    4. Fehlermeldung bei manuelles Update / Adapter
    SOLVED Fehlermeldung bei manuelles Update / Adapter
      LJSven last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Tinkerboard
      Arbeitsspeicher: 2GB
      Festplattenart: SD-Karte
      Betriebssystem: Debian Stretch with Armbian Linux 4.19.69-rockchip
      Node-Version: 10.20.1
      Nodejs-Version: 10.20.1
      NPM-Version: 6.14.4
      Installationsart: Manuell
      Wenn ich über iobroker update && iobroker upgrade ein Update als root ausführe, kommt immer folgende Meldung.
      Update iot from @1.4.2 to @1.4.4
      host.tinkerboardmaster Adapter "system.adapter.iot.0" is stopped.
      NPM version: 6.14.4
      npm install iobroker.iot@1.4.4 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.
      Perhaps you should add the directory containing `pixman-1.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)
      gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 4.19.69-rockchip
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v64"
      gyp ERR! cwd /opt/iobroker/node_modules/canvas
      gyp ERR! node -v v10.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v64' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:982:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
      node-pre-gyp ERR! System Linux 4.19.69-rockchip
      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvas
      node-pre-gyp ERR! node -v v10.20.1
      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
      node-pre-gyp ERR! not ok
      ERR! sharp Use with glibc 2.24 requires manual installation of libvips >= 8.9.1
      info sharp Attempting to build from source via node-gyp but this may fail due to the above error
      info sharp Please see https://sharp.pixelplumbing.com/install for required dependencies
      ../src/common.cc:23:22: fatal error: vips/vips8: Datei oder Verzeichnis nicht gefunden
       #include <vips/vips8>
      compilation terminated.
      make: *** [Release/obj.target/sharp/src/common.o] Fehler 1
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/sharp
      gyp ERR! not ok
      Update "system.adapter.iot.0"
      upload [20] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8b3eca34.js.map static/js/runtime-main.8b3eca34.js.map application/json
      upload [19] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/runtime-main.8b3eca34.js static/js/runtime-main.8b3eca34.js application/javascript
      upload [18] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.721d1c42.chunk.js.map static/js/main.721d1c42.chunk.js.map application/json
      upload [17] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/main.721d1c42.chunk.js static/js/main.721d1c42.chunk.js application/javascript
      upload [16] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js.map static/js/2.faa62e98.chunk.js.map application/json
      upload [15] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js.LICENSE.txt static/js/2.faa62e98.chunk.js.LICENSE.txt text/plain
      upload [14] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/js/2.faa62e98.chunk.js static/js/2.faa62e98.chunk.js application/javascript
      upload [13] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css.map static/css/main.d4bed9c6.chunk.css.map application/json
      upload [12] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/main.d4bed9c6.chunk.css static/css/main.d4bed9c6.chunk.css text/css
      upload [11] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css.map static/css/2.b1b16afe.chunk.css.map application/json
      upload [10] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/static/css/2.b1b16afe.chunk.css static/css/2.b1b16afe.chunk.css text/css
      upload [9] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/service-worker.js service-worker.js application/javascript
      upload [8] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/precache-manifest.b5249c907f3acd0903d8c4d182d1dce1.js precache-manifest.b5249c907f3acd0903d8c4d182d1dce1.js application/javascript
      upload [7] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/manifest.json manifest.json application/json
      upload [6] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/iot.png iot.png image/png
      upload [5] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/index_m.html index_m.html text/html
      upload [4] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [3] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/blockly.js blockly.js application/javascript
      upload [2] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/asset-manifest.json asset-manifest.json application/json
      upload [1] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/alexalogo.png alexalogo.png image/png
      upload [0] iot.admin /opt/iobroker/node_modules/iobroker.iot/admin/actions.js actions.js application/javascript
      Adapter "iot" updated
      host.tinkerboardmaster Adapter "system.adapter.iot.0" is started
      Bei jedem Adapter kommt diese "pixman-1" Meldung. Was muss ich da tun?
      • Glasfaser
        Glasfaser @LJSven last edited by
        @LJSven
        Link Text
        iot iot adapter update
