    4. Fehler beim Upgrade des js-controllers
      ChristianF last edited by
      folgenden Fehler hat es bei mir beim Upgrade des js-controllers gegeben:
      root@HWR-Raspi:/opt/iobroker# npm install iobroker.js-controller --production
      > iobroker.js-controller@0.11.3 install /opt/iobroker/node_modules/iobroker.js-controller
      > node lib/setup.js setup first
      fs.js:549
        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
      Error: EACCES: permission denied, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../../../killall.sh'
          at Error (native)
          at Object.fs.openSync (fs.js:549:18)
          at Object.fs.writeFileSync (fs.js:1156:15)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:213:24)
          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:538:23
          at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:559:11)
          at Module._compile (module.js:409:26)
          at Object.Module._extensions..js (module.js:416:10)
          at Module.load (module.js:343:32)
          at Function.Module._load (module.js:300:12)
      npm ERR! Linux 4.4.13-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller" "--production"
      npm ERR! node v4.4.7
      npm ERR! npm  v2.15.8
      npm ERR! code ELIFECYCLE
      npm ERR! iobroker.js-controller@0.11.3 install: `node lib/setup.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@0.11.3 install script 'node lib/setup.js setup first'.
      npm ERR! This is most likely a problem with the iobroker.js-controller package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR!     node lib/setup.js setup first
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR!     npm bugs iobroker.js-controller
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!
      npm ERR!     npm owner ls iobroker.js-controller
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log</anonymous>
      Einen Fehler bezüglich des Killall Scripts habe ich noch an anderer Stelle: beim Aufruf von ./iobroker stop kommt ein Exitcode 127 für killall.sh . Ich habe kurz nachgelesen und herausgefunden dass 127 der Exitcode ist für "File not found". Vielleicht ist irgendwo ein relativer Pfad falsch oder so?
      Viele grüße
      Christian
        Hmm, niemand ne Idee?
        Viele Grüße
        Christian
          Hab die Installation plattgemacht und neu installiert -> läuft.
