    2. Русский
    3. ioBroker
    4. Ошибка
    5. ioBroker ошибки
    6. Ошибка адаптера MQTT
      jeorgep last edited by
      После обновления адаптера MQTT до версии 1.1.1 (2016-09-12)
      в логе появились ошибки:
      warn	Client [...] has invalid password(....) or username(....)
        http://forum.iobroker.net/viewtopic.php … =20#p34655
          ford7 last edited by
          Только начал пробовать работать с mqtt, сыплется постоянно:
          ! mqtt.0 2017-05-08 22:22:46.267 warn Cannot resolve topic name for ID: system.adapter.javascript.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:41.598 warn Cannot resolve topic name for ID: system.adapter.s7.0.outputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:41.593 warn Cannot resolve topic name for ID: system.adapter.s7.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:39.521 warn Cannot resolve topic name for ID: system.adapter.web.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:36.808 warn Cannot resolve topic name for ID: system.adapter.mqtt.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:35.001 warn Cannot resolve topic name for ID: system.adapter.sql.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:32.485 warn Cannot resolve topic name for ID: system.adapter.admin.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:31.273 warn Cannot resolve topic name for ID: system.adapter.javascript.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:26.586 warn Cannot resolve topic name for ID: system.adapter.s7.0.outputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:26.585 warn Cannot resolve topic name for ID: system.adapter.s7.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:24.537 warn Cannot resolve topic name for ID: system.adapter.web.0.inputCount (object not found)
          ! mqtt.0 2017-05-08 22:22:19.987 warn Cannot resolve topic name for ID: system.adapter.sql.0.inputCount (object not found)
          ! mqtt.
          Скетч взял отсюда: http://forum.iobroker.net/viewtopic.php … 237#p62237 Изменил только адреса, остальное пока оставил как есть.
          • I
            instalator last edited by
            @ford7:
            ! mqtt.
            Скетч взял отсюда: http://forum.iobroker.net/viewtopic.php … 237#p62237 Изменил только адреса, остальное пока оставил как есть. `
            У меня вот такие настройки
