    3. Entwicklung
    4. (gelöst) ble Adapter crashed nach Update auf node.js V12
      Marty56 last edited by Marty56
      Das Update auf node.js V12 hat im Großen und Ganz geklappt. Nur der BLE- Adapter will nicht.
      ble.0	2020-05-03 22:24:56.307	error	the module (for instance, using `npm rebuild` or `npm install`).
      ble.0	2020-05-03 22:24:56.307	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      ble.0	2020-05-03 22:24:56.307	error	NODE_MODULE_VERSION 64. This version of Node.js requires
      ble.0	2020-05-03 22:24:56.307	error	was compiled against a different Node.js version using
      ble.0	2020-05-03 22:24:56.307	error	(5352) unhandled promise rejection: Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
      ble.0	2020-05-03 22:24:56.300	error	at Function.Module._load (internal/modules/cjs/loader.js:877:14)
      ble.0	2020-05-03 22:24:56.300	error	at Module.load (internal/modules/cjs/loader.js:977:32)
      ble.0	2020-05-03 22:24:56.300	error	at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
      ble.0	2020-05-03 22:24:56.300	error	at Module._compile (internal/modules/cjs/loader.js:1133:30)
      ble.0	2020-05-03 22:24:56.300	error	at Object.<anonymous> (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/native.js:6:15)
      ble.0	2020-05-03 22:24:56.300	error	at require (internal/modules/cjs/helpers.js:77:18)
      ble.0	2020-05-03 22:24:56.300	error	at Module.require (internal/modules/cjs/loader.js:1019:19)
      ble.0	2020-05-03 22:24:56.300	error	at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
      ble.0	2020-05-03 22:24:56.300	error	the module (for instance, using `npm rebuild` or `npm install`).
      ble.0	2020-05-03 22:24:56.300	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      ble.0	2020-05-03 22:24:56.300	error	NODE_MODULE_VERSION 64. This version of Node.js requires
      ble.0	2020-05-03 22:24:56.300	error	was compiled against a different Node.js version using
      ble.0	2020-05-03 22:24:56.300	error	(5352) Error: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
      ble.0	2020-05-03 22:24:56.291	error	the module (for instance, using `npm rebuild` or `npm install`).
      ble.0	2020-05-03 22:24:56.291	error	NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
      ble.0	2020-05-03 22:24:56.291	error	NODE_MODULE_VERSION 64. This version of Node.js requires
      ble.0	2020-05-03 22:24:56.291	error	was compiled against a different Node.js version using
      ble.0	2020-05-03 22:24:56.291	error	(5352) uncaught exception: The module '/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node'
      Gibt es hier schon eine Lösung?
        Thomas Braun Most Active @Marty56 last edited by Thomas Braun
        @Marty56
        iobroker rebuild ble --install
          @Thomas-Braun sagte in ble Adapter crashed nach Update auf node.js V12:
          Das ging schnell. Danke.
          Muss ich dazu ins iobroker Verzeichnis wechseln?
            @Marty56
            Ja, mach dich mal auf zu /opt/iobroker
            Und bitte auch daran denken, die setcapabilities zu aktualisieren:
            sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
            Muss ich jedenfalls immer machen, wenn die node-Version sich ändert.
              iobroker
              Hat geklappt! Vielen Dank!!
              Das mit den capabilities war bei mir nicht notwendig.
              ble adapter
