    4. [gelöst] Zigbee: uncaught exception: Timeout
    UNSOLVED [gelöst] Zigbee: uncaught exception: Timeout
      Kueppert last edited by Kueppert
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 3GB
      Festplattenart: SSD
      Betriebssystem: Debian
      Node-Version: 13.12.0 => nun 12.16.3
      Nodejs-Version: 13.12.0 => nun 12.16.3
      NPM-Version: 6.14.4
      Installationsart: Skript
      Image genutzt: Nein
      Hallo @arteck und @Asgothian
      ich habe die letzte Zeit (nach diversen Updates von JS-Controller/Admin) vermehrt Probleme mit dem Zigbee-Adapter 😕
      Heute startete er sich bereits 2mal neu mit folgenden Meldungen im Log:
      host.ioBroker2	2020-05-04 10:44:58.806	info	instance system.adapter.zigbee.0 started with pid 11939
      host.ioBroker2	2020-05-04 10:44:28.780	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.ioBroker2	2020-05-04 10:44:28.777	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      zigbee.0	2020-05-04 10:44:28.251	info	(8301) Terminated (NO_ERROR): Without reason
      zigbee.0	2020-05-04 10:44:28.250	info	(8301) terminating
      zigbee.0	2020-05-04 10:44:28.232	error	at rejected (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:6:65)
      zigbee.0	2020-05-04 10:44:28.232	error	at Generator.throw (<anonymous>)
      zigbee.0	2020-05-04 10:44:28.232	error	at Endpoint.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/controller/model/endpoint.js:349:23)
      zigbee.0	2020-05-04 10:44:28.232	error	(8301) Error on send command to 0x84182600000e06c0. Error: Error: Command 0x84182600000e06c0/3 genLevelCtrl.moveToLevelWithOnOff({"level":127,"transtime":0}, {"timeout":10000,"manufacturerCode":null,
      zigbee.0	2020-05-04 10:44:27.969	info	(8301) Zigbee: disabling joining new devices.
      zigbee.0	2020-05-04 10:44:27.968	info	(8301) cleaned everything up...
      zigbee.0	2020-05-04 10:44:27.967	error	at processTimers (internal/timers.js:492:7)
      zigbee.0	2020-05-04 10:44:27.967	error	at listOnTimeout (internal/timers.js:549:17)
      zigbee.0	2020-05-04 10:44:27.967	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
      zigbee.0	2020-05-04 10:44:27.967	error	(8301) Error: Timeout - 45454 - 3 - 2 - 8 - 11 after 10000ms
      zigbee.0	2020-05-04 10:44:27.967	error	(8301) uncaught exception: Timeout - 45454 - 3 - 2 - 8 - 11 after 10000ms
      host.ioBroker2	2020-05-04 10:30:00.036	info	instance system.adapter.daswetter.0 started with pid 26350
      host.ioBroker2	2020-05-04 10:29:47.955	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.ioBroker2	2020-05-04 10:29:47.954	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      host.ioBroker2	2020-05-04 10:29:47.954	error	Caught by controller[0]: (node:19909) PromiseRejectionHandledWarning: Promise rejection was handled asynchronously (rejection id: 1)
      zigbee.0	2020-05-04 10:29:47.434	info	(19909) Terminated (NO_ERROR): Without reason
      zigbee.0	2020-05-04 10:29:47.433	info	(19909) terminating
      zigbee.0	2020-05-04 10:29:46.928	info	(19909) Zigbee: disabling joining new devices.
      zigbee.0	2020-05-04 10:29:46.927	info	(19909) cleaned everything up...
      zigbee.0	2020-05-04 10:29:46.926	error	at processTimers (internal/timers.js:492:7)
      zigbee.0	2020-05-04 10:29:46.926	error	at listOnTimeout (internal/timers.js:549:17)
      zigbee.0	2020-05-04 10:29:46.926	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
      zigbee.0	2020-05-04 10:29:46.926	error	(19909) Error: Timeout - 30525 - 3 - 2 - 0 - 1 after 10000ms
      zigbee.0	2020-05-04 10:29:46.925	error	(19909) uncaught exception: Timeout - 30525 - 3 - 2 - 0 - 1 after 10000ms
      host.ioBroker2	2020-05-04 10:01:18.365	info	Restart adapter system.adapter.zigbee.0 because enabled
      host.ioBroker2	2020-05-04 10:01:18.362	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      zigbee.0	2020-05-04 10:01:17.843	info	(29900) terminating
      zigbee.0	2020-05-04 10:01:17.828	info	(29900) Terminated (NO_ERROR): Without reason
      zigbee.0	2020-05-04 10:01:17.826	info	(29900) terminating
      zigbee.0	2020-05-04 10:01:17.139	info	(29900) Zigbee: disabling joining new devices.
      zigbee.0	2020-05-04 10:01:17.137	info	(29900) cleaned everything up...
      zigbee.0	2020-05-04 10:01:17.137	error	at processTimers (internal/timers.js:492:7)
      zigbee.0	2020-05-04 10:01:17.137	error	at listOnTimeout (internal/timers.js:549:17)
      zigbee.0	2020-05-04 10:01:17.137	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
      zigbee.0	2020-05-04 10:01:17.137	error	(29900) Error: Timeout - 45454 - 3 - 75 - 0 - 1 after 10000ms
      zigbee.0	2020-05-04 10:01:17.135	error	(29900) uncaught exception: Timeout - 45454 - 3 - 75 - 0 - 1 after 10000ms
      Ist das etwas, dass man hier diskutieren könnte? Oder soll ich diese Meldungen im GIT posten? Ich hatte nach dem Umstieg auf den neuen Stick auch immer eine schöne Netzwerk-Karte. Jetzt auch nicht mehr - die ganzen Geräte, die mit Batterie betrieben werden, stehen auch nach 1 Tag noch auf rot - auch wenn sie ein Signal (geöffnet/geschlossen senden).
      Zigbee-Adapter: v1.1.1
      JS-Controller: v3.0.20
      Node js: v13.12.0
      2.Frage:
      ich habe eine Frage zum sbl-Tool. Ist es damit möglich, via USB meinen CC2538 + CC2592 zu flashen ohne dass ich den J-Link benötige? J-Link hab ich da, möchte nur am Stick die Pins nicht drauf löten ^^
      Hab dazu bei Koenkk auf Git einen EIntrag gefunden: Reflash firmware without CCDebugger/Arduino
      Danke euch und vG, Thorsten
        dimaiv @Kueppert last edited by dimaiv
        @Kueppert
        1. Warum hast du deine Logs abgeschnitten?
        2. Bringe dein System in Ordnung ! Node js !
        3. Nein, sbl-Tool kannst du nicht benutzen.
        4. Du muss deinen Stick nicht unbeding Updaten. (wenn du es unbedingt machen möchtest, kannst immer noch zu mir schicken)
        K 2 Replies Last reply Reply Quote 0
          Kueppert @dimaiv last edited by Kueppert
          @dimaiv
          1. hab hier mal ein file mit angehangen. Copy-Paste war zu lang für das Forum: Log_04.05.2020.txt
          2. alles klar, dann geh ich erst mal auf die v12 von Node zurück. Hatte ich installiert im Zusammenhang mit dem neuen JS-Controller und um zu schauen, ob Fehler auftreten.
            @dimaiv bin auf node v12 gegangen, rebuild vom Adapter hat der JS-Controller selbst übernommen. Habe leider immer noch das Problem, dass der Adapter sich verabschiedet 😞
            host.ioBroker2	2020-05-04 11:39:08.604	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.ioBroker2	2020-05-04 11:39:08.603	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
            zigbee.0	2020-05-04 11:39:08.076	info	(15976) Terminated (NO_ERROR): Without reason
            zigbee.0	2020-05-04 11:39:08.075	info	(15976) terminating
            zigbee.0	2020-05-04 11:39:07.990	error	(15976) Error on send command to 0x0017880102b1973c. Error: Error: Command 0x0017880102b1973c/11 genLevelCtrl.moveToLevelWithOnOff({"level":76,"transtime":0}, {"timeout":10000,"manufacturerCode":null,
            zigbee.0	2020-05-04 11:39:07.752	info	(15976) Zigbee: disabling joining new devices.
            zigbee.0	2020-05-04 11:39:07.751	info	(15976) cleaned everything up...
            zigbee.0	2020-05-04 11:39:07.750	error	(15976) Error: Timeout - 102 - 11 - 6 - 8 - 11 after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at lis
            zigbee.0	2020-05-04 11:39:07.748	error	(15976) uncaught exception: Timeout - 102 - 11 - 6 - 8 - 11 after 10000ms
            zigbee.0	2020-05-04 11:38:07.794	error	(15976) Error on send command to 0x8418260000000712. Error: Error: Command 0x8418260000000712/3 genOnOff.off({}, {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error
            nut.0	2020-05-04 11:36:37.543	info	(580) All Nut values set
            nut.0	2020-05-04 11:36:37.503	info	(580) Start NUT update
            zigbee.0	2020-05-04 11:35:48.601	error	(15976) Error on send command to 0x0017880102b1973c. Error: Error: Command 0x0017880102b1973c/11 genLevelCtrl.moveToLevelWithOnOff({"level":76,"transtime":0}, {"timeout":10000,"manufacturerCode":null,
            zigbee.0	2020-05-04 11:35:44.713	error	(15976) Error on send command to 0x0017880102b1973c. Error: Error: Command 0x0017880102b1973c/11 genLevelCtrl.moveToLevelWithOnOff({"level":76,"transtime":0}, {"timeout":10000,"manufacturerCode":null,
            javascript.0	2020-05-04 11:35:30.332	info	(460) script.js.common.Sonstiges.Status_TürenFenster-TextSkript: TürenFenster_getriggert
            zigbee.0	2020-05-04 11:35:01.455	info	(15976) Zigbee started
            zigbee.0	2020-05-04 11:35:01.455	info	(15976) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
            zigbee.0	2020-05-04 11:35:01.454	info	(15976) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:35:01.453	info	(15976) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
            zigbee.0	2020-05-04 11:35:01.452	info	(15976) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
            zigbee.0	2020-05-04 11:35:01.452	info	(15976) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
            zigbee.0	2020-05-04 11:35:01.451	info	(15976) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.450	info	(15976) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.449	info	(15976) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:35:01.448	info	(15976) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
            zigbee.0	2020-05-04 11:35:01.440	info	(15976) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.439	info	(15976) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
            zigbee.0	2020-05-04 11:35:01.439	info	(15976) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.438	info	(15976) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.437	info	(15976) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.436	info	(15976) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.435	info	(15976) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.434	info	(15976) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.433	info	(15976) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.433	info	(15976) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.432	info	(15976) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:35:01.431	info	(15976) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:35:01.430	info	(15976) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.429	info	(15976) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.428	info	(15976) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
            zigbee.0	2020-05-04 11:35:01.419	info	(15976) Currently 24 devices are joined:
            zigbee.0	2020-05-04 11:35:01.409	info	(15976) --> transmitPower : normal
            zigbee.0	2020-05-04 11:35:01.408	info	(15976) Unable to disable LED, unsupported function.
            zigbee.0	2020-05-04 11:34:55.401	info	(15976) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
            zigbee.0	2020-05-04 11:34:54.083	info	(15976) Starting Zigbee...
            zigbee.0	2020-05-04 11:34:54.057	info	(15976) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
            host.ioBroker2	2020-05-04 11:34:52.089	info	instance system.adapter.zigbee.0 started with pid 15976
            host.ioBroker2	2020-05-04 11:34:22.069	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.ioBroker2	2020-05-04 11:34:22.068	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
            zigbee.0	2020-05-04 11:34:21.546	info	(7677) Terminated (NO_ERROR): Without reason
            zigbee.0	2020-05-04 11:34:21.545	info	(7677) terminating
            zigbee.0	2020-05-04 11:34:21.495	error	(7677) Error on send command to 0x0017880102b1973c. Error: Error: Command 0x0017880102b1973c/11 genOnOff.off({}, {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error
            zigbee.0	2020-05-04 11:34:21.251	info	(7677) Zigbee: disabling joining new devices.
            zigbee.0	2020-05-04 11:34:21.250	info	(7677) cleaned everything up...
            zigbee.0	2020-05-04 11:34:21.250	error	(7677) Error: Timeout - 102 - 11 - 9 - 6 - 11 after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at list
            zigbee.0	2020-05-04 11:34:21.249	error	(7677) uncaught exception: Timeout - 102 - 11 - 9 - 6 - 11 after 10000ms
            host.ioBroker2	2020-05-04 11:30:04.057	info	instance system.adapter.ical.0 started with pid 10358
            host.ioBroker2	2020-05-04 11:30:02.698	info	instance system.adapter.daswetter.0 terminated with code 0 (NO_ERROR)
            daswetter.0	2020-05-04 11:30:02.182	info	(10336) Terminated (NO_ERROR): Without reason
            daswetter.0	2020-05-04 11:30:01.605	info	(10336) starting. Version 2.8.1 in /opt/iobroker/node_modules/iobroker.daswetter, node: v12.16.3, js-controller: 3.0.20
            host.ioBroker2	2020-05-04 11:30:00.043	info	instance system.adapter.daswetter.0 started with pid 10336
            zigbee.0	2020-05-04 11:27:56.272	info	(7677) Zigbee started
            zigbee.0	2020-05-04 11:27:56.271	info	(7677) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
            zigbee.0	2020-05-04 11:27:56.270	info	(7677) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:27:56.269	info	(7677) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
            zigbee.0	2020-05-04 11:27:56.268	info	(7677) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
            zigbee.0	2020-05-04 11:27:56.268	info	(7677) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
            zigbee.0	2020-05-04 11:27:56.267	info	(7677) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.266	info	(7677) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.265	info	(7677) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:27:56.264	info	(7677) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
            zigbee.0	2020-05-04 11:27:56.263	info	(7677) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.262	info	(7677) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
            zigbee.0	2020-05-04 11:27:56.261	info	(7677) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.260	info	(7677) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.259	info	(7677) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.258	info	(7677) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.256	info	(7677) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.255	info	(7677) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.254	info	(7677) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.250	info	(7677) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.248	info	(7677) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:27:56.247	info	(7677) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:27:56.246	info	(7677) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.245	info	(7677) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.244	info	(7677) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
            zigbee.0	2020-05-04 11:27:56.229	info	(7677) Currently 24 devices are joined:
            zigbee.0	2020-05-04 11:27:56.217	info	(7677) --> transmitPower : normal
            zigbee.0	2020-05-04 11:27:56.216	info	(7677) Unable to disable LED, unsupported function.
            zigbee.0	2020-05-04 11:27:50.209	info	(7677) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
            zigbee.0	2020-05-04 11:27:48.896	info	(7677) Starting Zigbee...
            zigbee.0	2020-05-04 11:27:48.869	info	(7677) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
            host.ioBroker2	2020-05-04 11:27:47.085	info	instance system.adapter.zigbee.0 started with pid 7677
            host.ioBroker2	2020-05-04 11:27:17.058	info	Restart adapter system.adapter.zigbee.0 because enabled
            host.ioBroker2	2020-05-04 11:27:17.055	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
            zigbee.0	2020-05-04 11:27:16.532	info	(4517) Terminated (NO_ERROR): Without reason
            zigbee.0	2020-05-04 11:27:16.531	info	(4517) terminating
            zigbee.0	2020-05-04 11:27:16.264	info	(4517) Zigbee: disabling joining new devices.
            zigbee.0	2020-05-04 11:27:16.262	info	(4517) cleaned everything up...
            zigbee.0	2020-05-04 11:27:16.262	error	at processTimers (internal/timers.js:492:7)
            zigbee.0	2020-05-04 11:27:16.262	error	at listOnTimeout (internal/timers.js:549:17)
            zigbee.0	2020-05-04 11:27:16.262	error	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
            zigbee.0	2020-05-04 11:27:16.262	error	(4517) Error: Timeout - 102 - 11 - 3 - 8 - 11 after 10000ms
            zigbee.0	2020-05-04 11:27:16.261	error	(4517) uncaught exception: Timeout - 102 - 11 - 3 - 8 - 11 after 10000ms
            javascript.0	2020-05-04 11:27:09.407	info	(460) script.js.common.Sonstiges.Status_TürenFenster-TextSkript: TürenFenster_getriggert
            nut.0	2020-05-04 11:26:37.525	info	(580) All Nut values set
            nut.0	2020-05-04 11:26:37.490	info	(580) Start NUT update
            zigbee.0	2020-05-04 11:25:18.670	info	(4517) Zigbee started
            zigbee.0	2020-05-04 11:25:18.670	info	(4517) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
            zigbee.0	2020-05-04 11:25:18.669	info	(4517) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:25:18.668	info	(4517) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
            zigbee.0	2020-05-04 11:25:18.667	info	(4517) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
            zigbee.0	2020-05-04 11:25:18.666	info	(4517) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
            zigbee.0	2020-05-04 11:25:18.665	info	(4517) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.664	info	(4517) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.662	info	(4517) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
            zigbee.0	2020-05-04 11:25:18.661	info	(4517) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
            zigbee.0	2020-05-04 11:25:18.660	info	(4517) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.659	info	(4517) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
            zigbee.0	2020-05-04 11:25:18.659	info	(4517) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.658	info	(4517) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.657	info	(4517) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.656	info	(4517) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.655	info	(4517) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.654	info	(4517) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.653	info	(4517) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.652	info	(4517) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.652	info	(4517) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:25:18.651	info	(4517) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
            zigbee.0	2020-05-04 11:25:18.649	info	(4517) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.648	info	(4517) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.647	info	(4517) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
            zigbee.0	2020-05-04 11:25:18.637	info	(4517) Currently 24 devices are joined:
            zigbee.0	2020-05-04 11:25:18.622	info	(4517) --> transmitPower : normal
            zigbee.0	2020-05-04 11:25:18.621	info	(4517) Unable to disable LED, unsupported function.
            zigbee.0	2020-05-04 11:25:12.616	info	(4517) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
            zigbee.0	2020-05-04 11:25:09.622	info	(4517) Starting Zigbee...
            zigbee.0	2020-05-04 11:25:09.597	info	(4517) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
            host.ioBroker2	2020-05-04 11:25:07.758	info	instance system.adapter.zigbee.0 started with pid 4517
              weiteres Testing: Adapter deinstalliert und neu installiert im Admin. Mal schauen...
                Kueppert @Kueppert last edited by
                Schade,
                leider kein Erfolg 😞
                @dimaiv @arteck @Asgothian ggf. eine Idee, was ich unternehmen/ausprobieren sollte? Danke euch.
                VG Thorsten
                nut.0	2020-05-04 12:06:37.549	info	(580) All Nut values set
                nut.0	2020-05-04 12:06:37.512	info	(580) Start NUT update
                zigbee.0	2020-05-04 12:06:10.139	info	(20768) Zigbee started
                zigbee.0	2020-05-04 12:06:10.139	info	(20768) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
                zigbee.0	2020-05-04 12:06:10.138	info	(20768) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
                zigbee.0	2020-05-04 12:06:10.137	info	(20768) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                zigbee.0	2020-05-04 12:06:10.136	info	(20768) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                zigbee.0	2020-05-04 12:06:10.136	info	(20768) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                zigbee.0	2020-05-04 12:06:10.135	info	(20768) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.134	info	(20768) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.133	info	(20768) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
                zigbee.0	2020-05-04 12:06:10.124	info	(20768) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
                zigbee.0	2020-05-04 12:06:10.123	info	(20768) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.122	info	(20768) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                zigbee.0	2020-05-04 12:06:10.122	info	(20768) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.121	info	(20768) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.120	info	(20768) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.119	info	(20768) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.118	info	(20768) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.117	info	(20768) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.116	info	(20768) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.115	info	(20768) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.114	info	(20768) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
                zigbee.0	2020-05-04 12:06:10.113	info	(20768) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
                zigbee.0	2020-05-04 12:06:10.112	info	(20768) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.110	info	(20768) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.109	info	(20768) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                zigbee.0	2020-05-04 12:06:10.097	info	(20768) Currently 24 devices are joined:
                zigbee.0	2020-05-04 12:06:10.074	info	(20768) --> transmitPower : normal
                zigbee.0	2020-05-04 12:06:10.073	info	(20768) Unable to disable LED, unsupported function.
                zigbee.0	2020-05-04 12:06:04.065	info	(20768) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
                zigbee.0	2020-05-04 12:06:02.724	info	(20768) Starting Zigbee...
                zigbee.0	2020-05-04 12:06:02.701	info	(20768) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
                host.ioBroker2	2020-05-04 12:06:00.710	info	instance system.adapter.zigbee.0 started with pid 20768
                host.ioBroker2	2020-05-04 12:05:30.680	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.ioBroker2	2020-05-04 12:05:30.676	info	instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
                zigbee.0	2020-05-04 12:05:30.151	info	(13898) Terminated (NO_ERROR): Without reason
                zigbee.0	2020-05-04 12:05:30.150	info	(13898) terminating
                zigbee.0	2020-05-04 12:05:29.648	info	(13898) Zigbee: disabling joining new devices.
                zigbee.0	2020-05-04 12:05:29.647	info	(13898) cleaned everything up...
                zigbee.0	2020-05-04 12:05:29.646	error	(13898) Error: Timeout - 1681 - 3 - 3 - 0 - 1 after 10000ms at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24) at list
                zigbee.0	2020-05-04 12:05:29.645	error	(13898) uncaught exception: Timeout - 1681 - 3 - 3 - 0 - 1 after 10000ms
                nut.0	2020-05-04 12:01:37.561	info	(580) All Nut values set
                nut.0	2020-05-04 12:01:37.510	info	(580) Start NUT update
                sql.0	2020-05-04 12:00:20.293	info	(746) disabled logging of zigbee.0.00158d000273d4a7.humidity
                sql.0	2020-05-04 12:00:20.291	info	(746) disabled logging of zigbee.0.00158d000273d4a7.temperature
                sql.0	2020-05-04 12:00:20.173	info	(746) disabled logging of zigbee.0.00158d0002720c7a.humidity
                sql.0	2020-05-04 12:00:20.170	info	(746) disabled logging of zigbee.0.00158d0002720c7a.temperature
                zigbee.0	2020-05-04 12:00:19.694	info	(13898) Zigbee started
                zigbee.0	2020-05-04 12:00:19.694	info	(13898) 0x0017880102b1973c (addr 102): 8718696449691 - Philips Hue White Single bulb B22 (Router)
                zigbee.0	2020-05-04 12:00:19.693	info	(13898) 0x7cb03eaa00b0ac01 (addr 5529): AB3257001NJ - OSRAM Smart+ plug (Router)
                zigbee.0	2020-05-04 12:00:19.692	info	(13898) 0x000d6f000edc34f1 (addr 56412): AC0251100NJ/AC0251700NJ - OSRAM Smart+ switch mini (EndDevice)
                zigbee.0	2020-05-04 12:00:19.691	info	(13898) 0x84182600000e06c0 (addr 45454): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                zigbee.0	2020-05-04 12:00:19.690	info	(13898) 0x00158d00027910c9 (addr 29791): MFKZQ01LM - Xiaomi Mi/Aqara smart home cube (EndDevice)
                zigbee.0	2020-05-04 12:00:19.689	info	(13898) 0x00158d000273d4a7 (addr 1854): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.688	info	(13898) 0x00158d0001bc1889 (addr 496): SJCGQ11LM - Xiaomi Aqara water leak sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.687	info	(13898) 0x84182600000d1c8c (addr 42681): AB3257001NJ - OSRAM Smart+ plug (Router)
                zigbee.0	2020-05-04 12:00:19.677	info	(13898) 0x00158d0001c9c771 (addr 23637): RB 185 C - Innr E27 bulb RGBW (Router)
                zigbee.0	2020-05-04 12:00:19.675	info	(13898) 0x00158d0001ab5af4 (addr 64368): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.675	info	(13898) 0x00158d0001bf57e5 (addr 6590): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
                zigbee.0	2020-05-04 12:00:19.674	info	(13898) 0x00158d000273bbe5 (addr 35598): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.673	info	(13898) 0x00158d00034681c3 (addr 64632): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.672	info	(13898) 0x00158d0002720c7a (addr 41822): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.671	info	(13898) 0x00158d000278952b (addr 36874): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.670	info	(13898) 0x00158d00019db26a (addr 38001): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.669	info	(13898) 0x00158d000273bb68 (addr 48606): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.668	info	(13898) 0x00158d00024e600d (addr 15675): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.668	info	(13898) 0x00158d00019f4fbf (addr 39484): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.667	info	(13898) 0x8418260000000712 (addr 1681): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
                zigbee.0	2020-05-04 12:00:19.666	info	(13898) 0x8418260000dad4e7 (addr 30525): AA68199 - OSRAM LIGHTIFY LED PAR16 50 GU10 tunable white (Router)
                zigbee.0	2020-05-04 12:00:19.665	info	(13898) 0x00158d00029c0083 (addr 45921): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.663	info	(13898) 0x00158d000276e2e2 (addr 58395): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.662	info	(13898) 0x00158d0001db1e9f (addr 23168): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
                zigbee.0	2020-05-04 12:00:19.653	info	(13898) Currently 24 devices are joined:
                zigbee.0	2020-05-04 12:00:19.628	info	(13898) --> transmitPower : normal
                zigbee.0	2020-05-04 12:00:19.627	info	(13898) Unable to disable LED, unsupported function.
                host.ioBroker2	2020-05-04 12:00:14.309	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
                ical.0	2020-05-04 12:00:13.793	info	(13734) Terminated (NO_ERROR): Without reason
                zigbee.0	2020-05-04 12:00:13.623	info	(13898) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20190523}}
                zigbee.0	2020-05-04 12:00:12.271	info	(13898) Starting Zigbee...
                zigbee.0	2020-05-04 12:00:12.233	info	(13898) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
                host.ioBroker2	2020-05-04 12:00:09.712	info	instance system.adapter.zigbee.0 started with pid 13898
                • MichMein
                  MichMein last edited by MichMein
                  ich hänge mich mal hier mit ran. Ich habe die Tage in meinem Log ebenfalls gesehen das sich der Zigbee Adapter neugestartet hatte, das ganze habe ich jetzt zwei oder drei mal gehabt.
                  Hier die Zeilen aus den "Log-Tab":
                  zigbee.0 	2020-05-03 14:28:39.489 	error 	at processTimers (internal/timers.js:492:7)
                  zigbee.0 	2020-05-03 14:28:39.489 	error 	at listOnTimeout (internal/timers.js:549:17)
                  zigbee.0 	2020-05-03 14:28:39.489 	error 	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.zigbee/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
                  zigbee.0 	2020-05-03 14:28:39.489 	error 	(12788) Error: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
                  zigbee.0 	2020-05-03 14:28:39.469 	error 	(12788) uncaught exception: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
                  Und hier die Zeilen aus der Log-Datei:
                  2020-05-03 14:28:39.469 - error: zigbee.0 (12788) uncaught exception: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
                  2020-05-03 14:28:39.489 - error: zigbee.0 (12788) Error: Timeout - 62092 - 3 - 192 - 0 - 1 after 10000ms
                  Installierte Adapter-Version: 1.1.1
                  Node.js: 12.16.3
                  Vielen Dank
                  Michael
                  EDIT: Grundsätzlich funktioniert alles so wie es soll (das glaube ich zumindestens), bis auf das selbstständige neustarten.
                    Kueppert @MichMein last edited by
                    @MichMein 3mal in 2-3 Tagen geht ja, aber ich hab das alle 5-15 Minuten ^^
                    MichMein D 2 Replies Last reply Reply Quote 0
                    • MichMein
                      MichMein @Kueppert last edited by
                      @Kueppert Das glaube ich wohl 😞 Allerdings habe ich auch zur Zeit nur 5 Geräte angelernt, vielleicht hängt es auch damit zusammen 🙄
                        @Kueppert
                        Laut log, startet dein Zigbee Stick sauber, und wird richtig erkannt.
                        ! Der Stick funktioniert!
                        Dein IoBroker spielt verrückt. Wo der Fehler genau liegt kann ich dir noch nicht sagen.
                        • Garfonso
                          Garfonso Developer last edited by
                          Da wird irgendeine Timeout exception tief in Herdsman nicht abgefangen (bzw. die Promise-Rejection nicht behandelt). js-controller 3.0 macht das zu fatalen Fehlern und killt damit den Adapter. Könnte auch ein Problem in Herdsman sein.
                          MichMein 1 Reply Last reply Reply Quote 0
                          • MichMein
                            MichMein @Garfonso last edited by
                            @Garfonso das klingt gut, hilft mir aber leider nicht 😢 Gibt es seitens der Entwickler da ne Chance auf Fehlerbehebung?
                            Ich habe gerade mal geschaut, heute wurde der Adapter drei mal neu gestartet.
                            Garfonso K 2 Replies Last reply Reply Quote 0
                            • Garfonso
                              Garfonso Developer @MichMein last edited by
                              @MichMein
                              Das müssen die Entwickler beheben, ja... vielleicht machst du mit dem Log, falls noch nicht geschehen, beim github des zigbee adapters mal ein Issue auf -> dann haben die Entwickler das an zentraler Stelle und werden da auch dran erinnert. 🙂
                              Ggf. ist es aber etwas komplexer, weil das Problem sich nicht im zigbee Adapter lösen lässt, sondern nur im Herdsmann, da müsste man dann dort den Fehler beheben, das könnte es etwas verzögern.
                                @MichMein ist in GitHub schon adressiert
                                  Ich habe vom Entwickler die Info, dass im Herdsman das Provblem behoben wurde. Ich habe den Zigbee-Adapter via Git drüber installiert (Version bleibt 1.1.1) und dies hat bei mir den Fehler behoben.
                                  Git-Installation für alle betroffenen auf eigene Gefahr. BACKUP vorher nicht vergessen 😉
                                  • MichMein
                                    @Kueppert oh das klingt gut, werde ich direkt mal probieren und anschliessend berichten.
                                    • MichMein
                                      Ich habe den Adapter über Git neuinstalliert und habe folgende Meldungen im Log gefunden, vielleicht kann mir jemand etwas genaueres dazu sagen
                                      2020-05-05 13:57:10.695 - info: host.raspberrypi iobroker url "https://github.com/ioBroker/ioBroker.zigbee/tarball/master" zigbee
                                      2020-05-05 13:57:12.292 - info: host.raspberrypi iobroker install https://github.com/ioBroker/ioBroker.zigbee/tarball/master
                                      2020-05-05 13:57:12.911 - info: host.raspberrypi iobroker NPM version: 6.14.4
                                      2020-05-05 13:57:12.913 - info: host.raspberrypi iobroker npm install https://github.com/ioBroker/ioBroker.zigbee/tarball/master --loglevel error --prefix "/opt/iobroker" (System call)
                                      2020-05-05 13:58:07.692 - info: host.raspberrypi iobroker upload [200] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/tuya_TS0201.png img/tuya_TS0201.png image/png
                                      2020-05-05 13:58:10.779 - info: host.raspberrypi iobroker upload [150] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/osram_surface_light_tw.png img/osram_surface_light_tw.png image/png
                                      2020-05-05 13:58:13.858 - info: host.raspberrypi iobroker upload [100] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/innr_color_gu10.png img/innr_color_gu10.png image/png
                                      2020-05-05 13:58:14.493 - info: host.raspberrypi iobroker upload [90] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_transformer.png img/ikea_transformer.png image/png
                                      2020-05-05 13:58:15.627 - info: host.raspberrypi iobroker upload [80] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ikea_e14_bulb.png img/ikea_e14_bulb.png image/png
                                      2020-05-05 13:58:16.232 - info: host.raspberrypi iobroker upload [70] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/hs1sa.png img/hs1sa.png image/png
                                      2020-05-05 13:58:16.850 - info: host.raspberrypi iobroker upload [60] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/gld003z.png img/gld003z.png image/png
                                      2020-05-05 13:58:17.441 - info: host.raspberrypi iobroker upload [50] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ewelink_DS01.png img/ewelink_DS01.png image/png
                                      2020-05-05 13:58:18.054 - info: host.raspberrypi iobroker upload [40] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/ctrl_ln2.png img/ctrl_ln2.png image/png
                                      2020-05-05 13:58:18.668 - info: host.raspberrypi iobroker upload [30] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/aqara_switch.png img/aqara_switch.png image/png
                                      2020-05-05 13:58:19.265 - info: host.raspberrypi iobroker upload [20] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/LCT002.png img/LCT002.png image/png
                                      2020-05-05 13:58:19.324 - info: host.raspberrypi iobroker upload [19] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Ikea_fyrtur.png img/Ikea_fyrtur.png image/png
                                      2020-05-05 13:58:19.381 - info: host.raspberrypi iobroker upload [18] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/FLOALT.panel.WS.png img/FLOALT.panel.WS.png image/png
                                      2020-05-05 13:58:19.443 - info: host.raspberrypi iobroker upload [17] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Eurotronic_Spirit_04.png img/Eurotronic_Spirit_04.png image/png
                                      2020-05-05 13:58:19.505 - info: host.raspberrypi iobroker upload [16] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/DIYRuZ.png img/DIYRuZ.png image/png
                                      2020-05-05 13:58:19.567 - info: host.raspberrypi iobroker upload [15] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/Bitron_AV201021A.png img/Bitron_AV201021A.png image/png
                                      2020-05-05 13:58:19.629 - info: host.raspberrypi iobroker upload [14] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/AV2010_32.png img/AV2010_32.png image/png
                                      2020-05-05 13:58:19.690 - info: host.raspberrypi iobroker upload [13] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw2.png img/86sw2.png image/png
                                      2020-05-05 13:58:19.752 - info: host.raspberrypi iobroker upload [12] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86sw1.png img/86sw1.png image/png
                                      2020-05-05 13:58:19.813 - info: host.raspberrypi iobroker upload [11] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/img/86plug.png img/86plug.png image/png
                                      2020-05-05 13:58:19.875 - info: host.raspberrypi iobroker upload [10] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                      2020-05-05 13:58:19.939 - info: host.raspberrypi iobroker upload [9] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                      2020-05-05 13:58:20.000 - info: host.raspberrypi iobroker upload [8] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                      2020-05-05 13:58:20.064 - info: host.raspberrypi iobroker upload [7] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                      2020-05-05 13:58:20.150 - info: host.raspberrypi iobroker upload [6] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                      2020-05-05 13:58:20.259 - info: host.raspberrypi iobroker upload [5] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                      2020-05-05 13:58:20.322 - info: host.raspberrypi iobroker upload [4] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                      2020-05-05 13:58:20.404 - info: host.raspberrypi iobroker upload [3] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                      2020-05-05 13:58:20.466 - info: host.raspberrypi iobroker upload [2] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                      2020-05-05 13:58:20.533 - info: host.raspberrypi iobroker upload [1] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                      2020-05-05 13:58:20.597 - info: host.raspberrypi iobroker upload [0] zigbee.admin /opt/iobroker/node_modules/iobroker.zigbee/admin/admin.js admin.js application/javascript
                                      2020-05-05 13:58:20.685 - info: host.raspberrypi iobroker Update "system.adapter.zigbee.0"
                                      2020-05-05 13:58:20.704 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 (force=false, process=true)
                                      2020-05-05 13:58:20.706 - info: host.raspberrypi stopInstance system.adapter.zigbee.0 send kill signal
                                      2020-05-05 13:58:20.712 - info: zigbee.0 (32715) Got terminate signal TERMINATE_YOURSELF
                                      2020-05-05 13:58:20.715 - info: zigbee.0 (32715) cleaned everything up...
                                      2020-05-05 13:58:20.718 - info: zigbee.0 (32715) Zigbee: disabling joining new devices.
                                      2020-05-05 13:58:20.976 - info: zigbee.0 (32715) terminating
                                      2020-05-05 13:58:20.977 - info: zigbee.0 (32715) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2020-05-05 13:58:21.528 - info: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2020-05-05 13:58:21.715 - info: host.raspberrypi iobroker exit 0
                                      2020-05-05 13:58:22.082 - info: host.raspberrypi Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json"
                                      2020-05-05 13:58:23.870 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15253
                                      2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                                      2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: throw e;
                                      2020-05-05 13:58:24.368 - error: host.raspberrypi Caught by controller[0]: ^
                                      2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                                      2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                                      2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                      2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                      2020-05-05 13:58:24.369 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                      2020-05-05 13:58:24.370 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                                      2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                      2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                      2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                      2020-05-05 13:58:24.371 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                      2020-05-05 13:58:24.371 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2020-05-05 13:58:24.372 - info: host.raspberrypi Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                                      2020-05-05 13:58:24.372 - info: host.raspberrypi system.adapter.zigbee.0 will be rebuilt
                                      2020-05-05 13:58:24.373 - warn: host.raspberrypi adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
                                      2020-05-05 13:58:24.373 - info: host.raspberrypi iobroker rebuild zigbee
                                      2020-05-05 13:58:24.906 - info: host.raspberrypi iobroker npm-rebuild: npm rebuild --loglevel error (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
                                      2020-05-05 13:58:25.959 - info: host.raspberrypi iobroker npm-rebuild: Rebuild zigbee done
                                      2020-05-05 13:58:26.908 - info: host.raspberrypi iobroker npm-rebuild: exit 0
                                      2020-05-05 13:58:26.978 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 15445
                                      2020-05-05 13:58:27.442 - error: host.raspberrypi Caught by controller[0]: /opt/iobroker/node_modules/bindings/bindings.js:121
                                      2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: throw e;
                                      2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: ^
                                      2020-05-05 13:58:27.443 - error: host.raspberrypi Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/@serialport/bindings/build/Release/bindings.node'
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: was compiled against a different Node.js version using
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
                                      2020-05-05 13:58:27.444 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at bindings (/opt/iobroker/node_modules/bindings/bindings.js:112:48)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Object. (/opt/iobroker/node_modules/@serialport/bindings/lib/linux.js:2:36)
                                      2020-05-05 13:58:27.445 - error: host.raspberrypi Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
                                      2020-05-05 13:58:27.446 - error: host.raspberrypi Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
                                      2020-05-05 13:58:27.446 - error: host.raspberrypi Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
                                      2020-05-05 13:58:27.446 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                      2020-05-05 13:58:27.446 - info: host.raspberrypi Adapter system.adapter.zigbee.0 needs rebuild and will be restarted afterwards.
                                      2020-05-05 13:58:27.447 - info: host.raspberrypi system.adapter.zigbee.0 will be rebuilt
                                      2020-05-05 13:58:27.447 - warn: host.raspberrypi adapter "zigbee" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
                                      2020-05-05 13:58:27.447 - info: host.raspberrypi iobroker rebuild zigbee --install
                                      2020-05-05 13:58:27.604 - warn: readFile will not read this file (simple-api.png) in future versions: simple-api.admin is not an object of type "meta"
                                      2020-05-05 13:58:27.625 - warn: readFile will not read this file (socketio.png) in future versions: socketio.admin is not an object of type "meta"
                                      2020-05-05 13:58:27.972 - info: host.raspberrypi iobroker npm-rebuild: npm install --loglevel error --production (System call) in "/opt/iobroker/node_modules/iobroker.zigbee"
                                      2020-05-05 13:58:58.428 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/./serialport.h:6, from ../src/serialport.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                                      2020-05-05 13:58:58.488 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:78:69: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen); ^~~~~~~~~~~~~
                                      2020-05-05 13:58:58.494 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:135:71: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate); ^~~~~~~~~~~~~~~
                                      2020-05-05 13:58:58.498 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:175:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose); ^~~~~~~~~~~~~~
                                      2020-05-05 13:58:58.501 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:215:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush); ^~~~~~~~~~~~~~
                                      2020-05-05 13:58:58.505 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:270:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet); ^~~~~~~~~~~~
                                      2020-05-05 13:58:58.509 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:314:68: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet); ^~~~~~~~~~~~
                                      2020-05-05 13:58:58.515 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:363:76: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate); ^~~~~~~~~~~~~~~~~~~~
                                      2020-05-05 13:58:58.521 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: In function ‘Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)’:../src/serialport.cpp:409:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain); ^~~~~~~~~~~~~~
                                      2020-05-05 13:58:58.523 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp: At global scope:../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of ‘ToParityEnum’ [-Wparentheses] SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local& v8str)) { ^
                                      2020-05-05 13:58:58.525 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of ‘ToStopBitEnum’ [-Wparentheses] SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) { ^
                                      2020-05-05 13:58:58.528 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../../../nan/nan.h:56, from ../src/./serialport.h:6, from ../src/serialport.cpp:1:/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)’ {aka ‘void (*)(v8::Local)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local, v8::Local, void*)’} [-Wcast-function-type] (node::addon_register_func) (regfunc), \ ^/home/iobroker/.cache/node-gyp/12.16.3/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’ NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage) ^~~~~~~~~~~~~../src/serialport.cpp:483:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(serialport, init); ^~~~~~~~~~~
                                      2020-05-05 13:59:01.879 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/serialport.h:6, from ../src/serialport_unix.cpp:2:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                                      2020-05-05 13:59:02.221 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘int setup(int, OpenBaton*)’:../src/serialport_unix.cpp:176:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1005 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:176:13: note: ‘snprintf’ output 20 or more bytes (assuming 1043) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error %s Cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                      2020-05-05 13:59:02.261 - info: host.raspberrypi iobroker npm-rebuild: ../src/serialport_unix.cpp: In function ‘void EIO_Open(uv_work_t*)’:../src/serialport_unix.cpp:86:60: warning: ‘%s’ directive output may be truncated writing up to 1023 bytes into a region of size 1003 [-Wformat-truncation=] snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ^~~~~~~~~~~~~~~~~~~~~~~~~~~../src/serialport_unix.cpp:86:13: note: ‘snprintf’ output 22 or more bytes (assuming 1045) into a destination of size 1024 snprintf(data->errorString, sizeof(data->errorString), "Error: %s, cannot open %s", strerror(errno), data->path); ~~~~~~~~^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
                                      2020-05-05 13:59:03.778 - info: host.raspberrypi iobroker npm-rebuild: In file included from ../src/poller.cpp:1:../../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type] , reinterpret_cast(AsyncExecuteComplete) ^
                                      2020-05-05 13:59:07.320 - info: host.raspberrypi iobroker npm-rebuild:
                                      2020-05-05 13:59:07.321 - info: host.raspberrypi iobroker npm-rebuild: Rebuild zigbee done
                                      2020-05-05 13:59:08.339 - info: host.raspberrypi iobroker npm-rebuild: exit 0
                                      2020-05-05 13:59:08.426 - info: host.raspberrypi instance system.adapter.zigbee.0 started with pid 16543
                                      2020-05-05 13:59:09.957 - info: zigbee.0 (16543) starting. Version 1.1.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.16.3, js-controller: 3.0.20
                                      2020-05-05 13:59:09.992 - info: zigbee.0 (16543) Starting Zigbee...
                                      2020-05-05 13:59:11.410 - info: zigbee.0 (16543) Coordinator firmware version: {"type":"zStack30x","meta":{"transportrev":2,"product":2,"majorrel":2,"minorrel":7,"maintrel":2,"revision":20200211}}
                                      2020-05-05 13:59:11.419 - info: zigbee.0 (16543) --> transmitPower : high
                                      2020-05-05 13:59:11.431 - info: zigbee.0 (16543) Currently 5 devices are joined:
                                      2020-05-05 13:59:11.440 - info: zigbee.0 (16543) 0x00158d0004659dbd (addr 454): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2020-05-05 13:59:11.442 - info: zigbee.0 (16543) 0x00158d0004208499 (addr 35479): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
                                      2020-05-05 13:59:11.445 - info: zigbee.0 (16543) 0x84182600000f0c04 (addr 62092): AB3257001NJ - OSRAM Smart+ plug (Router)
                                      2020-05-05 13:59:11.446 - info: zigbee.0 (16543) 0x00158d00042d1b54 (addr 2753): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
                                      2020-05-05 13:59:11.447 - info: zigbee.0 (16543) 0x00158d0004658581 (addr 12099): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
                                      2020-05-05 13:59:11.448 - info: zigbee.0 (16543) Zigbee started
                                        @MichMein sagte in [gelöst] CC2538 + CC2592: Error & SBL-Tool:
                                        kommt mir bekannt vor 😉 Welche JS-Controller-Version hast du drauf?
                                        • MichMein
                                          @Kueppert
                                          Node.js: 12.16.3
                                            Hi, wollt ihr nicht überlegen das Thema umzubenennen?
                                            Das was ihr hier diskutiert hat nix mit CC2538 und SBL-Tool zu tun.
                                            Danke für das Verständnis.
                                            cc2538 + cc2592 error sbl-tool zigbee zigbee adapter
                                            2667
