    4. Gosund SP111 tasmota dauernd "alive: false"
      chrbo80 last edited by
      ich habe mehrere gosund SP111 mit tasmota 8.2 im Einsatz. Da ich immer mal ab und an eine Dose hatte, die nicht erreichbar war, wollte ich mich der Sache einmal annehmen.
      Daher habe ich heute um 13:57 mal den sonoff-adapter neu gestartet, und seitdem das hier im log:
      sonoff.0	2020-05-04 19:18:50.363	info	(28713) Client [ShellyAnkleideJo] connected with secret 1588612730362_2234
      sonoff.0	2020-05-04 19:18:04.365	info	(28713) Client [ShellyAnkleideJo] connection closed: closed
      sonoff.0	2020-05-04 19:12:38.648	info	(28713) Client [DVES_2F9255] connection closed: timeout
      sonoff.0	2020-05-04 18:59:53.455	info	(28713) Client [DVES_2F9255] connected with secret 1588611593444_4360
      sonoff.0	2020-05-04 17:50:24.292	info	(28713) Client [DVES_2F9255] connection closed: timeout
      sonoff.0	2020-05-04 14:16:45.853	info	(28713) Client [DVES_202757] connected with secret 1588594605852_4321
      sonoff.0	2020-05-04 14:16:39.022	info	(28713) Client [DVES_202757] connection closed: closed
      sonoff.0	2020-05-04 14:16:09.300	info	(28713) Client [DVES_202757] connected with secret 1588594569299_4232
      sonoff.0	2020-05-04 14:16:02.473	info	(28713) Client [DVES_202757] connection closed: closed
      sonoff.0	2020-05-04 14:13:07.776	info	(28713) Client [DVES_202757] reconnected. Old secret 1588593461335_1092. New secret 1588594387774_605
      sonoff.0	2020-05-04 14:11:59.794	info	(28713) Client [DVES_2F9255] connected with secret 1588594319792_983
      sonoff.0	2020-05-04 14:11:51.122	info	(28713) Client [DVES_2F9255] connection closed: disconnected
      sonoff.0	2020-05-04 14:11:15.602	info	(28713) Client [DVES_2F9255] connected with secret 1588594275575_403
      sonoff.0	2020-05-04 14:09:17.104	info	(28713) Client [DVES_232BA0] connected with secret 1588594157102_5106
      sonoff.0	2020-05-04 14:09:10.265	info	(28713) Client [DVES_232BA0] connection closed: closed
      sonoff.0	2020-05-04 14:06:49.549	info	(28713) Client [DVES_232BA0] connected with secret 1588594009547_9716
      sonoff.0	2020-05-04 14:06:42.712	info	(28713) Client [DVES_232BA0] connection closed: closed
      sonoff.0	2020-05-04 14:05:50.708	info	(28713) Client [DVES_2F88EC] connected with secret 1588593950707_774
      sonoff.0	2020-05-04 14:05:44.015	info	(28713) Client [DVES_2F88EC] connection closed: disconnected
      sonoff.0	2020-05-04 14:05:43.619	info	(28713) Client [DVES_2F9255] connection closed: timeout
      sonoff.0	2020-05-04 14:05:12.005	info	(28713) Client [DVES_2F865D] connected with secret 1588593912005_3894
      sonoff.0	2020-05-04 14:05:05.365	info	(28713) Client [DVES_2F865D] connection closed: disconnected
      sonoff.0	2020-05-04 14:02:15.725	info	(28713) Client [DVES_ECF8DA] connected with secret 1588593735723_6067
      sonoff.0	2020-05-04 14:02:09.077	info	(28713) Client [DVES_ECF8DA] connection closed: disconnected
      sonoff.0	2020-05-04 14:00:08.014	info	(28713) Client [DVES_2F9255] connected with secret 1588593608012_5591
      sonoff.0	2020-05-04 13:59:00.772	info	(28713) Client [DVES_2F9255] connection closed: closed
      sonoff.0	2020-05-04 13:57:42.191	info	(28713) Client [ShellyVorratsraum] connected with secret 1588593462190_3552
      sonoff.0	2020-05-04 13:57:42.050	info	(28713) Client [DVES_232BA0] connected with secret 1588593462049_9482
      sonoff.0	2020-05-04 13:57:41.775	info	(28713) Client [DVES_2F865D] connected with secret 1588593461774_5656
      sonoff.0	2020-05-04 13:57:41.661	info	(28713) Client [ShellyAnkleideJo] connected with secret 1588593461660_9777
      sonoff.0	2020-05-04 13:57:41.615	info	(28713) Client [DVES_348537] connected with secret 1588593461615_1216
      sonoff.0	2020-05-04 13:57:41.502	info	(28713) Client [DVES_ECF8DA] connected with secret 1588593461487_9618
      sonoff.0	2020-05-04 13:57:41.427	info	(28713) Client [DVES_2F88EC] connected with secret 1588593461425_4633
      sonoff.0	2020-05-04 13:57:41.376	info	(28713) Client [ShellyWaschkueche] connected with secret 1588593461374_5225
      sonoff.0	2020-05-04 13:57:41.339	info	(28713) Client [DVES_202757] connected with secret 1588593461335_1092
      sonoff.0	2020-05-04 13:57:41.316	info	(28713) Client [DVES_3507CE] connected with secret 1588593461313_9203
      sonoff.0	2020-05-04 13:57:40.312	info	(28713) Client [DVES_2F9255] connected with secret 1588593460280_8019
      sonoff.0	2020-05-04 13:57:33.640	info	(28713) Starting MQTT authenticated server on port 1881
      sonoff.0	2020-05-04 13:57:33.589	info	(28713) starting. Version 2.3.3 in /opt/iobroker/node_modules/iobroker.sonoff, node: v10.18.1
      Zudem ist aktuell eine Steckdose von mir (die 2f9255) nicht erreichbar, im Datenpunkt alive steht false. Die Dose ist auch über den Browser und die IP nicht zu erreichen.
      Hinzufügen kann ich noch, dass die Dose in einem Mehrfachstecker mit einer anderen Dose steckt, die keinerlei Probleme hat.
      Hat jemand einen Tipp bzw. braucht weitere Infos?
        Hier sind noch die aktuellen Datenpunkte der nicht erreichbaren Dose:
          Jan1 @chrbo80 last edited by
          @chrbo80
          Das oben sind Infos und durchaus normal.
          Hats die Dinger OTA geflasht, oder?
            chrbo80 @Jan1 last edited by
            @Jan1 hi, danke. habe die geflasht gekauft. Daher weiß ich es nicht. Hatte sowas im Gefühl und habe mir bereits einen FTDI gekauft und suche grade eine anfängerfreundliche Anleitung fürn Mac...
            Meinst Du, es liegt an der Art und Weise vom flashen?
            VG
              @chrbo80
              Ich sags mal so, ich flash immer mit Kabel und habe solche Probleme nicht. Den Rest kannst Du Dir denken, wie Du es willst 😉
                @Jan1 dank dir. flashst du mit dem mac und kannst mir vlt nen tipp geben? für windows habe ich viele schritt-für-schritt-anleitungen gesehen, für mac irgendwie noch nicht... was ich bisher schonmal gemacht habe: habe das esptool und die dazugehörige tasmota-bin in einem verzeichnis. weiter komme ich mit dem terminal allerdings leider nicht.
                J 2 Replies Last reply Reply Quote 0
                  @chrbo80
                  Bei MAC bin ich komplett raus, kein Plan ob es da auch ein VSCode Version zum kompilieren und Flashen gibt. Ich kompiliere mein bins selber wenn schon dann richtig 🙂
                  • Ralla66
                    Ralla66 Most Active last edited by
                    @chrbo80
                    connection closed sind aber alle.
                      @chrbo80
                      Interessant ist auch was in der Web Konsole von Tasmota drin steht, ob das wirklich reconnects sind oder nicht.
                        @Jan1 kann ich das irgendwie nachvollziehen? habe grade mal bei einer, die reconnected hat, in die console geschaut, da ist aber nicht mehr drin bis auf die aktuellen einträge...
                        • Ralla66
                          @Jan1
                          @chrbo80
                          Blank drüber,
                          dann mit 7er testen,
                          wenn rennt wieder Blank und die 8.2 testen.
                          @chrbo80 Kumpel mit Windowsrechner suchen.
                            chrbo80 @Ralla66 last edited by
                            @Ralla66 said in Gosund SP111 tasmota dauernd "alive: false":
                            @Jan1
                            @chrbo80
                            Blank drüber,
                            ok - klare ansage 🙂 mache ich...
                            J Lenny.CB 2 Replies Last reply Reply Quote 0
                              Jan1 @chrbo80 last edited by Jan1
                              @chrbo80
                              Würde aber nicht die 7er verwenden, hab mit der 8.2er keine Problem.
                              Mit Kabel das Device löschen, z.B. mit Tasmotizer und dann wieder die 8.2 drauf, da die 7er ein anderen Core hat , würdest Du Dir ohne nochmaliges löschen beim Flashen von 7 nach 8 nur unnötig Probleme einfangen.
                              • Lenny.CB
                                Lenny.CB Most Active @chrbo80 last edited by
                                @chrbo80 schau dir mal die anleitung an. Ich selbst nutze den Tasmo mit nem Win-Rechner... bisher ohne Probleme.
                                https://siytek.com/how-to-flash-tasmota-the-easy-way/#Mac
                                  Jan1 @Lenny.CB last edited by
                                  @Lenny-CB
                                  Geil, Tasmotizer läuft auch auf nem MAC, dann hat er ja schon sein Flash Tool.
                                  Lenny.CB C 2 Replies Last reply Reply Quote 0
                                  • Lenny.CB
                                    Lenny.CB Most Active @Jan1 last edited by
                                    @Jan1 sagte in Gosund SP111 tasmota dauernd "alive: false":
                                    @Lenny-CB
                                    Sollte zumindest da auch gehen. Selbst aber, wegen fehlendem MAC, noch nicht probiert.
                                      TemPeck last edited by
                                      Ich habe bei einigen meiner Gosund SP1 das selbe Problem, allerdings nicht in der Häufung.
                                      Es betrifft sowohl welche, die ich mit Tasmota 6.5 über Kabel geflasht habe (was bei der SP1 mit dem Löten wirklich kein Geschenk ist), als auch zwei, die ich erst wenige Tage habe und mit Tasmota 8.1 OTA geflasht habe.
                                      Die Stecker haben manchmal Tage, an denen sie unterbrechungsfrei laufen, an anderen Tagen unterbrechen sie im niedrigen zweistelligen Bereich.
                                      Was mich wundert ist, dass etliche Sonoff S20 problemfrei laufen.
                                      Weiterhin scheint es auch nicht vom Standort abzuhängen, da sie im ganzen Haus verteilt sind.
                                      Kann es sein, dass die WLAN-Verbindung der Gosund Stecker aus irgendeinem Grund einfach wesentlich schlechter sind als bei anderen Produkten??
                                      • Ralla66
                                        Blank vorher flashen ist wichtig.
                                        Ohne Probs läuft bei mir 7.1.1 Core 2.3.0 auf dem Gosund.
                                        Überall, auch Wemos D1.
                                        @chrbo80, welche Version ist dein Gosund ?
                                          @Jan1 auch grad gesehen. das versuche ich morgen. kann mir nochmal einer kurz erklären, was man am besten bei den mqtt-konfig eingibt? hostadresse und port sind klar, aber topic etc. nicht wirklich... sieht bei mir zb bei meiner waschmaschinen-steckdose so aus:
                                          topic passe ich dann halt an. ist das korrekt?
                                            @Ralla66 1.1 mit 3450 watt und die 8.2 tasmota
                                            gosund sp111 tasmota
                                            2408
