    4. sql startet nach update nicht mehr
    UNSOLVED sql startet nach update nicht mehr
      madison last edited by Negalein
      Systemdata vmware
      Hardwaresystem: vmware
      Arbeitsspeicher: 4GB
      Festplattenart: HDD
      Betriebssystem: Ubuntu
      Node-Version: 12.16.1
      Nodejs-Version: 12.16.1
      NPM-Version: 6.13.4
      Installationsart: Skript
      Image genutzt: Nein
      Ort/Name der Imagedatei: Link
      nach dem update auf 1.13.0 startet der sql adapter nicht mehr.
      folgendes ist im log zu finden.
      sql.0	2020-05-18 18:34:29.779	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      sql.0	2020-05-18 18:34:29.779	error	at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
      sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
      sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
      sql.0	2020-05-18 18:34:29.779	error	at Array.map (<anonymous>)
      sql.0	2020-05-18 18:34:29.779	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
      sql.0	2020-05-18 18:34:29.779	error	(31880) TypeError: Cannot read property 'startsWith' of undefined
      sql.0	2020-05-18 18:34:29.776	error	(31880) unhandled promise rejection: Cannot read property 'startsWith' of undefined Unhandled	2020-05-18 18:34:29.776	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      sql.0	2020-05-18 18:28:32.141	error	(31422) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/no
      sql.0	2020-05-18 18:28:32.138	error	(31422) unhandled promise rejection: Cannot read property 'startsWith' of undefined
      sql.0	2020-05-18 18:28:32.138	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Mod-Edit: Code/Log in Code Tags gepackt. Bitte benutzt die Code Tags Funktion -> </>
      Hier gehts zur Hilfe.
        nach downgrade auf 1.12.5 läuft der adapter wieder.
        sieht nach einem bug in der version 1.13.0 aus!
          rascal last edited by
          das Gleiche hier:
          host.Mastermind	2020-05-18 19:47:51.590	info	instance system.adapter.sql.0 terminated with code 0 (NO_ERROR)
          host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at processTicksAndRejections (internal/process/task_queues.js:97:5)
          host.Mastermind	2020-05-18 19:47:51.590	error	Caught by controller[1]: at _0x30230c._applyViewFunc (/opt/iobroker/node_modules/iobroker.objects-redis/index.js:1:115328)
          host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1482:21
          host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:26
          host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at Array.map (<anonymous>)
          host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39
          host.Mastermind	2020-05-18 19:47:51.589	error	Caught by controller[1]: TypeError: Cannot read property 'startsWith' of undefined
          host.Mastermind	2020-05-18 19:47:51.588	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected
          sql.0	2020-05-18 19:47:51.469	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.468	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.467	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.466	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.465	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.464	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.463	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.462	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.461	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.460	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.454	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.453	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.452	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.451	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.450	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.449	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.448	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.447	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.446	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.445	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.444	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.443	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.442	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.441	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.440	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.369	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.368	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.364	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.363	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.357	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.356	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.353	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.352	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.349	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.348	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.345	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.339	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.337	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.336	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.333	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.331	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.330	warn	(453392) No Connection to database
          sql.0	2020-05-18 19:47:51.043	info	(453392) Terminated (NO_ERROR): Without reason
          sql.0	2020-05-18 19:47:51.041	info	(453392) terminating
          sql.0	2020-05-18 19:47:50.436	error	(453392) TypeError: Cannot read property 'startsWith' of undefined at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7066:39 at Array.map (<anonymous>) at /opt/iobroker/n
          sql.0	2020-05-18 19:47:50.426	error	(453392) unhandled promise rejection: Cannot read property 'startsWith' of undefined
          sql.0	2020-05-18 19:47:50.425	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            C-3po @madison last edited by
            @madison said in sql startet nach update nicht mehr:
            Jo,
            Hier das selbe Ergebnis. Nur seltsam das es in der History noch eine 1.12.6 gibt. Selbige aber nicht Installierbar ist.
            Mit 1.12.5 wieder io.
              mit 1.12.6 hatte ich den Fehler auch
              • Feuersturm
                Feuersturm last edited by
                Es gibt hierzu auch ein Github Issue: https://github.com/ioBroker/ioBroker.sql/issues/120
                peer69 created this issue in ioBroker/ioBroker.sql
                closed Adapter crashes after update to 1.13.0 #120
                  Lstt last edited by
                    bommel_030 last edited by bommel_030
                    Habe auch auf die 1.13.0 aktualisiert (Vermute von der 1.12.5). Instanz ist permanent neu gestartet.
                    Habe dann den Downgrade auf 1.12.5 und bekomme seitdem folgende Fehlermeldung.
                    sql.0	2020-05-19 07:34:49.602	info	(4756) No Data
                    sql.0	2020-05-19 07:34:24.964	error	(4756) Error: Packets out of order. Got: 1 Expected: 0
                    Egal welche Version ich auch installiere, die Meldung kommt jetzt immer. Hat jemand ne Idee was das sein könnte?
                    Edit:
                    Downgrade auf 1.9.4 und danach upgrade auf 1.12.5 hat geholfen, warum auch immer...
                    • opossum
                      opossum last edited by
                      bei mir gleiches Problem, aber Downgrade auf 1.12.5 hat fehlerfrei geklappt. Downgrade von 1.13.0 auf 1.12.6 hat bei mir gar nicht funktioniert.
                      • Dr. Bakterius
                        Dr. Bakterius Most Active last edited by
                        Kann ich auch bestätigen! Das mit der nicht existenten 1.12.6 ist auch fies. Wird ohne Fehler installiert, doch danach ist immer noch 1.13.0 installiert. Wollte schon über die Console installieren als ich diesen Hinweis hier bekam.
                          Berchemer last edited by Berchemer
                          Schließe mich an.
                          Habe jetzt die 1.12.6 gar nicht erst versucht sondern direkt auf 1.12.5 downgegraded und alles ist wieder gut.
                          Danke für die Warnung mit der 1.12.6 🙂
                          oberfragger 1 Reply Last reply Reply Quote 0
                          • oberfragger
                            oberfragger @Berchemer last edited by oberfragger
                            Vielen Dank für das Posting. Dachte nur bei mir wäre was im Eimer. 1.12.5 funktiniert auf Anhieb!
                              bombastikde last edited by
                              Nach dem Downgrade auf 1.12.5 funktionert jetzt wieder alles - Das hat aber einigen Scheiss gekostet
                                hat die Version 1.13.1 schon jemand getestet?
                                C Feuersturm 2 Replies Last reply Reply Quote 0
                                  @madison
                                  Jupp
                                  eben gerade
                                  Rennt wieder.
                                    madison @C-3po last edited by
                                    @C-3po super, danke!
                                      @madison
                                      dafür schiest aber das neue Script Engine quer
                                        @C-3po welche version?
                                          C-3po @madison last edited by C-3po
                                          @madison
                                          4.6.13
                                          macht stress mit Blockly und Datumsabfragen.
                                          bin erst mal wieder auf 4.6.4
                                          M B 2 Replies Last reply Reply Quote 1
                                            @C-3po Datumsabfragen verwende ich nicht, sonst wäre mir noch nichts aufgefallen!
                                            sql adapter crash error
                                            14
                                            32
                                            2223
