    4. Shelly 2.5 Error
    UNSOLVED Shelly 2.5 Error
    • xxx_turbo_xxx
      xxx_turbo_xxx last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Raspbian
      Node-Version: ?
      Nodejs-Version: 12.6.3
      NPM-Version: 6.?
      Installationsart: ioBroker image
      Image genutzt: Ja
      ich bekomme ständig folgenden error...
      2020-05-18 18:08:19.995 - error: shelly.0 (3232) Error handling Shelly data: SyntaxError: Unexpected token P in JSON at position 1017 (res) for JSON {"blk":[{"I":0,"D":"Relay0"},{"I":1,"D":"Relay1"},{"I":2,"D":"Device"}],"sen":[{"I":112,"T":"S","D":"State","R":"0/1","L":0},{"I":122,"T":"S","D":"State","R":"0/1","L":1},{"I":111,"T":"P","D":"Power","R":"0/2300","L":0},{"I":121,"T":"P","D":"Power","R":"0/2300","L":1},{"I":118,"T":"S","D":"Input","R":"0(off)/1(on)/2(longpush)","L":0},{"I":128,"T":"S","D":"Input","R":"0(off)/1(on)/2(longpush)","L":1},{"I":115,"T":"T","D":"Temperature C","R":"-40/300","L":2},{"I":116,"T":"T","D":"Temperature F","R":"-40/300","L":2},{"I":117,"T":"S","D":"Overtemp","R":"0/1","L":2},{"I":211,"T":"S","D":"Energy counter 0 [W-min]","L":0},{"I":212,"T":"S","D":"Energy counter 1 [W-min]","L":0},{"I":213,"T":"S","D":"Energy counter 2 [W-min]","L":0},{"I":214,"T":"S","D":"Energy counter total [W-min]","L":0},{"I":221,"T":"S","D":"Energy counter 0 [W-min]","L":1},{"I":222,"T":"S","D":"Energy counter 1 [W-min]","L":1},{"I":223,"T":"S","D":"Energy counter 2 [W-min]","L":1},{"I":224,"T":"S","D":"Energy counter total [W-min]","L":1}]}PB��cits��	SHSW-25#BCDDC27766F0#1�C����{"G":[[0,112,1],[0,122,1],[0,111,97.810028],[0,121,1918.086670],[0,118,0],[0,128,0],[0,115,87.57],[0,116,189.62],[0,117,0],[0,211,94.965],[0,212,282.307],[0,213,656.066],[0,214,179854],[0,221,1924.700],[0,222,1903.324],[0,223,1872.539],[0,224,217548]]}
      Kann mir jemand sagen, woran das liegen könnte?
      Danke schonmal!
      • haselchen
        haselchen Most Active @xxx_turbo_xxx last edited by
        @xxx_turbo_xxx
        Version Shelly Adapter?
        App Version?
        xxx_turbo_xxx 1 Reply Last reply Reply Quote 0
        • xxx_turbo_xxx
          xxx_turbo_xxx @haselchen last edited by
          @haselchen Shelly 2.5! App nutze ich nicht! Hab den Shelly per http konfiguriert und sonst steuere ich ihn per ioBroker
          harrym haselchen 2 Replies Last reply Reply Quote 0
          • harrym
            harrym @xxx_turbo_xxx last edited by
            @xxx_turbo_xxx mach mal ein FW update bei dem 2.5er 😉
            • haselchen
              @xxx_turbo_xxx
              Und ich hatte nach der Adapter Version gefragt, nicht nach der Shelly Version 😉
              harrym 1 Reply Last reply Reply Quote 0
              • harrym
                harrym @haselchen last edited by
                @haselchen de FW is es Problem .... de "Fehler" beruhen auf ner alten FW Version beim shelly 😉
                J haselchen 2 Replies Last reply Reply Quote 0
                  Jan1 @harrym last edited by
                  @harrym
                  und die hat er darauf weil er das APP nicht nutzt 😉
                  • haselchen
                    haselchen Most Active @harrym last edited by haselchen
                    @harrym
                    Welche FW hast Du auf den(m) Shelly(s)?
                    @Jan1
                    Alle üblichen Verdächtigen wieder vereint 🙂
                    • harrym
                      harrym @Jan1 last edited by
                      @Jan1 was hat de APP mit der GUI zu tun????
                        @harrym
                        Die FW des Shelly wird doch wohl über die APP aktualisiert, oder wie läuft das bei den Dingern und original FW?
                        • harrym
                          @haselchen 1.6
                          • harrym
                            @Jan1 nö. kannste auch über die GUI aktualisieren ..... einfach den shelly via browser mit der ip aufrufen. shelly funzt auch ohne cloud und app 😉
                              @harrym
                              Ja das weiß ich dass das auch ohne geht, war der Annahme, dass die APP das regelt. War wohl falsch, die Annahme 🙂
                              • harrym
                                @Jan1 alles gut 😉
                                  @harrym
                                  Ich hab zwar jede Menge der Dinger, aber die laufen bei mir alle mit Tasmota, weil ich alles in einem Adapter haben möchte und ich bin da von den Sonoff ausgegangen, weil die das eben über die APP machen, wieder schlauer 😎
                                  Dann sollte er mal ein Update fahren, ist mir eh immer ein Rätsel warum User mit alten Ständen nicht einfach mal updaten und dann schaue ob der Fehler überhaupt noch da ist 😜
                                  harrym 1 Reply Last reply Reply Quote 1
                                  • harrym
                                    man kann die shelly auch via RestAPI lokal via OTA mit neuer FW versorgen .....DAS ist aber noch nicht im shelly adapter implementiert.
                                    • harrym
                                      @Jan1 wie bist du mit tasmota auf de shelly zufrieden? ich hab bis dato eigentlich noch keinen grund gesehen, dass ich da vom coap/mqtt und der originalen FW auf tasmota wechsel ..... welche vorteile hast du da?
                                        @harrym
                                        Hab ich ja schon geschrieben, alles in einem Adapter und deshalb etwas übersichtlicher. Dann habe ich Quickview im Einsatz das mir alle Tasmota Geräte auf einer HTML Seite listet, was eben einfacher ist wenn man mal direkt steuern will. Dann habe ich die meisten als Shutter im Einsatz und da gefällt mir Tasmota ein Tick besser, ansonsten ist es eher Geschmackssache ob original oder Tasmota.
                                        Da gibts ausnahmsweise mal nicht die Vor- oder Nachteile, die original ist schon gut durchdacht.
                                        • harrym
                                          harrym @Jan1 last edited by harrym
                                          @Jan1 tasmoadmin ? g
                                          und alles in einem adapter .... kannste dir ja abseits vom broker nen master aufsetzten .... und den dann via broker als client abfragen .....ok .... der sonoff adapter unterstützt das noch nicht.
                                            Jan1 @harrym last edited by Jan1
                                            @harrym
                                            von TasmotaAdmin halte ich nicht viel, da ich viele verschiedene Tasmota Devices habe und damit nicht wirklich ein Vorteil. Ich passe jedes bin dem Device an und der Admin erlaubt nur ein bin für alle zum updaten z.B.
                                            Machen kann man viel, wobei ich da so wenig wie möglich als HW bevorzuge.
                                            error shelly
                                            835
