    4. Script Engine Update nach 4.6.4
    UNSOLVED Script Engine Update nach 4.6.4
    • Chaot
      Chaot last edited by Chaot
      Mir wurde gestern und heute das Update der Script Engine angeboten.
      Wenn ich das Update mache kommt dieser Fehler:
      javascript.0	2020-05-16 09:15:53.432	error	(2593) Cannot install xml2js: 254
      javascript.0	2020-05-16 09:15:53.386	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-16T07_15_53_365Z-debug.log
      javascript.0	2020-05-16 09:15:53.386	error	(2593) npm ERR! A complete log of this run can be found in:
      javascript.0	2020-05-16 09:15:53.383	error	(2593)
      javascript.0	2020-05-16 09:15:53.364	error	npm ERR! enoent
      javascript.0	2020-05-16 09:15:53.364	error	npm ERR! enoent This is related to npm not being able to find a file.
      javascript.0	2020-05-16 09:15:53.364	error	(2593) ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match'
      javascript.0	2020-05-16 09:15:53.361	error	(2593) npm
      javascript.0	2020-05-16 09:15:53.359	error	npm ERR! errno -2
      javascript.0	2020-05-16 09:15:53.359	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
      javascript.0	2020-05-16 09:15:53.359	error	(2593) npm ERR! syscall access
      javascript.0	2020-05-16 09:15:53.357	error	(2593) npm ERR! code ENOENT
      javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/open-fin-ts-js-client
      javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/bunyan
      javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mv
      javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/rimraf
      javascript.0	2020-05-16 09:15:53.184	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/glob
      javascript.0	2020-05-16 09:15:53.184	error	(2593) npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inflight
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/once
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/wrappy
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/safe-json-stringify
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/path-is-absolute
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/ncp
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/dtrace-provider
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/nan
      javascript.0	2020-05-16 09:15:53.182	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/mkdirp
      javascript.0	2020-05-16 09:15:53.182	error	(2593) Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimist
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/minimatch
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/inherits
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/encoding
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/iconv-lite
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/brace-expansion
      javascript.0	2020-05-16 09:15:53.181	error	npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/concat-map
      javascript.0	2020-05-16 09:15:53.181	error	(2593) WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/balanced-match
      javascript.0	2020-05-16 09:15:53.179	error	(2593) npm
      javascript.0	2020-05-16 09:15:42.908	error	(2593) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      javascript.0	2020-05-16 09:15:42.905	error	(2593) npm
      Irgendwie seltsam, weil ich ansonsten keinerlei Berechtigungsprobleme habe. Der Fixer bringt auch nichts.
      Jemand eine Idee?
      Edit:
      Der Fehler get weiter:
      In den Adaptern wird die 4.5.1. als installiert angezeigt und der Reiter "Scripte" zeigt nichts mehr an.
      Wenn ich manuell wieder den 4.5.1 installiere geht alles wieder.
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        Jan1 @Chaot last edited by
        @Chaot
        Deinstalliere mal den JS Adapter und versuch ne Neuinstallation nach dem der Fixer noch mal lief.
        Ein reboot des ganzen System wirkt auch oft Wunder.
        • Chaot
          Chaot @Jan1 last edited by
          @Jan1
          Ich habe das auch schon versucht.
          Der letzte Versuch war jetzt mit der Brechstange.
          Das ganze Verzeichnis auf 777 gesetzt, Adapter installiert und danach den Fixer wieder drüber.
          Jetzt ist (seltsamerweise) 4.6.4 installiert und der Script Reiter zeigt auch wieder die Scripte.
          Fehlermeldung ist noch:
          javascript.0	2020-05-16 09:35:06.364	error	(27210) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          javascript.0	2020-05-16 09:35:06.361	error	(27210) npm
          javascript.0	2020-05-16 09:34:59.751	error	(27210) Cannot install request: 254
          javascript.0	2020-05-16 09:34:59.734	error	npm ERR! /home/iobroker/.npm/_logs/2020-05-16T07_34_59_687Z-debug.log
          javascript.0	2020-05-16 09:34:59.734	error	(27210) A complete log of this run can be found in:
          javascript.0	2020-05-16 09:34:59.731	error	(27210) ERR!
          javascript.0	2020-05-16 09:34:59.728	error	(27210)
          javascript.0	2020-05-16 09:34:59.726	error	(27210) npm
          javascript.0	2020-05-16 09:34:59.724	error	(27210)
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent This is related to npm not being able to find a file.
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! enoent ENOENT: no such file or directory, access '/opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser'
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! errno -2
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! path /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
          javascript.0	2020-05-16 09:34:59.691	error	npm ERR! syscall access
          javascript.0	2020-05-16 09:34:59.691	error	(27210) npm ERR! code ENOENT
          javascript.0	2020-05-16 09:34:59.539	error	(27210) npm WARN checkPermissions Missing write access to /opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js-parser
          host.ioBroker	2020-05-16 09:34:57.521	info	iobroker exit 0
          host.ioBroker	2020-05-16 09:34:56.504	info	iobroker Adapter "javascript" updated
          host.ioBroker	2020-05-16 09:34:56.447	info	iobroker upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
          host.ioBroker	2020-05-16 09:34:56.382	info	iobroker upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/asset-manifest.json asset-manifest.json application/json
          host.ioBroker	2020-05-16 09:34:56.317	info	iobroker upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
          host.ioBroker	2020-05-16 09:34:56.256	info	iobroker upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
          host.ioBroker	2020-05-16 09:34:56.183	info	iobroker upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/blockly_compressed.js google-blockly/blockly_compressed.js application/javascript
          javascript.0	2020-05-16 09:34:56.142	error	(27210) WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
          javascript.0	2020-05-16 09:34:56.139	error	(27210) npm
          An dem Request Fehler scheint Bluefox zu arbeiten wenn ich das Changelog richtig lese. Aber warum er bei Rechten 777 immer noch die Rechte beim xml2js-parser bemängelt ist mit schleierhaft.
            Thomas Braun Most Active @Chaot last edited by
            @Chaot Plötzliche unerklärliche Probleme mit den Rechten können auf ein sterbendes Dateisystem hindeuten.
            • Chaot
              Chaot @Thomas Braun last edited by
              @Thomas-Braun Auf der SSD am NUC? Am Raspi könnte ich mir das erklären.
                @Chaot Auch die können sterben. Ich habe ja auch nicht gesagt, dass es 100% so ist, sondern das weggebröselte Dateirechte ein Hinweis auf Probleme dort sein kann.
                • Chaot
                  @Thomas-Braun Stimmt schon, aber komischerweise sind ja mit dem 4.1.5 die Dateirechte in Ordnung. Also liegt es vermutlich am Update.
                  • BBTown
                    BBTown @Chaot last edited by BBTown
                    @Chaot
                    versuche mal ein update auf v4.6.7
                      A Former User last edited by
                      Fragt sich der problem geplagte User, woher die 4.6.7 ?
                      in den "Verwahrungs Orten" ist die nicht b.z.w. wird über diese nicht angezeigt.
                        Thomas Braun Most Active @Guest last edited by
                        @Blechsoldat
                        Geht im Moment nur über git (die 'Katze')
                        • E
                          Einstein67 last edited by
                          Mittels das Katzensysmbol von Git-Hub installieren!
                            A Former User @Einstein67 last edited by
                            @Einstein67
                            Danke Sehr
                              Jan1 last edited by
                              st über den timeout und dem zugehörigen stop timeout schon was bekannt?
                              Bei mir hat eben ein Script Fehler geworfen und beim Überprüfen ist mir das aufgefallen:
                              Das lässt sich zwar ändern, wird aber nicht gespeichert. Das Problem wird auch erst aktiv, wenn man am Script was ändert, ansonsten läuft das so und bringt auch keine Fehler. Seit wann das so ist und ob es mit dem Update des Adapter zusammenhängt weiß ich nicht.
                              Edit:
                              da ist definitiv was faul, da sich der Adapter nicht downgraden lässt, läuf zwar durch, aber an der Version ändert sich nichts und seit wann heißt das eigentlich "Wartezeit"?
                              Hier mal das Lag beim Deinstallieren, sind einige seltsame Meldungen drin:
                              $ ./iobroker del javascript
                              Delete adapter "javascript"
                              host.Beelink Counted 1 instances of javascript
                              host.Beelink Counted 1 meta of javascript
                              host.Beelink Counted 1 adapter for javascript
                              host.Beelink Counted 107 states of javascript
                              host.Beelink Counted 15 states of system.adapter.javascript
                              host.Beelink Counted 1 objects of javascript
                              host.Beelink file javascript.admin deleted
                              host.Beelink object javascript.admin deletedhost.Beelink Deleting 126 object(s).
                              npm uninstall iobroker.javascript --error --prefix "/opt/iobroker" (System call)
                              npm
                               WARN tsutils@3.17.1 requires a peer of typescript@>=2.8.0 || >= 3.2.0-dev || >= 3.3.0-dev || >= 3.4.0-dev || >= 3.5.0-dev || >= 3.6.0-dev || >= 3.6.0-beta || >= 3.7.0-dev || >= 3.7.0-beta but none is installed. You must install peer dependencies yourself.
                              npm
                               WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):npm WARN
                              notsup
                               SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN
                               optional
                               SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                              npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm
                               WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.2 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):npm WARN
                               notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN
                              optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.12 (node_modules/zigbee-herdsman/node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.12: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                              process exited with code 0
                              • Chaot
                                Chaot @BBTown last edited by
                                @BBTown 4..6.7 ist jetzt drauf. Bisher keine Fehlermeldung erschienen und alles scheint zu laufen.
                                  @Chaot
                                  Schau Dir mal Deine Blockly Scripte an die timeouts drin haben, selbst mit der Github Version war das buggy
                                  • E
                                    Hab bei meiner Heizungssteuerung einen "Pulsbetrieb" mit dem ich 1,2, oder 3 Stunden die Heizung aktivieren kann. Das ist alles über Timeouts gesteuert ... und hat gerade (Schei*** Eisheilige 😉 ) mit 4.6.7 problemlos funktioniert.
                                      Jan1 @Einstein67 last edited by Jan1
                                      @Einstein67
                                      Das läuft schon, nur ändere mal was im Blockly, dann wars das😁
                                        A Former User @Jan1 last edited by
                                        @Jan1 !
                                        Läuft .... 😁
                                          Jan1 @Guest last edited by Jan1
                                          @Blechsoldat
                                          Der Screenshot sagt aber was anderes😆
                                          Mir ist es erst aufgefallen, als ich an einem Script was ergänzt hatte und plötzlich auch so schöne Meldungen im Log hatte. Wenn man nichts ändert, läuft das Script ohne Fehler.
                                          • crunchip
                                            Habe ich heute auch festgestellt mit dem timeout, bei Script Änderung.
                                            Und generell, habe ich Probleme mit dem Speichern/ Ändern/Bearbeiten der Scripte. Alles sehr träge. Wird nicht übernommen, muss mehrmals speichern bzw Änderungen wiederholen.
                                            Probleme macht überwiegend FireFox.
                                            script engine
                                            12
                                            60
                                            3347
