    4. Update node-red mit error
      Beim aktuellen update von node-red gab es einiges gemecker:
       host-quad-pi	2015-03-25 22:34:57	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
      node-red-0	2015-03-25 22:34:57	info	 node-red exited with 8
      TypeError:	2015-03-25 22:34:57	error	 at Pipe.onread (net.js:526:21)
      TypeError:	2015-03-25 22:34:57	error	 at Socket.Readable.push (_stream_readable.js:127:10)
      TypeError:	2015-03-25 22:34:57	error	 at readableAddChunk (_stream_readable.js:165:9)
      TypeError:	2015-03-25 22:34:57	error	 at emitReadable (_stream_readable.js:404:5)
      TypeError:	2015-03-25 22:34:57	error	 at emitReadable_ (_stream_readable.js:408:10)
      TypeError:	2015-03-25 22:34:57	error	 at Socket.EventEmitter.emit (events.js:92:17)
      TypeError:	2015-03-25 22:34:57	error	 at Socket. (_stream_readable.js:746:14)
      TypeError:	2015-03-25 22:34:57	error	 at Socket.EventEmitter.emit (events.js:95:17)
      TypeError:	2015-03-25 22:34:57	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:100:18)
      TypeError:	2015-03-25 22:34:57	error	 has no method 'indexOf'
      TypeError:	2015-03-25 22:34:57	error	 at Module.load (module.js:356:32)
      TypeError:	2015-03-25 22:34:57	error	 at Object.Module._extensions..js (module.js:474:10)
      TypeError:	2015-03-25 22:34:57	error	 at Module._compile (module.js:456:26)
      TypeError:	2015-03-25 22:34:57	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
      TypeError:	2015-03-25 22:34:57	error	 at require (module.js:380:17)
      TypeError:	2015-03-25 22:34:57	error	 at Module.require (module.js:364:17)
      TypeError:	2015-03-25 22:34:57	error	 at Function.Module._load (module.js:312:12)
      TypeError:	2015-03-25 22:34:57	error	 at Object.Module._extensions..json (module.js:482:27)
      TypeError:	2015-03-25 22:34:57	error	 at Object.parse (native)
      TypeError:	2015-03-25 22:34:57	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
      TypeError:	2015-03-25 22:34:57	error	 ^
      TypeError:	2015-03-25 22:34:57	error	 throw err;
      TypeError:	2015-03-25 22:34:57	error	 Object module.js:485
      uncaught	2015-03-25 22:34:57	error	 has no method 'indexOf'
      uncaught	2015-03-25 22:34:57	error	 at Module.load (module.js:356:32)
      uncaught	2015-03-25 22:34:57	error	 at Object.Module._extensions..js (module.js:474:10)
      uncaught	2015-03-25 22:34:57	error	 at Module._compile (module.js:456:26)
      uncaught	2015-03-25 22:34:57	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
      uncaught	2015-03-25 22:34:57	error	 at require (module.js:380:17)
      uncaught	2015-03-25 22:34:57	error	 at Module.require (module.js:364:17)
      uncaught	2015-03-25 22:34:57	error	 at Function.Module._load (module.js:312:12)
      uncaught	2015-03-25 22:34:57	error	 at Object.Module._extensions..json (module.js:482:27)
      uncaught	2015-03-25 22:34:57	error	 at Object.parse (native)
      uncaught	2015-03-25 22:34:57	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
      uncaught	2015-03-25 22:34:57	error	 ^
      uncaught	2015-03-25 22:34:57	error	 throw err;
      uncaught	2015-03-25 22:34:57	error	 exception: Object module.js:485
      node-red-0	2015-03-25 22:34:56	info	 Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
      node-red-0	2015-03-25 22:34:54	info	 starting. Version 0.1.7 in /opt/iobroker/node_modules/iobroker.node-red
      2015-03-25 22:34:53	info	info
      host-quad-pi	2015-03-25 22:34:52	info	 instance system.adapter.node-red.0 started with pid 11468
      host-quad-pi	2015-03-25 22:34:22	info	 Restart adapter system.adapter.node-red.0 because enabled
      host-quad-pi	2015-03-25 22:34:22	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
      node-red-0	2015-03-25 22:34:22	info	 node-red exited with 8
      TypeError:	2015-03-25 22:34:22	error	 at Pipe.onread (net.js:526:21)
      TypeError:	2015-03-25 22:34:22	error	 at Socket.Readable.push (_stream_readable.js:127:10)
      TypeError:	2015-03-25 22:34:22	error	 at readableAddChunk (_stream_readable.js:165:9)
      TypeError:	2015-03-25 22:34:22	error	 at emitReadable (_stream_readable.js:404:5)
      TypeError:	2015-03-25 22:34:22	error	 at emitReadable_ (_stream_readable.js:408:10)
      TypeError:	2015-03-25 22:34:22	error	 at Socket.EventEmitter.emit (events.js:92:17)
      TypeError:	2015-03-25 22:34:22	error	 at Socket. (_stream_readable.js:746:14)
      TypeError:	2015-03-25 22:34:22	error	 at Socket.EventEmitter.emit (events.js:95:17)
      TypeError:	2015-03-25 22:34:22	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:100:18)
      TypeError:	2015-03-25 22:34:22	error	 has no method 'indexOf'
      TypeError:	2015-03-25 22:34:22	error	 at Module.require (module.js:364:17)
      TypeError:	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:312:12)
      TypeError:	2015-03-25 22:34:22	error	 at Module.load (module.js:356:32)
      TypeError:	2015-03-25 22:34:22	error	 at Object.Module._extensions..js (module.js:474:10)
      TypeError:	2015-03-25 22:34:22	error	 at Module._compile (module.js:456:26)
      TypeError:	2015-03-25 22:34:22	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/lib/proto.js:12:20)
      TypeError:	2015-03-25 22:34:22	error	 at require (module.js:380:17)
      TypeError:	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:280:25)
      TypeError:	2015-03-25 22:34:22	error	 at Function.Module._resolveFilename (module.js:338:15)
      TypeError:	2015-03-25 22:34:22	error	Error: Cannot find module 'finalhandler'
      TypeError:	2015-03-25 22:34:22	error	 ^
      TypeError:	2015-03-25 22:34:22	error	 throw err;
      TypeError:	2015-03-25 22:34:22	error	 Object module.js:340
      uncaught	2015-03-25 22:34:22	error	 has no method 'indexOf'
      uncaught	2015-03-25 22:34:22	error	 at Module.require (module.js:364:17)
      uncaught	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:312:12)
      uncaught	2015-03-25 22:34:22	error	 at Module.load (module.js:356:32)
      uncaught	2015-03-25 22:34:22	error	 at Object.Module._extensions..js (module.js:474:10)
      uncaught	2015-03-25 22:34:22	error	 at Module._compile (module.js:456:26)
      uncaught	2015-03-25 22:34:22	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/lib/proto.js:12:20)
      uncaught	2015-03-25 22:34:22	error	 at require (module.js:380:17)
      uncaught	2015-03-25 22:34:22	error	 at Function.Module._load (module.js:280:25)
      uncaught	2015-03-25 22:34:22	error	 at Function.Module._resolveFilename (module.js:338:15)
      uncaught	2015-03-25 22:34:22	error	Error: Cannot find module 'finalhandler'
      uncaught	2015-03-25 22:34:22	error	 ^
      uncaught	2015-03-25 22:34:22	error	 throw err;
      uncaught	2015-03-25 22:34:22	error	 exception: Object module.js:340
      node-red-0	2015-03-25 22:34:21	info	 Starting node-red: /opt/iobroker
        Probiere jetzt
          Naja, sieht auch nicht gut sus:
           iobroker	2015-03-26 16:28:38	info	> node-gyp rebuild
          iobroker	2015-03-26 16:28:38	info	 > iconv@2.1.6 install /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/iconv
          host-quad-pi	2015-03-26 16:28:12	info	 Restart adapter system.adapter.node-red.0 because enabled
          host-quad-pi	2015-03-26 16:28:12	error	 instance system.adapter.node-red.0 terminated with code 6 (uncaught exception)
          node-red-0	2015-03-26 16:28:12	info	 node-red exited with 8
          TypeError:	2015-03-26 16:28:12	error	 at Pipe.onread (net.js:526:21)
          TypeError:	2015-03-26 16:28:12	error	 at Socket.Readable.push (_stream_readable.js:127:10)
          TypeError:	2015-03-26 16:28:12	error	 at readableAddChunk (_stream_readable.js:165:9)
          TypeError:	2015-03-26 16:28:12	error	 at emitReadable (_stream_readable.js:404:5)
          TypeError:	2015-03-26 16:28:12	error	 at emitReadable_ (_stream_readable.js:408:10)
          TypeError:	2015-03-26 16:28:12	error	 at Socket.EventEmitter.emit (events.js:92:17)
          TypeError:	2015-03-26 16:28:12	error	 at Socket. (_stream_readable.js:746:14)
          TypeError:	2015-03-26 16:28:12	error	 at Socket.EventEmitter.emit (events.js:95:17)
          TypeError:	2015-03-26 16:28:12	error	 at Socket. (/opt/iobroker/node_modules/iobroker.node-red/main.js:103:18)
          TypeError:	2015-03-26 16:28:12	error	 has no method 'indexOf'
          TypeError:	2015-03-26 16:28:12	error	 at Module.load (module.js:356:32)
          TypeError:	2015-03-26 16:28:12	error	 at Object.Module._extensions..js (module.js:474:10)
          TypeError:	2015-03-26 16:28:12	error	 at Module._compile (module.js:456:26)
          TypeError:	2015-03-26 16:28:12	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
          TypeError:	2015-03-26 16:28:12	error	 at require (module.js:380:17)
          TypeError:	2015-03-26 16:28:12	error	 at Module.require (module.js:364:17)
          TypeError:	2015-03-26 16:28:12	error	 at Function.Module._load (module.js:312:12)
          TypeError:	2015-03-26 16:28:12	error	 at Object.Module._extensions..json (module.js:482:27)
          TypeError:	2015-03-26 16:28:12	error	 at Object.parse (native)
          TypeError:	2015-03-26 16:28:12	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
          TypeError:	2015-03-26 16:28:12	error	 ^
          TypeError:	2015-03-26 16:28:12	error	 throw err;
          TypeError:	2015-03-26 16:28:12	error	 Object module.js:485
          uncaught	2015-03-26 16:28:12	error	 has no method 'indexOf'
          uncaught	2015-03-26 16:28:12	error	 at Module.load (module.js:356:32)
          uncaught	2015-03-26 16:28:12	error	 at Object.Module._extensions..js (module.js:474:10)
          uncaught	2015-03-26 16:28:12	error	 at Module._compile (module.js:456:26)
          uncaught	2015-03-26 16:28:12	error	 at Object. (/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-d
          uncaught	2015-03-26 16:28:12	error	 at require (module.js:380:17)
          uncaught	2015-03-26 16:28:12	error	 at Module.require (module.js:364:17)
          uncaught	2015-03-26 16:28:12	error	 at Function.Module._load (module.js:312:12)
          uncaught	2015-03-26 16:28:12	error	 at Object.Module._extensions..json (module.js:482:27)
          uncaught	2015-03-26 16:28:12	error	 at Object.parse (native)
          uncaught	2015-03-26 16:28:12	error	SyntaxError: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/express/node_modules/connect/node_modules/type-is/node_modules/mime-types/node_modules/mime-db/db.json: Une
          uncaught	2015-03-26 16:28:12	error	 ^
          uncaught	2015-03-26 16:28:12	error	 throw err;
          uncaught	2015-03-26 16:28:12	error	 exception: Object module.js:485
          node-red-0	2015-03-26 16:28:11	info	 Starting node-red: /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/red.js -v --settings /opt/iobroker/node_modules/iobroker.node-red/userdata/settings.js
          node-red-0	2015-03-26 16:28:07	info	 starting. Version 0.1.8 in /opt/iobroker/node_modules/iobroker.node-red
          Gesendet von meinem Cynus T7 mit Tapatalk
            Bei dir hat npm versagt. Kannst du folgendes machen:
            cd /opt/iobroker
            sudo rm -r /opt/iobroker/node_modules/iobroker.node-red/
            npm install iobroker.node-red
              Sieht leider auch nicht gut aus:
              make: Entering directory '/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector/build'
                CXX(target) Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o
              ../node-icu-charset-detector.cpp:5:28: fatal error: unicode/ucsdet.h: Datei oder Verzeichnis nicht gefunden
              compilation terminated.
              node-icu-charset-detector.target.mk:77: recipe for target 'Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o' failed
              make: *** [Release/obj.target/node-icu-charset-detector/node-icu-charset-detector.o] Error 1
              make: Leaving directory '/opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector/build'
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2
              gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
              gyp ERR! stack     at ChildProcess.EventEmitter.emit (events.js:98:17)
              gyp ERR! stack     at Process.ChildProcess._handle.onexit (child_process.js:789:12)
              gyp ERR! System Linux 3.18.7-v7+
              gyp ERR! command "node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
              gyp ERR! cwd /opt/iobroker/node_modules/iobroker.node-red/node_modules/node-red/node_modules/irc/node_modules/node-icu-charset-detector
              gyp ERR! node -v v0.10.22
              gyp ERR! node-gyp -v v0.11.0
              gyp ERR! not ok
              npm http GET https://registry.npmjs.org/hoek
              npm http GET https://registry.npmjs.org/boom
