    4. host.iobroker Fehlermeldung
    UNSOLVED host.iobroker Fehlermeldung
      karstent last edited by
      Von jetzt auf gleich bekomme ich folgende fehlermeldung im Log. Davor habe ich eigentlich nur versucht den Synology Adapter in betrieb zu nehmen.
      host.iobroker	2020-05-18 11:44:34.748	error	instance system.adapter.history.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at bootstrap_node.js:625:3
      host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at startup (bootstrap_node.js:204:16)
      host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at Function.Module.runMain (module.js:694:10)
      host.iobroker	2020-05-18 11:44:34.747	error	Caught by controller[0]: at Function.Module._load (module.js:498:3)
      host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at tryModuleLoad (module.js:506:12)
      host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at Module.load (module.js:566:32)
      host.iobroker	2020-05-18 11:44:34.746	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:664:10)
      host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at Module._compile (module.js:617:28)
      host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at Object.runInThisContext (vm.js:139:10)
      host.iobroker	2020-05-18 11:44:34.745	error	Caught by controller[0]: at createScript (vm.js:80:10)
      host.iobroker	2020-05-18 11:44:34.744	error	Caught by controller[0]: SyntaxError: Unexpected token {
      host.iobroker	2020-05-18 11:44:34.744	error	Caught by controller[0]: ^
      host.iobroker	2020-05-18 11:44:34.743	error	Caught by controller[0]: } catch {
      host.iobroker	2020-05-18 11:44:34.742	error	Caught by controller[0]: /opt/iobroker/node_modules/iobroker.history/main.js:1020
      Was ist den da schief gelaufen?
      Typ: js-controller
      Titel: JS controller
      OS: linux
      Verfügbar: 3.1.4
      Installiert: 2.2.8
      Ereignisse: ↦31 / ↦13
        karstent last edited by karstent
        zu früh gefreut.
          Thomas Braun Most Active @karstent last edited by
          @karstent
          nodejs -v && node -v && npm -v
          which nodejs && which node && which npm
            ich schau nach.
              node -v v8.16.0
              npm -v 6.4.1
              nodejs -v v8.16.0
              Nach dem ich versucht habe ein Update der ioBroker Installation zu machen kommt folgende Fehlermeldung:
              iobroker upgrade self
              Update js-controller from @2.2.8 to @3.1.4
              NPM version: 6.4.1
              npm install iobroker.js-controller@3.1.4 --unsafe-perm --loglevel error --prefix "/opt/iobroker" (System call)
              /opt/iobroker/node_modules/iobroker.js-controller/lib/cli/cliPlugin.js:253
                                  } catch {
                  at Module.require (module.js:597:17)
                  at require (internal/module.js:11:18)
                  at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/cli/index.js:19:17)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! iobroker.js-controller@3.1.4 install: `node iobroker.js setup first`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the iobroker.js-controller@3.1.4 install script.
              npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                @karstent node zu alt. node12 installieren.
                  node -v v10.20.1
                  nodejs -v v10.20.1
                  npm -v6.14.4
                  schlägt fehl mein Update:
                  internal/modules/cjs/loader.js:638
                      throw err;
                      at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
                      at Function.Module._load (internal/modules/cjs/loader.js:562:25)
                      at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
                      at startup (internal/bootstrap/node.js:283:19)
                      at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
                  weiß nich weiter 😞
                    @karstent node 12 installieren...
                    Wo hängst du denn da nun mit node genau?
                    apt policy nodejs
                      karstent @Thomas Braun last edited by
                      @Thomas-Braun ```
                      nodejs:
                      Installiert: 10.20.1-1nodesource1
                      Installationskandidat: 10.20.1-1nodesource1
                      Versionstabelle:
                      *** 10.20.1-1nodesource1 500
                      500 https://deb.nodesource.com/node_10.x stretch/main amd64 Packages
                      100 /var/lib/dpkg/status
                      4.8.2~dfsg-1 500
                      500 http://ftp.de.debian.org/debian stretch/main amd64 Packages
                        @karstent
                        Die anderen Ausgaben waren geheim?
                          mehr kommt da nicht
                          iobroker:~$ which nodejs && which node && which npm
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          ktrepte@iobroker:~$ apt policy nodejs
                          nodejs:
                            Versionstabelle:
                               4.8.2~dfsg-1 500
                            @karstent
                            iobroker update
                            iobroker upgrade
                              das ist alles:
                              ktrepte@iobroker:~$ iobroker update
                                  throw err;
                              ktrepte@iobroker:~$ iobroker upgrade
                                  throw err;
                                @karstent
                                cd /opt/iobroker
                                sudo -H -u iobroker npm install iobroker.js-controller
                                  wieder so eine Ellenlange Ausgabe:
                                  ktrepte@iobroker:~$ cd /opt/iobroker
                                  ktrepte@iobroker:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
                                  > iobroker.js-controller@2.2.10 preinstall /opt/iobroker/node_modules/iobroker.js-controller
                                  > node lib/preinstallCheck.js
                                  NPM version: 6.14.4
                                  > iobroker.js-controller@2.2.10 install /opt/iobroker/node_modules/iobroker.js-controller
                                  110 file(s) successfully synchronized with ioBroker storage.
                                  Please DO NOT copy files manually into ioBroker storage directories!
                                  The following notifications happened during sync:
                                  - Added 94 Files in Directory "iqontrol.meta"
                                  - Added 16 Files in Directory "javascript.admin"
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.1.2 (node_modules/chokidar/node_modules/fsevents):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.5 (node_modules/osx-temperature-sensor):
                                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                  + iobroker.js-controller@2.2.10
                                  added 59 packages from 83 contributors and audited 1498 packages in 48.098s
                                  7 packages are looking for funding
                                    run `npm fund` for details
                                  found 76 vulnerabilities (56 low, 20 high)
                                    run `npm audit fix` to fix them, or `npm audit` for details
                                  ktrepte@iobroker:/opt/iobroker$ npm audit fix
                                  npm ERR! code ELOCKVERIFY
                                  npm ERR! Errors were found in your package-lock.json, run  npm install  to fix them.
                                  npm ERR!     Invalid: lock file's iobroker.admin@3.6.0 does not satisfy iobroker.admin@^4.1.1
                                  npm ERR!     Missing: iobroker.alexa2@^3.1.2
                                  npm ERR!     Missing: iobroker.backitup@^1.5.7
                                  npm ERR!     Missing: iobroker.cloud@^2.6.2
                                  npm ERR!     Missing: iobroker.devices@^0.3.6
                                  npm ERR!     Invalid: lock file's iobroker.discovery@1.2.4 does not satisfy iobroker.discovery@^2.3.3
                                  npm ERR!     Missing: iobroker.flot@^1.9.2
                                  npm ERR!     Missing: iobroker.fritzdect@^0.3.2
                                  npm ERR!     Missing: iobroker.history@^1.9.6
                                  npm ERR!     Missing: iobroker.hm-rega@^2.6.7
                                  npm ERR!     Missing: iobroker.hm-rpc@^1.14.2
                                  npm ERR!     Missing: iobroker.ical@^1.7.0
                                  npm ERR!     Missing: iobroker.influxdb@^1.8.6
                                  npm ERR!     Invalid: lock file's iobroker.info@1.3.7 does not satisfy iobroker.info@^1.7.2
                                  npm ERR!     Missing: iobroker.iot@^1.2.0
                                  npm ERR!     Missing: iobroker.iqontrol@https://github.com/sbormann/ioBroker.iqontrol/tarball/master
                                  npm ERR!     Missing: iobroker.javascript@^4.6.4
                                  npm ERR!     Invalid: lock file's iobroker.js-controller@1.4.2 does not satisfy iobroker.js-controller@^2.2.10
                                  npm ERR!     Missing: iobroker.meross@^1.3.13
                                  npm ERR!     Missing: iobroker.mihome@^1.3.0
                                  npm ERR!     Missing: iobroker.mobile@^0.5.0
                                  npm ERR!     Missing: iobroker.mqtt@^2.1.3
                                  npm ERR!     Missing: iobroker.mqtt-client@^1.3.1
                                  npm ERR!     Missing: iobroker.node-red@^1.16.5
                                  npm ERR!     Missing: iobroker.nut@^1.1.3
                                  npm ERR!     Missing: iobroker.parser@^1.0.7
                                  npm ERR!     Missing: iobroker.proxmox@^1.0.2
                                  npm ERR!     Missing: iobroker.rickshaw@^1.0.0
                                  npm ERR!     Missing: iobroker.scenes@^1.1.0
                                  npm ERR!     Missing: iobroker.simple-api@^2.4.1
                                  npm ERR!     Missing: iobroker.snmp@^0.5.0
                                  npm ERR!     Missing: iobroker.socketio@^3.0.7
                                  npm ERR!     Missing: iobroker.sonoff@^2.3.3
                                  npm ERR!     Missing: iobroker.sql@^1.9.5
                                  npm ERR!     Missing: iobroker.squeezebox@^1.0.0
                                  npm ERR!     Missing: iobroker.statistics@^0.2.2
                                  npm ERR!     Missing: iobroker.synology@^0.1.10
                                  npm ERR!     Missing: iobroker.systeminfo@^0.3.1
                                  npm ERR!     Missing: iobroker.terminal@^0.1.2
                                  npm ERR!     Missing: iobroker.tr-064@^0.4.18
                                  npm ERR!     Missing: iobroker.tr-064-community@https://github.com/iobroker-community-adapters/ioBroker.tr-064-community/tarball/master
                                  npm ERR!     Missing: iobroker.upnp@^1.0.14
                                  npm ERR!     Missing: iobroker.viessmannapi@^1.3.2
                                  npm ERR!     Missing: iobroker.virtualpowermeter@^1.0.1
                                  npm ERR!     Missing: iobroker.vis@^1.2.3
                                  npm ERR!     Missing: iobroker.vis-hqwidgets@^1.1.2
                                  npm ERR!     Missing: iobroker.vis-jqui-mfd@^1.0.12
                                  npm ERR!     Missing: iobroker.web@^3.0.5
                                  npm ERR!     /home/ktrepte/.npm/_logs/2020-05-18T20_42_42_679Z-debug.log
                                    Nach dem ich die ioBroker Instanz wieder starten konnte ergibt sich folgendes im log:
                                    host.iobroker	2020-05-18 22:49:03.812	error	instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                                    host.iobroker	2020-05-18 22:49:03.812	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                    host.iobroker	2020-05-18 22:49:03.811	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
                                    host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
                                    host.iobroker	2020-05-18 22:49:03.807	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
                                    host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
                                    host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
                                    host.iobroker	2020-05-18 22:49:03.806	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
                                    host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
                                    host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
                                    host.iobroker	2020-05-18 22:49:03.805	error	Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:807:18)
                                    host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                                    host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 64. Please try re-compiling or re-installing
                                    host.iobroker	2020-05-18 22:49:03.804	error	Caught by controller[0]: NODE_MODULE_VERSION 57. This version of Node.js requires
                                    host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: was compiled against a different Node.js version using
                                    host.iobroker	2020-05-18 22:49:03.803	error	Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
                                    host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: ^
                                    host.iobroker	2020-05-18 22:49:03.802	error	Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
                                    host.iobroker	2020-05-18 22:49:03.801	error	Caught by controller[0]: internal/modules/cjs/loader.js:807
                                      @karstent
                                      iobroker rebuild
                                        Vielen Dank für deine Hilfe. Nach dem ich aus Verzweiflung noch einmal die befehle
                                        cd /opt/iobroker
                                        npm cache clean
                                        sudo iobroker stop
                                        sudo iobroker update
                                        sudo iobroker upgrade self
                                        sudo iobroker start
                                        in die Console getippt habe hat sich, oh Wunder, die Instanz wieder selber zum leben erweckt. Im Moment habe ich keinerlei Fehlermeldungen mehr und der Controller ist jetzt dort wo er sein soll:
                                        Typ: js-controller
                                        Verfügbar: 3.1.4
                                        Installiert: 3.1.4
                                        Also, vielen Dank noch mal 🙂
                                          Stejin last edited by
                                          sry fürs raus kramen, aber ich hatte das gleiche Problem, mir hat das update auf node12 geholfen!
                                          sudo apt-get install curl software-properties-common
                                          curl -sL https://deb.nodesource.com/setup_12.x | sudo bash -
                                          apt-get install nodejs
                                          host.iobroker
                                          2584
