    4. Js.controller 0.12.0
      takero78 last edited by
      ich habe ein manuelles upgrade durchgeführt, dies läuft auch durch nur bekomme ich die Fehlermeldung:
      Invalid version of js-controler. Required >=0.12.0
      Eine neuinstallattion des js.controllers installiert wieder nur den 0.11.0
      pi@raspberrypi:/opt/iobroker $ sudo npm install iobroker.js-controller@0.12.0
      npm ERR! Linux 4.4.9-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.js-controller@0.12.0"
      npm ERR! node v4.4.4
      npm ERR! npm  v2.15.1
      npm ERR! version not found: iobroker.js-controller@0.12.0
      npm ERR!
      npm ERR! If you need help, you may report this error at:
      npm ERR!     <https: github.com/npm/issues="">npm ERR! Please include the following file with any support request:
      npm ERR!     /opt/iobroker/npm-debug.log</https:>
      Wo finde ich bzw. wie installiere ich Version 0.12.0?
      Im Prinzip läuft alles, nur die History funktioniert nicht mehr, weder SQL-History noch History. . .
      Bitte um Hilfe!
      Nachtrag:
      SQL-History Fehlermeldung:
      sql-0	2016-09-01 17:13:22.754	error	TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
      sql-0	2016-09-01 17:14:52.807	error	TypeError: SQL[(clients[adapter.config.dbtype].name + "Pool")] is not a function
      TypeError:	2016-09-01 17:14:47.234	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
      TypeError:	2016-09-01 17:14:47.234	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-09-01 17:14:47.234	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2016-09-01 17:14:47.234	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2098:34)
      TypeError:	2016-09-01 17:14:47.234	error	at Adapter.emit (events.js:169:7)
      TypeError:	2016-09-01 17:14:47.234	error	at emitOne (events.js:77:13)
      TypeError:	2016-09-01 17:14:47.234	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:73:5)
      TypeError:	2016-09-01 17:14:47.234	error	at processMessage (/opt/iobroker/node_modules/iobroker.sql/main.js:429:9)
      TypeError:	2016-09-01 17:14:47.234	error	at getHistory (/opt/iobroker/node_modules/iobroker.sql/main.js:1008:16)
      TypeError:	2016-09-01 17:14:47.234	error	at getId (/opt/iobroker/node_modules/iobroker.sql/main.js:798:15)
      TypeError:	2016-09-01 17:14:47.234	error	Cannot read property 'borrow' of undefined
      message	2016-09-01 17:14:47.232	error	messagebox.system.adapter.sql.0 [object Object] Cannot read property 'borrow' of undefined
      TypeError:	2016-09-01 17:14:47.225	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
      TypeError:	2016-09-01 17:14:47.225	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-09-01 17:14:47.225	error	at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30)
      TypeError:	2016-09-01 17:14:47.225	error	at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2098:34)
      TypeError:	2016-09-01 17:14:47.225	error	at Adapter.emit (events.js:169:7)
      TypeError:	2016-09-01 17:14:47.225	error	at emitOne (events.js:77:13)
      TypeError:	2016-09-01 17:14:47.225	error	at Adapter. (/opt/iobroker/node_modules/iobroker.sql/main.js:73:5)
      TypeError:	2016-09-01 17:14:47.225	error	at processMessage (/opt/iobroker/node_modules/iobroker.sql/main.js:429:9)
      TypeError:	2016-09-01 17:14:47.225	error	at getHistory (/opt/iobroker/node_modules/iobroker.sql/main.js:1008:16)
      TypeError:	2016-09-01 17:14:47.225	error	at getId (/opt/iobroker/node_modules/iobroker.sql/main.js:798:15)
      TypeError:	2016-09-01 17:14:47.225	error	Cannot read property 'borrow' of undefined
      message	2016-09-01 17:14:47.206	error	messagebox.system.adapter.sql.0 [object Object] Cannot read property 'borrow' of undefined
        Haus last edited by
        @takero78:
        npm ERR!
        Wo finde ich bzw. wie installiere ich Version 0.12.0? `
        cd /opt/iobroker
        iobroker stop
        npm install https://github.com/ioBroker/ioBroker.js-controller/tarball/master --production
        iobroker restart
          Danke, das war es!
            rascal last edited by
            ich habe sie über die Weboberfläche vom github installiert
