    4. Neue Konsolen befehle seit js 3.0
    • G
      gifftstaub last edited by
      Hallo Zusammen,
      Seit JS 3.0 wurde ja viele neue befehle dazugefügt, gibt es schon eine neue Console commands seite?
      die hier ist ein bisschen alt
      lg
        Thomas Braun Most Active @gifftstaub last edited by
        @gifftstaub
        Die hier?
        Die hättest du aber auch selber aufrufen können...
        pi@raspberrypi:~ $ iobroker
        Commands:
        iobroker setup [--objects <host>] [--states <host>] [custom]
        iobroker start - starts the js-controller
        iobroker stop - stops the js-controller
        iobroker start <adapter>[.instance] - starts a specified adapter instance
        iobroker stop <adapter>.[instance] - stops a specified adapter instance
        iobroker start all - starts js-controller and all adapters
        iobroker restart - restarts the js-controller
        iobroker restart <adapter>[.instance] - restarts a specified adapter
        iobroker debug <adapter> [--ip=<ip>] [--port=<port>] [--wait] - Starts a Node.js debugging session for the adapter
            --wait stops the execution until the debugger is attached.
            --ip and --port can be used to change the listen IP and port. Use IP 0.0.0.0 for remote debugging.
        iobroker info - shows the host info
        iobroker logs [adapter] [--watch] [--lines=1000]
        iobroker add <adapter> [desiredNumber] [--enabled] [--host <host>] [--port <port>]
        iobroker install <adapter> - installs a specified adapter
        iobroker rebuild <adapter>|self [--install]
        iobroker url <url> [<name>] - install adapter from specified url, e.g. GitHub
        iobroker del <adapter> - remove adapter from system
        iobroker del <adapter>.<instance> - remove adapter instance
        iobroker update [repository url] [--updatable/--u] [--installed/--i] [--force/--f] - update repository and optionally filter installed/updateable adapters, use --force to bypass hash check
        iobroker upgrade [repository url]
        iobroker upgrade self [repository url] - upgrade js-controller and all adapters, optionally you can specify the repository url
        iobroker upgrade <adapter> [repository url] - upgrade specified adapter, optionally you can specify the repository url
        iobroker upload <pathToLocalFile> <pathIniobroker>
        iobroker upload all - upload all adapter files to make them available for instances
        iobroker upload <adapter> - upload specified adapter files to make them available for instances
        iobroker object get <id> - get object specified by id
        iobroker object set <id> <json-value> - set object with the given id by providing a new json object
        iobroker object set <id> propertyname=<value or json-value> - update part of the object by providing a new value or partial object
        iobroker object extend <id> <json-value> - extend object with the given id by providing a new json object
        iobroker object del <id|pattern> [--yes]
        iobroker object chmod <object-mode> [state-mode] <id>
        iobroker object chown <user> <group> <id>
        iobroker object list <id>
        iobroker state get <id> - get state, specified by id
        iobroker state getplain <id> [--pretty]
        iobroker state getvalue <id>
        iobroker state set <id> <value> [ack]
        iobroker state del <id>
        iobroker message <adapter>[.instance] <command> [<message>]
        iobroker list <type> [filter]
        iobroker chmod <mode> <file>
        iobroker chown <user> <group> <file>
        iobroker touch <file>
        iobroker rm <file>
        iobroker file read <iobroker-path-to-read> [<filesystem-path-to-write>]
        iobroker file write <filesystem-path-to-read> <iobroker-path-to-write>
        iobroker file rm <iobroker-path-to-delete>
        iobroker file sync
        iobroker user add <user> [--ingroup group] [--password pass]
        iobroker user del <user>
        iobroker user passwd <user> [--password pass]
        iobroker user enable <user>
        iobroker user disable <user>
        iobroker user get <user>
        iobroker user check <user> [--password pass]
        iobroker group add <group>
        iobroker group del <group>
        iobroker group list <group>
        iobroker group enable <group>
        iobroker group disable <group>
        iobroker group get <group>
        iobroker group adduser <group> <user>
        iobroker group deluser <group> <user>
        iobroker host this
        iobroker host <hostname>
        iobroker host set <hostname>
        iobroker host remove <hostname>
        iobroker set <adapter>.<instance> [--port port] [--ip address] [--ssl true|false]
        iobroker license <license.file or license.text>
        iobroker cert create
        iobroker cert view [<certificate name>]
        iobroker clean
        iobroker backup
        iobroker restore <backup name or path> - restore a specified backup
        iobroker validate <backup name or path> - validate a specified backup
        iobroker <command> --timeout 5000
        iobroker status [all|<adapter>.<instance>]
        iobroker repo [name]
        iobroker repo add <name> <path or url>
        iobroker repo set <name>
        iobroker repo del <name>
        iobroker uuid
        iobroker unsetup
        iobroker fix - execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost <enable|disable> [--secure true|false]
        iobroker multihost browse
        iobroker multihost connect
        iobroker compact status - show if compact mode is enabled in general
        iobroker compact <enable|on|disable|off> - enable or disable compact mode in general
        iobroker compact <adapter>.<instance> status - show if compact mode is enabled for a specific instance
        iobroker compact <adapter>.<instance> group <group-id> - define compact group of a specific adapter
        iobroker compact <adapter>.<instance> <disable|off> - enable or disable compact mode for specified adapter instance
        iobroker compact <adapter>.<instance> <enable|on> [group-id] - enable or disable compact mode for specified adapter instance and set comapct group optionally
        iobroker plugin enable <pluginname> [--host <hostname>] - enables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin disable <pluginname> [--host <hostname>] - disables a plugin for the specified host. If no host is specified, the current one is used
        iobroker plugin status <pluginname> [--host <hostname>] - checks if a plugin is enabled for the specified host. If no host is specified, the current one is used
        iobroker plugin enable <pluginname> --instance <adapter>[.<nr>] - enables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin disable <pluginname> --instance <adapter>[.<nr>] - disables a plugin for the specified adapter instance (defaults to instance 0)
        iobroker plugin status <pluginname> --instance <adapter>[.<nr>] - checks if a plugin is enabled for the specified adapter instance (defaults to instance 0)
        iobroker version [adapter] - show version of js-controller or specified adapter
        iobroker [adapter] -v - show version of js-controller or specified adapter
        Options:
          --help     Hilfe anzeigen  [boolean]
          --version  Version anzeigen  [boolean]
        console commands
