    4. SQL Adapter starte nicht mehr
    SOLVED SQL Adapter starte nicht mehr
    • heinhan
      heinhan last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: PI 4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Debian
      Node-Version: 12.16.3
      Nodejs-Version: 12.16.3
      NPM-Version: 6.14.4
      Seit heute läuft der SQL-Adapter auf meinem IoBroker nicht mehr . Hier die LOG Meldung dazu:
      host.raspberrypi 2020-05-01 11:42:41.596 info Restart adapter system.adapter.sql.0 because enabled
      host.raspberrypi 2020-05-01 11:42:41.596 error instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi 2020-05-01 11:42:41.595 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
      host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
      host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
      host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
      host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
      host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
      host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
      host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: was compiled against a different Node.js version using
      host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
      host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: ^
      host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
      host.raspberrypi 2020-05-01 11:42:41.589 error Caught by controller[0]: internal/modules/cjs/loader.js:1183
      Über Windwos (HeidiSQL) läuft alles wie gewohnt.
      Wenn es an dem Fehler liegt NODE_MODULE_VERSION 72 , wie kann ich den aktualisieren, npm install ergibt folgendes Ergebnis:
      pi@raspberrypi:~ $ npm -v
      6.14.4
      pi@raspberrypi:~ $ sudo npm install
      npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm WARN pi No description
      npm WARN pi No repository field.
      npm WARN pi No README data
      npm WARN pi No license field.
      up to date in 1.072s
      found 0 vulnerabilities
      • Glasfaser
        Glasfaser @heinhan last edited by
        @heinhan
        Den Log bitte in Code Tags </> setzen !
        Nach einem Update von Node..... 😎
        cd /opt/iobroker
        npm rebuild
        heinhan 1 Reply Last reply Reply Quote 0
        • Glasfaser
          @heinhan
          cd /opt/iobroker
          npm rebuild
          • heinhan
            heinhan @Glasfaser last edited by
            @Glasfaser Danke, Fehler behoben. Werde zukünftig den Code einbetten
            • Glasfaser
              @heinhan sagte in SQL Adapter starte nicht mehr:
              Fehler behoben.
              Dann setze den Thread auf gelöst !
              sql-adapter
