    4. Node-Red
    5. Node Red funktioniert nicht nach contrib-enocean
    • Thorsten Missenberger
      Thorsten Missenberger last edited by Thorsten Missenberger
      ich habe heute über die Palette in Node Red das node-red-contrib-Enocean installiert.
      Seitdem komme ich nicht mehr auf die Oberfläche und im Log habe ich folgende meldungen
      node-red.0	2020-05-22 11:30:11.122	warn	(3166) 18: 0x92cab3 node::contextify::ContextifyContext::CreateV8Context(node::Environment*, v8::Local<v8::Object>, node::contextify::ContextOptions const&) [node-red] 19: 0x92d0e9 node::contextify::C
      node-red.0	2020-05-22 11:30:11.118	warn	(3166) 16: 0xb0fdf0 v8::Context::New(v8::Isolate*, v8::ExtensionConfiguration*, v8::MaybeLocal<v8::ObjectTemplate>, v8::MaybeLocal<v8::Value>, v8::DeserializeInternalFieldsCallback) [node-red] 17: 0x8
      node-red.0	2020-05-22 11:30:11.114	warn	(3166) 12: 0x12013de v8::internal::Snapshot::NewContextFromSnapshot(v8::internal::Isolate*, v8::internal::Handle<v8::internal::JSGlobalProxy>, unsigned long, v8::DeserializeInternalFieldsCallback) [no
      node-red.0	2020-05-22 11:30:11.111	warn	(3166) 11: 0x11f3c0a v8::internal::PartialDeserializer::DeserializeContext(v8::internal::Isolate*, v8::internal::SnapshotData const*, bool, v8::internal::Handle<v8::internal::JSGlobalProxy>, v8::Deser
      node-red.0	2020-05-22 11:30:11.108	warn	(3166) 10: 0x11ec35a v8::internal::DefaultDeserializerAllocator::ReserveSpace() [node-red]
      node-red.0	2020-05-22 11:30:11.106	warn	(3166) 9: 0xf06630 v8::internal::Heap::ReserveSpace(std::vector<v8::internal::Heap::Chunk, std::allocator<v8::internal::Heap::Chunk> >*, std::vector<unsigned long, std::allocator<unsigned long> >*) [
      node-red.0	2020-05-22 11:30:11.103	warn	(3166) 8: 0xf03f74 v8::internal::Heap::CollectGarbage(v8::internal::AllocationSpace, v8::internal::GarbageCollectionReason, v8::GCCallbackFlags) [node-red]
      node-red.0	2020-05-22 11:30:11.101	warn	(3166) 7: 0xf03642 v8::internal::Heap::PerformGarbageCollection(v8::internal::GarbageCollector, v8::GCCallbackFlags) [node-red]
      node-red.0	2020-05-22 11:30:11.099	warn	(3166) 6: 0xef7568 v8::internal::Heap::CheckIneffectiveMarkCompact(unsigned long, double) [node-red]
      node-red.0	2020-05-22 11:30:11.096	warn	(3166) 5: 0xef7462 [node-red]
      node-red.0	2020-05-22 11:30:11.094	warn	(3166) 4: 0xb03404 v8::internal::V8::FatalProcessOutOfMemory(v8::internal::Isolate*, char const*, bool) [node-red]
      node-red.0	2020-05-22 11:30:11.092	warn	(3166) 3: 0xb031ce v8::Utils::ReportOOMFailure(v8::internal::Isolate*, char const*, bool) [node-red]
      node-red.0	2020-05-22 11:30:11.090	warn	(3166) 2: 0x8fb0dc [node-red]
      node-red.0	2020-05-22 11:30:11.080	warn	(3166) 1: 0x8fb090 node::Abort() [node-red]
      node-red.0	2020-05-22 11:30:11.079	warn	(3166) FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
      node-red.0	2020-05-22 11:30:06.681	warn	(3166) 22 May 11:30:06 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
      Kann ich das node wieder deinstallieren über die Konsole oder was kann ich da machen?
      Habe NodeRED 128MB zugewiesen und benutzt derzeit nur 55MB.
      VG Thorsten
        frankyboy73 @Thorsten Missenberger last edited by
        @Thorsten-Missenberger
        Hi, deinstallieren über die Konsole mit
        npm uninstall node-red-contrib-enocean
        eventuell mit sudo davor.
        Oder du versuchst es noch mal drüber zu installieren, vielleicht ist bei der Installation was schief gelaufen
        npm install node-red-contrib-enocean
        Sonst Node Red eventuell mal neu starten
        Falls nichts klappt, hoffe ich du hast ein Backup.
