    4. [Fehler] nach Neustart des Systems # module.js:340
    • derAuge
      derAuge last edited by
      leider ist mein ioBroker-System nach einer Laufzeit von 5 Tagen wund einem Neustart das Host-Systems (Pi2) wieder "zustört"
      Auf dem Monitor das Pi2 erscheint:
      [ OK ] Starting system message bus: dbus.
      Startion ioBroker
      module.js:340
          throw err;
      Error: Cannot find module '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/iobroker.js'
          at Function.Module._resolveFilename (module.js:338:15)
          at Function.Module._load (module.js:280:25)
          at Function.Module.runMain (module.js:497:10)
          at startup (node.js:119:16)
          at node.js:935:3
      [ OK ] Starting RPi-Monitor: rpimonitord
      das ist das gleche Fehlerbild wie bei http://forum.iobroker.org/viewtopic.php … =500#p3363
      Nun stellt sich mir die Frage: Was geht da kaputt?
      Werde nun versuchen das ioBroker-System wieder zu reparieren
      • derAuge
        Den js-controller neu installieren
        root@pi2:/mnt/ioBroker/iobroker.Pi2# apt-get update && apt-get upgrade -y
        root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.js-controller
        > ws@0.5.0 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/w                                                s
        > (node-gyp rebuild 2> builderror.log) || (exit 0)
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_mo                                                dules/ws/build'
          CXX(target) Release/obj.target/bufferutil/src/bufferutil.o
          SOLINK_MODULE(target) Release/obj.target/bufferutil.node
          SOLINK_MODULE(target) Release/obj.target/bufferutil.node: Finished
          COPY Release/bufferutil.node
          CXX(target) Release/obj.target/validation/src/validation.o
          SOLINK_MODULE(target) Release/obj.target/validation.node
          SOLINK_MODULE(target) Release/obj.target/validation.node: Finished
          COPY Release/validation.node
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
        npm WARN engine hawk@0.10.2: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
        npm WARN engine cryptiles@0.1.3: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
        npm WARN engine boom@0.3.8: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
        npm WARN engine sntp@0.1.4: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
        npm WARN engine hoek@0.7.6: wanted: {"node":"0.8.x"} (current: {"node":"0.10.37","npm":"1.4.28"})
        > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/buil                     d'
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/build                     '
        npm WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
        > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules                     /ws
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_m                     odules/ws/build'
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_mo                     dules/ws/build'
        > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_                     modules/engine.io-client/node_modules/ws
        make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client                     /node_modules/engine.io-client/node_modules/ws/build'
        make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/                     node_modules/engine.io-client/node_modules/ws/build'
        > iobroker.js-controller@0.6.0 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller
        > node lib/setup.js setup first
        iobroker.js-controller@0.6.0 node_modules/iobroker.js-controller
        ├── daemonize2@0.4.2
        ├── mime@1.2.11
        ├── node-schedule@0.1.13
        ├── ncp@0.6.0
        ├── node.extend@1.0.10 (is@0.3.0)
        ├── adm-zip@0.4.7
        ├── yargs@1.2.6 (minimist@0.1.0)
        ├── tar.gz@0.1.1 (commander@1.1.1, tar@0.1.20, fstream@0.1.31)
        ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, mime-types@1.0.2, form-data@0.1.4, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
        ├── winston@0.7.3 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8, colors@0.6.2, async@0.2.10, pkginfo@0.3.0, request@2.16.6)
        ├── socket.io@1.2.1 (debug@0.7.4, has-binary-data@0.1.3, socket.io-adapter@0.3.1, socket.io-parser@2.2.2, engine.io@1.4.3)
        ├── socket.io-client@1.2.1 (to-array@0.1.3, indexof@0.0.1, component-bind@1.0.0, debug@0.7.4, object-component@0.0.3, component-emitter@1.1.2, parseuri@0.0.2, has-binary@0.1.5, socket.io-parser@2.2.2, engine.io-client@1.4.3)
        ├── npm@2.3.0
        └── iobroker.admin@0.3.23 (connect-flash@0.1.1, cookie-parser@1.3.4, passport-local@1.0.0, passport@0.2.1, xtend@2.0.6, express-session@1.7.6, express@4.4.5, body-parser@1.5.2, socket.io@1.0.6)
        ioBroker starten:
        root@pi2:/mnt/ioBroker/iobroker.Pi2# iobroker start
        Starting ioBroker controller daemon...
        ioBroker controller daemon started. PID: 17094
        Die installierten Adapter werden gestartet. Es fehlt "io.admin"
        root@pi2:/mnt/ioBroker/iobroker.Pi2# ps -A |grep io.
        17094 ?        00:00:26 io.js-controlle
        17124 ?        00:00:10 io.history.0
        17130 ?        00:00:04 io.hm-rpc.0
        17136 ?        00:00:07 io.hm-rega.0
        17157 ?        00:00:11 io.javascript.0
        17172 ?        00:00:03 io.ping.0
        17182 ?        00:00:03 io.sayit.0
        17192 ?        00:00:06 io.web.0
        17207 ?        00:00:05 io.sonos.0
        17229 ?        00:00:07 io.hm-rpc.1
        17235 ?        00:00:04 io.node-red.0
        Das UI (pi2:8081)ist nicht zu erreichen
        Pi2:8082/vis/#Heizung = läuft
        Pi2:8083/ = SONOS läuft
        Pi2:1880/ = node-RED läuft
        Wie bekomme ich "admin" ans laufen?
          iobroker add admin --enabled --port 8090
          Dann erscheint unter "http://ip:8090" die Admin Seite und über die kannst du wieder alles gerade machen.
          Falls admin.0 und admin.1 existieren, dann admin.0 aktivieren und admin.1 löschen. Falls nur admin.0 existiert dann Port wieder auf 8081 ändern.
          • derAuge
            @Bluefox:
            Falls admin.0 und admin.1 existieren, dann admin.0 aktivieren und admin.1 löschen. Falls nur admin.0 existiert dann Port wieder auf 8081 ändern. `
            root@pi2:/mnt/ioBroker/iobroker.Pi2# iobroker add admin --enabled --port 8090
            This should never happens!
            create instance admin
            error: reading io-package.json Error: ENOENT, no such file or directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/io-package.json'
              dann
              npm install iobroker.admin
              • derAuge
                root@pi2:/mnt/ioBroker/iobroker.Pi2# npm install iobroker.admin
                > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws
                make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
                make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/engine.io/node_modules/ws/build'
                > ws@0.4.31 install /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws
                make: Entering directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/                      ws/build'
                make: Leaving directory '/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.admin/node_modules/socket.io/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/w                      s/build'
                iobroker.admin@0.3.23 node_modules/iobroker.admin
                ├── connect-flash@0.1.1
                ├── cookie-parser@1.3.4 (cookie-signature@1.0.6, cookie@0.1.2)
                ├── passport-local@1.0.0 (passport-strategy@1.0.0)
                ├── passport@0.2.1 (pause@0.0.1, passport-strategy@1.0.0)
                ├── xtend@2.0.6 (is-object@0.1.2, object-keys@0.2.0)
                ├── express-session@1.7.6 (cookie@0.1.2, utils-merge@1.0.0, cookie-signature@1.0.4, on-headers@1.0.0, parseurl@1.3.0, buffer-crc32@0.2.3, depd@0.4.4, debug@1.0.4, uid-safe@1.0.1                      )
                ├── express@4.4.5 (parseurl@1.0.1, utils-merge@1.0.0, merge-descriptors@0.0.2, escape-html@1.0.1, cookie@0.1.2, cookie-signature@1.0.4, range-parser@1.0.0, fresh@0.2.2, vary@0.1                      .0, qs@0.6.6, methods@1.0.1, serve-static@1.2.3, buffer-crc32@0.2.3, path-to-regexp@0.1.2, debug@1.0.2, proxy-addr@1.0.1, send@0.4.3, type-is@1.2.1, accepts@1.0.7)
                ├── body-parser@1.5.2 (qs@0.6.6, media-typer@0.2.0, raw-body@1.3.0, bytes@1.0.0, depd@0.4.4, type-is@1.3.2, iconv-lite@0.4.4)
                ├── request@2.38.0 (json-stringify-safe@5.0.0, forever-agent@0.5.2, aws-sign2@0.5.0, qs@0.6.6, oauth-sign@0.3.0, stringstream@0.0.4, tunnel-agent@0.4.0, node-uuid@1.4.3, form-da                      ta@0.1.4, mime-types@1.0.2, http-signature@0.10.1, tough-cookie@0.12.1, hawk@1.1.1)
                └── socket.io@1.0.6 (debug@0.7.4, has-binary-data@0.1.1, socket.io-parser@2.2.0, socket.io-adapter@0.2.0, engine.io@1.3.1, socket.io-client@1.0.6)
                > iobroker add admin –enabled --port 8090
                object system.adapter.admin.1.uptime created
                object system.adapter.admin.1.memRss created
                object system.adapter.admin.1.memHeapTotal created
                object system.adapter.admin.1.memHeapUsed created
                object system.adapter.admin.1.connected created
                object system.adapter.admin.1.alive created
                object system.adapter.admin.1 created
                 2313 ?        00:07:42 io.js-controlle
                 2422 ?        00:02:17 io.history.0
                 2432 ?        00:00:34 io.hm-rpc.0
                 2455 ?        00:00:41 io.hm-rega.0
                 2476 ?        00:02:15 io.javascript.0
                 2482 ?        00:00:12 io.ping.0
                 2507 ?        00:00:06 io.sayit.0
                 2513 ?        00:02:25 io.web.0
                 2519 ?        00:00:35 io.sonos.0
                 2540 ?        00:00:10 io.hm-rpc.1
                 2555 ?        00:00:08 io.node-red.0
                 6990 ?        00:00:21 io.admin.1
                Das adminUI ist unter Pi2:8090 errechbar
                • derAuge
                  Es sind nun beide Instanzen installiert
                  der admin.0 läuft nicht
                  nach Konfigurieren von :
                  nach
                  wird admin.0 zwar gestartet, jadoch ist die Oberfläche nicht erreichbar (Kreisel)
                    Es heißt, dass Port ist belegt und eine Instanz immer noch läuft und will nicht runtergehen. Das sollte vorbei sein, wenn man komplett reboot macht. Um zu prüfen ob ich recht habe, kann man:
                    netstat -n -a | grep 8081
                    ausführen und schauen, ob was da ist.
                    • derAuge
                      😉 Und täglich grüßt das Murmeltier 😉
                      root@pi2:/mnt/ioBroker/iobroker.Pi2# init 6
                      Nach neustart des Pi2
                          Startion ioBroker
                          module.js:340
                              throw err;
                              at node.js:935:3
                      Zur Zeit wird das NAS geprüft. dort liegt die Installation und wird vom Pi2 gemountet.
                      • derAuge
                        Das NAS-System ist sauber.
                        Nun stehe ich vor der Frage: Wie kann ich herausfinden wo das Problem liegt?
                        Kann ich irgend welche prüfroutinen einbauen um festzustellen warun dort etwas "zerschossen" wird?
                          Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert.
                          • derAuge
                            @Bluefox:
                            Alle erste, muss du gesamte Installation zu Rpi2 holen. Und beobachten ob das Problem sich reproduziert. `
                            OK
                            da brauche ich aber dann etwas mehr Zeit…. Werde es testen. 😉 So schnell geben wir ja nicht auf 😉
                            zur Info
                            nach einigen Updates folgendes im LOG:
                            iobroker	2015-03-26 20:18:45	info	exit 8
                            iobroker	2015-03-26 20:18:45	error	at Timer.listOnTimeout [as ontimeout] (timers.js:112:15)
                            iobroker	2015-03-26 20:18:45	error	at null._onTimeout (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/setup.js:1514:27)
                            iobroker	2015-03-26 20:18:45	error	at new ObjectsInMemServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:146:7)
                            iobroker	2015-03-26 20:18:45	error	at /mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:139:9
                            iobroker	2015-03-26 20:18:45	error	at _initWebServer (/mnt/ioBroker/iobroker.Pi2/node_modules/iobroker.js-controller/lib/objectsInMemServer.js:958:24)
                            iobroker	2015-03-26 20:18:45	error	at Server.listen (net.js:1139:5)
                            iobroker	2015-03-26 20:18:45	error	at listen (net.js:1065:10)
                            iobroker	2015-03-26 20:18:45	error	at Server._listen2 (net.js:1043:14)
                            iobroker	2015-03-26 20:18:45	error	Error: listen EADDRINUSE at errnoException (net.js:905:11)
                            iobroker	2015-03-26 20:18:45	error	throw er; // Unhandled 'error' event ^
                            iobroker	2015-03-26 20:18:45	error	events.js:72
                            iobroker	2015-03-26 20:18:36	info	upgrade hm-rega
                              Es läuft was auf dem System.
                              Neu starten (init 6)
                              • derAuge
                                @Bluefox:
                                Neu starten (init 6) `
                                ja,
                                ich hatte das System noch mal manuell gestartet.
                                Danach liefen die Adapter natürlich wieder.
                                Habe dann nach updates geschaut….
                                Gerade habe ich das "defekte" System auch noch mal (zum Test) manuell gestartet und die anstehenden Updates eingespielt.
                                  pix last edited by
                                  Halo,
                                  könnt Ihr mir bitte noch einmal erklären, wie das funktioniert! Ich habe leider wieder das Problem:
                                  2015-08-19 00:25:10.573  - info: host.Mini-Wohnzimmer.fritz.box ioBroker.js-controller version 0.7.8 js-controller starting
                                  2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box Copyright (c) 2014-2015 bluefox, hobbyquaker
                                  2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box hostname: Mini-Wohnzimmer.fritz.box
                                  2015-08-19 00:25:10.575  - info: host.Mini-Wohnzimmer.fritz.box ip addresses: XXXXXXXANONYMISIERTXXXXXX
                                  2015-08-19 00:25:12.389  - info: inMem-states listening on port 9000
                                  2015-08-19 00:25:12.801  - info: inMem-objects listening on port 9001
                                  2015-08-19 00:25:12.803  - info: host.Mini-Wohnzimmer.fritz.box InMemoryDB connected
                                  2015-08-19 00:25:12.818  - info: host.Mini-Wohnzimmer.fritz.box 33 instances found
                                  2015-08-19 00:25:12.819  - warn: host.Mini-Wohnzimmer.fritz.box does not start any instances on this host
                                  Der JS-Controler startet als einziger und dann bleibt es stehen. Ich habe bereits den obigen Weg probiert. Eine weitere Admin Instanz angeschmissen und sie läuft auch. Aber wie geht es dann weiter? amin.0 löschen hat nichts gebracht.
                                  Habe bereits über Timemachine ein altes Backup von heute Mittag genutzt. Leider kein Erfolg.
                                  ./iobroker update bringt das:
                                  ./iobroker update
                                  Cannot download json from https://raw.githubusercontent.com/ioBroker/ioBroker.js-controller/master/conf/adapter/example/io-package.json. Error: Not Found
                                  update done
                                  Adapter "zwave" : 0.1.0
                                  Adapter "yr" : 0.1.7 , installed 0.1.7
                                  Adapter "web" : 0.4.3 , installed 0.4.2 [Updateable]
                                  Adapter "vis-plumb" : 0.1.5
                                  Adapter "vis-metro" : 0.1.7 , installed 0.1.3 [Updateable]
                                  Adapter "vis-lcars" : 0.1.6 , installed 0.1.4 [Updateable]
                                  Adapter "vis-hqwidgets" : 0.1.0 , installed 0.1.0
                                  Adapter "vis-colorpicker": 0.1.0 , installed 0.1.0
                                  Adapter "vis-bars" : 0.0.3
                                  Adapter "vis" : 0.6.12 , installed 0.6.5 [Updateable]
                                  Adapter "sonos" : 0.1.6 , installed 0.1.6
                                  Adapter "rickshaw" : 0.2.2 , installed 0.2.2
                                  Adapter "pushover" : 0.1.1 , installed 0.1.1
                                  Adapter "pushbullet" : 0.0.6 , installed 0.0.6
                                  Adapter "owfs" : 0.0.2
                                  Adapter "onkyo" : 0.1.9
                                  Adapter "socketio" : 0.4.5
                                  Adapter "simple-api" : 0.1.1 , installed 0.1.1
                                  Adapter "scenes" : 0.1.2 , installed 0.0.2 [Updateable]
                                  Adapter "sayit" : 0.3.11 , installed 0.3.11
                                  Adapter "s7" : 0.1.8
                                  Adapter "ping" : 0.1.4
                                  Adapter "node-red" : 0.3.4 , installed 0.3.3 [Updateable]
                                  Adapter "mqtt" : 0.2.9 , installed 0.2.9
                                  Adapter "megad" : 0.1.1
                                  Adapter "knx" : 0.0.1
                                  Controller "js-controller" : 0.7.7 , installed 0.7.8
                                  Adapter "javascript" : 0.5.4 , installed 0.5.1 [Updateable]
                                  Adapter "icons-ultimate-png": 0.1.0 , installed 0.1.0
                                  Adapter "icons-open-icon-library-png": 0.1.1
                                  Adapter "icons-mfd-svg" : 0.1.0 , installed 0.1.0
                                  Adapter "icons-mfd-png" : 0.1.0 , installed 0.1.0
                                  Adapter "icons-material-svg": 0.1.0 , installed 0.1.0
                                  Adapter "icons-material-png": 0.1.0 , installed 0.1.0
                                  Adapter "icons-addictive-flavour-png": 0.1.0 , installed 0.1.0
                                  Adapter "ical" : 1.1.1 , installed 1.0.2 [Updateable]
                                  Adapter "hmm" : 0.1.1
                                  Adapter "hue" : 0.4.2
                                  Adapter "hm-rpc" : 0.5.2 , installed 0.5.2
                                  Adapter "hm-rega" : 0.2.2 , installed 0.2.2
                                  Adapter "history" : 0.1.3 , installed 0.1.3
                                  Adapter "harmony" : 0.5.1
                                  Adapter "fritzbox" : 0.2.1 , installed 0.2.1
                                  Adapter "flot" : 0.1.1 , installed 0.1.1
                                  Adapter "email" : 0.1.2
                                  Adapter "dwd" : 0.1.10 , installed 0.1.9 [Updateable]
                                  Adapter "cul" : 0.0.4
                                  Adapter "b-control-em" : 0.1.1
                                  Adapter "artnet" : 0.0.3
                                  Adapter "admin" : 0.5.8 , installed 0.5.7 [Updateable]
                                  Ich muss das System wohl erstmal ruhen lassen. :o
                                  Pix
                                    pix last edited by
                                    habe jetzt mit mühevoller Handarbeit alles wieder zum Laufen bekommen. Es lief ja auf einem mac mini mit OS X.
                                    Achtung! Die Einstellungen der Adapter gehen verloren (egal bei VIS oder Scenes), daher unbedingt vorher Screenshots der einzelnen Einstellungen machen (aufwendig bei ical, hm-rega, hm-rpc; bei Javascript und node-red ggf. an die zusätzlichen Module denken)
                                    <list type="decimal">4. Backup des Ordner iobroker/iobroker-data (waren über 5GB wegen History Daten)
                                    1. neuen Benutzer mit Adminrechten angelegt (alter Benutzer hatte sehr viele verwaiste Dateien)
                                    2. ./iobroker start startet nur den js-controller (siehe oben)
                                    3. ./iobroker del admin.0
                                    4. ./iobroker add admin –enabled --port 8081 (danach wieder Zugriff auf Admin im Browser)
                                    5. auf diese Weise jeden einzelnen Adapter erst gelöscht und dann neu angelegt und gestartet (Achtung: Bei Adaptern mit mehreren Instanzen müssen erst alle Instanzen gelöscht werden, damit die alte Reihenfolge 0,1,2,… wieder hergestellt wird)
                                    6. Alle History Einstellungen sind weg. Das heißt, die Objekte müssen einzeln wieder angewählt und die gewünschte History-Log-Einstellung getätigt werden (mühsam).
                                      Empfehlung: Erst hm-rp-Instanzen und dann hm-rega erneuern. Dann ggf. node-red und erst danach javascript, da viele Skripte auf die Daten aus der Homematic bzw. node-red zugreifen und sonst verrückt spielen, wenn die Objekte nicht mehr da sind.
                                    Vielleicht kann es jemand brauchen, notfalls sehe ich später selbst hier nach, wenn der Fehler wieder auftaucht.
                                    Pix
                                    2989
