    3. Entwicklung
    4. openweather Fehler
    openweather Fehler
      skorpil last edited by skorpil
      Bis heute mittag (12:46) lief der Adapter problemlos.
      2020-05-30 12:46:00.023 - info: host.debian-VB instance system.adapter.openweathermap.0 started with pid 25552
      2020-05-30 12:46:03.612 - info: openweathermap.0 (25552) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v8.16.0
      Eine halbe Stunde später bekomme ich folgende Fehlermeldung
      2020-05-30 13:23:00.036 - info: host.debian-VB instance system.adapter.openweathermap.0 started with pid 25596
      2020-05-30 13:23:03.167 - info: openweathermap.0 (25596) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v8.16.0
      2020-05-30 13:23:04.621 - error: openweathermap.0 (25596) uncaught exception: Cannot read property 'statusCode' of undefined
      2020-05-30 13:23:04.621 - error: openweathermap.0 (25596) TypeError: Cannot read property 'statusCode' of undefined
      Was könnte das sein?
        Gerade habe ich den iobroker nochmal neu gestartet. Jetzt bekomme ich folgende Fehlermeldungen:
        openweathermap.0	2020-05-30 16:04:38.043	info	(26312) Terminated (NO_ERROR): Without reason
        openweathermap.0	2020-05-30 16:04:38.043	info	(26312) terminating
        host.debian-VB		2020-05-30 16:04:37.828	info	instance system.adapter.broadlink2.0 started with pid 26326
        openweathermap.0	2020-05-30 16:04:37.540	error	at TLSSocket.emit (events.js:211:7)
        openweathermap.0	2020-05-30 16:04:37.540	error	at emitOne (events.js:116:13)
        openweathermap.0	2020-05-30 16:04:37.540	error	at TLSSocket.socketErrorListener (_http_client.js:401:9)
        openweathermap.0	2020-05-30 16:04:37.540	error	at ClientRequest.emit (events.js:211:7)
        openweathermap.0	2020-05-30 16:04:37.540	error	at Request.onRequestError (/opt/iobroker/node_modules/iobroker.openweathermap/node_modules/request/request.js:881:8)
        openweathermap.0	2020-05-30 16:04:37.540	error	at Request.emit (events.js:211:7)
        openweathermap.0	2020-05-30 16:04:37.540	error	at self.callback (/opt/iobroker/node_modules/iobroker.openweathermap/node_modules/request/request.js:185:22)
        openweathermap.0	2020-05-30 16:04:37.540	error	at Request.request [as _callback] (/opt/iobroker/node_modules/iobroker.openweathermap/main.js:255:47)
        openweathermap.0	2020-05-30 16:04:37.540	error	(26312) TypeError: Cannot read property 'statusCode' of undefined
        openweathermap.0	2020-05-30 16:04:37.539	error	(26312) uncaught exception: Cannot read property 'statusCode' of undefined
        openweathermap.0	2020-05-30 16:04:37.273	info	(26312) starting. Version 0.1.0 in /opt/iobroker/node_modules/iobroker.openweathermap, node: v8.16.0
        host.debian-VB		2020-05-30 16:04:33.835	info	instance system.adapter.openweathermap.0 started with pid 26312
        host.debian-VB		2020-05-30 16:04:33.814	info	instance scheduled system.adapter.openweathermap.0 23,46 6-22 * * *
        Vielleicht kann mir ja jemand auf dieser Basis eine Tip geben, wo ich den Fehler suchen soll.
          paul53 @skorpil last edited by
          @skorpil sagte:
          Den Fehler erzeugt die Instanz "openweathermap.0". Die Eigenschaft "statusCode" eines nicht vorhandenen Objektes kann nicht ermittelt werden. Mehr kann ich dazu nicht sagen, denn ich bin nicht der Entwickler des Adapters.
            skorpil @paul53 last edited by
            @paul53 Dankeschön
            • Kusselin
              Kusselin last edited by
              Servus.....habe die Meldung jetzt schon des Öfteren und auch länger....API stimmt aber lt. openweather...
              Ist das bekannt?
                Thomas Braun Most Active @Kusselin last edited by Thomas Braun
                @kusselin
                The HyperText Transfer Protocol (HTTP) 401 Unauthorized response status code indicates that the client request has not been completed because it lacks valid authentication credentials for the requested resource.
                Zugangsdaten prüfen (wenn da welche zu vergeben sind).
                1.2k
                81.1k
                fehler adapter openweathermap
