43.618	error	at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
      TypeError:	2016-08-27 22:36:43.618	error	at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
      TypeError:	2016-08-27 22:36:43.618	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
      TypeError:	2016-08-27 22:36:43.618	error	at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-08-27 22:36:43.618	error	at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
      TypeError:	2016-08-27 22:36:43.618	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-08-27 22:36:43.618	error	at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError:	2016-08-27 22:36:43.618	error	at Socket. (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:283:37)
      TypeError:	2016-08-27 22:36:43.618	error	at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2268:20)
      TypeError:	2016-08-27 22:36:43.618	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2261:53)
      TypeError:	2016-08-27 22:36:43.618	error	Cannot read property 'substring' of undefined
      uncaught	2016-08-27 22:36:43.581	error	exception: Cannot read property 'substring' of undefined
      javascript-0	2016-08-27 22:36:43.499	info	received all objects
      javascript-0	2016-08-27 22:36:42.671	info	received all states
      javascript-0	2016-08-27 22:36:40.215	info	requesting all objects
      javascript-0	2016-08-27 22:36:40.205	info	requesting all states
      javascript-0	2016-08-27 22:36:40.143	info	starting. Version 3.0.0 in /opt/iobroker/node_modules/iobroker.javascript
        Stmiko last edited by
        Ja, kann ich bestätigen…...bei mir das selbe Verhalten.
          simpixo last edited by
          Bei mir auch auch, ich bin schon mal soweit das ich diese Fehlermeldung erhalte:
          host.HQ-RASPI-00 instance system.adapter.javascript.0 terminated with code 0 (OK)
          javascript.0	2016-08-27 22:55:42.425	error	uncaught exception: Cannot read property 'substring' of undefined
          Davor hatte ich auch die oben genannte! Als ich die alte Version wieder installier hatte, bekam ich auch einen Fehler aber irgendwas mit Xpc-connection@0.1.4 [emoji53]
          Gesendet von meinem iPhone mit Tapatalk
            looxer01 last edited by
            Hi
            bei mir leider auch. (neuer js-contoller ist installiert)
            Ich habe versucht auf die alte Version zu gehen mit: "npm install iobroker.javascript@2.3.0 –production"
            leider geht das nicht. mache ich da was falsch ?
            vG Looxer
              PrinzEisenherz1 last edited by
              Hier das selbe Problem
                Es gibt fix.
                  vielen Dank. Es funktioniert wieder.
                  Ich muss schon sagen, dass ich schwer beeindruckt bin was du machst aber auch wie du das machst.
                  Das ist nicht selbstverständlich. Zeit für eine Spende …... 😄
                  lG Looxer
                    thx und auch ich bin echt beeindruckt wie schnell das hier geht
                    • apollon77
                      apollon77 last edited by
                      Ich habe mit der 3.0.1 jetzt noch einen komischen Effekt … Alle Skripte mit Instanz 0 klappen problemlos. Bei Instanz 1 wird nichts gestartet.
                      Nachvollziehbar - sobald ich ein Skript auf Instanz 1 ziehe geht nichts mehr, zurück auf Instanz 0 und alles normal ...
                      Hat sowas noch jemand?
