    4. HID Adapter lässt sich nicht installieren
    UNSOLVED HID Adapter lässt sich nicht installieren
      FrenkyIO last edited by
      |Systemdata| Raspberry Pi4 4Gb|
      |Betriebssystem:| Raspbian Buster |
      |Node-Version:| 12.x.x |
      |Nodejs-Version:| 12.17.0|
      |NPM-Version:| 6.14.4 |
      |Installationsart:| Skript&#x2F |
      Kann leider den Adapter nicht installieren. Hier der Log.
      $ ./iobroker add hid  --host raspberrypi4
      NPM version: 6.14.4
      npm install iobroker.hid@0.1.17 --loglevel error --prefix "/opt/iobroker" (System call)
      ../hidapi/libusb/hid.c: In function ‘hid_read_timeout’:
      ../hidapi/libusb/hid.c:1078:6: warning: variable ‘bytes_read’ might be clobbered by ‘longjmp’ or ‘vfork’ [-Wclobbered]  int bytes_read = -1;      ^~~~~~~~~~
      In file included from ../src/HID.cc:31:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/HID.cc: At global scope:../src/HID.cc:67:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]     throw(JSException);     ^~~~~
      ../src/HID.cc:70:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]     throw(JSException);     ^~~~~
      ../src/HID.cc:152:3: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]   throw(JSException)   ^~~~~
      ../src/HID.cc:163:3: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]   throw(JSException)   ^~~~~
      ../src/HID.cc: In member function ‘void HID::readResultsToJSCallbackArguments(HID::ReceiveIOCB*, v8::Local<v8::Value>*)’:../src/HID.cc:203:91: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::GetCurrentContext()->Global()->Get(Nan::New<String>("Buffer").ToLocalChecked() )        ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:207:74: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’     Local<Object> buf = nodeBufConstructor->NewInstance(1, nodeBufferArgs);        ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4281:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4281:44: note:   candidate expects 3 arguments, 2 provided
      /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4284:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4284:44: note:   candidate expects 1 argument, 2 provided
      ../src/HID.cc: In static member function ‘static void HID::recvAsyncDone(uv_work_t*)’:../src/HID.cc:231:32: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   iocb->_callback->Call(2, argv);                                ^
      In file included from ../src/HID.cc:31:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::read(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:257:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, recvAsync, (uv_after_work_cb)recvAsyncDone);        ^~~~~~~~~~~~~
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::readSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:280:51: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buff_read[i]));                                                   ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::readTimeout(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:305:51: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buff_read[i]));                                                   ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::getFeatureReport(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:339:45: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buf[i]));                                             ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::sendFeatureReport(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:360:29: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     if (!messageArray->Get(i)->IsNumber()) {                             ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:363:58: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     message.push_back((unsigned char) messageArray->Get(i)->Int32Value());                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:363:72: error: no matching function for call to ‘v8::Value::Int32Value()’     message.push_back((unsigned char) messageArray->Get(i)->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:404:46: error: no matching function for call to ‘v8::Value::Int32Value()’       int32_t vendorId = info[0]->Int32Value();                                              ^
      ../src/HID.cc:405:47: error: no matching function for call to ‘v8::Value::Int32Value()’       int32_t productId = info[1]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc:409:62: error: no matching function for call to ‘v8::String::Value::Value(v8::Local<v8::Value>)’         serialPointer = (wchar_t*) *v8::String::Value(info[2]);                                                              ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3158:5: note: candidate: ‘v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>)’     Value(Isolate* isolate, Local<v8::Value> obj);     ^~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3158:5: note:   candidate expects 2 arguments, 1 provided../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::setNonBlocking(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:443:37: error: no matching function for call to ‘v8::Value::Int32Value()’   blockStatus = info[0]->Int32Value();                                     ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::write(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:468:31: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       if (!messageArray->Get(i)->IsNumber()) {                               ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:471:60: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       message.push_back((unsigned char) messageArray->Get(i)->Int32Value());                                                            ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:471:74: error: no matching function for call to ‘v8::Value::Int32Value()’       message.push_back((unsigned char) messageArray->Get(i)->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::getDeviceInfo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:505:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:509:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:513:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::devices(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:535:38: error: no matching function for call to ‘v8::Value::Int32Value()’       vendorId = info[0]->Int32Value();                                      ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc:536:39: error: no matching function for call to ‘v8::Value::Int32Value()’       productId = info[1]->Int32Value();                                       ^
      ../src/HID.cc:551:101: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("vendorId").ToLocalChecked(), Nan::New<Integer>(dev->vendor_id));        ^
      ../src/HID.cc:552:103: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("productId").ToLocalChecked(), Nan::New<Integer>(dev->product_id));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:554:110: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("path").ToLocalChecked(), Nan::New<String>(dev->path).ToLocalChecked());        ^
      ../src/HID.cc:557:143: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("serialNumber").ToLocalChecked(), Nan::New<String>(narrow(dev->serial_number).c_str()).ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:560:149: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("manufacturer").ToLocalChecked(), Nan::New<String>(narrow(dev->manufacturer_string).c_str()).ToLocalChecked());        ^
      ../src/HID.cc:563:139: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("product").ToLocalChecked(), Nan::New<String>(narrow(dev->product_string).c_str()).ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:565:105: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("release").ToLocalChecked(), Nan::New<Integer>(dev->release_number));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:566:109: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("interface").ToLocalChecked(), Nan::New<Integer>(dev->interface_number));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:568:107: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         deviceInfo->Set(Nan::New<String>("usagePage").ToLocalChecked(), Nan::New<Integer>(dev->usage_page));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:571:98: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         deviceInfo->Set(Nan::New<String>("usage").ToLocalChecked(), Nan::New<Integer>(dev->usage));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc:573:36: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(count++, deviceInfo);                                    ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
      ../src/HID.cc: In static member function ‘static void HID::Initialize(v8::Local<v8::Object>)’:../src/HID.cc:596:31: warning: ‘void node::AtExit(void (*)(void*), void*)’ is deprecated: Use the three-argument variant of AtExit() or AddEnvironmentCleanupHook() [-Wdeprecated-declarations]   node::AtExit(deinitialize, 0);                               ^
      In file included from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:702:22: note: declared here     NODE_EXTERN void AtExit(void (*cb)(void* arg), void* arg = nullptr));                      ^~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~../src/HID.cc:596:31: warning: ‘void node::AtExit(void (*)(void*), void*)’ is deprecated: Use the three-argument variant of AtExit() or AddEnvironmentCleanupHook() [-Wdeprecated-declarations]   node::AtExit(deinitialize, 0);                               ^In file included from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:702:22: note: declared here     NODE_EXTERN void AtExit(void (*cb)(void* arg), void* arg = nullptr));                      ^~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
      ../src/HID.cc:614:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New<String>("HID").ToLocalChecked(), hidTemplate->GetFunction());        ^
      In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
      ../src/HID.cc:616:115: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New<String>("devices").ToLocalChecked(), Nan::New<FunctionTemplate>(HID::devices)->GetFunction());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
      In file included from ../src/HID.cc:30:../src/HID.cc: At global scope:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/HID.cc:629:3: note: in expansion of macro ‘NODE_MODULE’   NODE_MODULE(HID, init);   ^~~~~~~~~~~
      make: *** [HID.target.mk:120: Release/obj.target/HID/src/HID.o] Error 1
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-hidgyp ERR! node -v v12.17.0
      gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! node-hid@0.5.7 install: `prebuild-install || node-gyp rebuild`
      npm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-hid@0.5.7 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-31T09_31_49_013Z-debug.log
      ERROR: host.raspberrypi4 Cannot install iobroker.hid@0.1.17: 1
      ERROR: process exited with code 25
      Vielen Dank schonmal für eure Hilfe.
        Der Adapter wird wahrscheinlich nicht mehr gewartet, oder?
        Kennt jemand denn vielleicht eine andere Idee wie ich meine Funkfernbedienung einbinde.
        Habe diese hier: https://www.amazon.de/Andoer®-Tragbare-Drahtlose-Fernbedienung-Tastatursteuerung-Type-2/dp/B00WDSCTR4
        Möchte damit nicht nur Kodi steuern können, sondern optional auch den Strom am Fernseher einschalten können (über einen Datenpunkt). Bin für jede Hilfe dankbar.
        adapter hid
