    4. [gelöst] sonos startet nach Update nicht 0.1.10
    • I
      iben last edited by
      seit den letzte Updates lässt sich der Sonos Adapter nicht starte, hier das Log (./node_modules/sonos-web-controller/node_modules/socket.io) ist vorhanden:
      host-ubuntu2cpu	2016-09-20 17:58:15.146	info	Restart adapter system.adapter.sonos.0 because enabled
      host-ubuntu2cpu	2016-09-20 17:58:15.146	error	instance system.adapter.sonos.0 terminated with code 0 (OK)
      sonos-0	2016-09-20 17:58:15.131	info	terminating
      sonos-0	2016-09-20 17:58:15.125	info	terminating
      TypeError:	2016-09-20 17:58:15.125	error	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:247:12)
      TypeError:	2016-09-20 17:58:15.125	error	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      TypeError:	2016-09-20 17:58:15.125	error	at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-09-20 17:58:15.125	error	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:333:8)
      TypeError:	2016-09-20 17:58:15.125	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
      TypeError:	2016-09-20 17:58:15.125	error	at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      TypeError:	2016-09-20 17:58:15.125	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:229:12)
      TypeError:	2016-09-20 17:58:15.125	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:305:9)
      TypeError:	2016-09-20 17:58:15.125	error	at Socket. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:122:13)
      TypeError:	2016-09-20 17:58:15.125	error	at main (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:958:17)
      TypeError:	2016-09-20 17:58:15.125	error	sonosDiscovery is not a function
      uncaught	2016-09-20 17:58:15.124	error	exception: sonosDiscovery is not a function
      sonos-0	2016-09-20 17:58:15.096	info	starting. Version 0.1.10 in /opt/iobroker/node_modules/iobroker.sonos
      Error:	2016-09-20 17:58:14.925	error	at Function.Module.runMain (module.js:441:10)
      Error:	2016-09-20 17:58:14.925	error	at Function.Module._load (module.js:300:12)
      Error:	2016-09-20 17:58:14.925	error	at Module.load (module.js:343:32)
      Error:	2016-09-20 17:58:14.925	error	at Object.Module._extensions..js (module.js:416:10)
      Error:	2016-09-20 17:58:14.925	error	at Module._compile (module.js:409:26)
      Error:	2016-09-20 17:58:14.925	error	at Object. (/opt/iobroker/node_modules/iobroker.sonos/sonos.js:180:22)
      Error:	2016-09-20 17:58:14.925	error	at require (internal/module.js:12:17)
      Error:	2016-09-20 17:58:14.925	error	at Module.require (module.js:353:17)
      Error:	2016-09-20 17:58:14.925	error	at Function.Module._load (module.js:276:25)
      Error:	2016-09-20 17:58:14.925	error	at Function.Module._resolveFilename (module.js:325:15)
      Error:	2016-09-20 17:58:14.925	error	Cannot find module './node_modules/sonos-web-controller/node_modules/socket.io'
      uncaught	2016-09-20 17:58:14.916	error	exception: Cannot find module './node_modules/sonos-web-controller/node_modules/socket.io'
      host-ubuntu2cpu	2016-09-20 17:58:14.518	info	instance system.adapter.sonos.0 started with pid 32705
      Hier die Updatetable:
      update done
      Adapter    "zwave"         : 0.2.5
      Adapter    "yr"            : 1.0.4    , installed 1.0.4
      Adapter    "yamaha"        : 0.2.0
      Adapter    "wolf"          : 0.1.0
      Adapter    "web"           : 1.7.1    , installed 1.7.0 [Updateable]
      Adapter    "weatherunderground": 1.0.1
      Adapter    "vis-timeandweather": 1.1.4    , installed 1.1.4
      Adapter    "vis-rgraph"    : 0.0.2
      Adapter    "vis-plumb"     : 0.1.6
      Adapter    "vis-metro"     : 1.0.1
      Adapter    "vis-map"       : 0.1.3
      Adapter    "vis-lcars"     : 1.0.1    , installed 1.0.1
      Adapter    "vis-keyboard"  : 0.0.2
      Adapter    "vis-justgage"  : 0.6.0
      Adapter    "vis-jqui-mfd"  : 1.0.5    , installed 1.0.4 [Updateable]
      Adapter    "vis-hqwidgets" : 1.0.5    , installed 1.0.3 [Updateable]
      Adapter    "vis-history"   : 0.2.1
      Adapter    "vis-google-fonts": 0.1.0
      Adapter    "vis-fancyswitch": 1.0.0    , installed 1.0.0
      Adapter    "vis-colorpicker": 1.1.0
      Adapter    "vis-bars"      : 0.1.2
      Adapter    "vis"           : 0.10.11  , installed 0.10.9 [Updateable]
      Adapter    "vcard"         : 0.0.8
      Adapter    "tvspielfilm"   : 0.2.2
      Adapter    "text2command"  : 1.1.3
      Adapter    "terminal"      : 0.1.2
      Adapter    "telegram"      : 0.4.3
      Adapter    "tankerkoenig"  : 0.1.2
      Adapter    "starline"      : 0.1.7
      Adapter    "sonos"         : 0.1.10   , installed 0.1.10
      Adapter    "solarwetter"   : 0.1.2
      Adapter    "socketio"      : 1.7.0    , installed 1.7.0
      Adapter    "squeezebox"    : 0.1.0
      Adapter    "sql"           : 1.2.0    , installed 1.2.0
      Adapter    "simple-api"    : 1.3.0    , installed 1.3.0
      Adapter    "scenes"        : 0.2.6    , installed 0.2.6
      Adapter    "sayit"         : 1.0.0    , installed 1.0.0
      Adapter    "samsung"       : 0.0.10
      Adapter    "s7"            : 0.2.4
      Adapter    "rwe-smarthome" : 0.1.9
      Adapter    "rpi"           : 0.0.4
      Adapter    "rickshaw"      : 0.4.4    , installed 0.4.4
      Adapter    "pushover"      : 1.0.1
      Adapter    "pushbullet"    : 0.0.11
      Adapter    "ping"          : 1.1.1    , installed 1.1.1
      Adapter    "piface"        : 0.0.50
      Adapter    "phantomjs"     : 0.1.2
      Adapter    "owntracks"     : 0.1.1
      Adapter    "owfs"          : 0.3.4
      Adapter    "onkyo"         : 0.2.0
      Adapter    "occ"           : 0.2.4
      Adapter    "nut"           : 0.3.1
      Adapter    "noolite"       : 0.0.1
      Adapter    "node-red"      : 1.1.2
      Adapter    "netatmo"       : 0.4.0
      Adapter    "mysensors"     : 1.0.2
      Adapter    "mqtt-client"   : 0.3.0
      Adapter    "mqtt"          : 1.1.2
      Adapter    "modbus"        : 0.3.11
      Adapter    "mobile"        : 0.4.6
      Adapter    "miele"         : 0.0.16
      Adapter    "megad"         : 1.2.1
      Adapter    "lgtv"          : 0.0.4
      Adapter    "kodi"          : 0.1.2
      Adapter    "knx"           : 0.2.10
      Controller "js-controller" : 0.12.2   , installed 0.12.2
      Adapter    "javascript"    : 3.0.8    , installed 3.0.6 [Updateable]
      Adapter    "influxdb"      : 0.5.0
      Adapter    "icons-ultimate-png": 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.3
      Adapter    "icons-mfd-svg" : 1.0.0
      Adapter    "icons-mfd-png" : 1.0.0    , installed 1.0.0
      Adapter    "icons-material-svg": 0.1.0
      Adapter    "icons-material-png": 0.1.0
      Adapter    "icons-icons8"  : 0.0.1
      Adapter    "icons-addictive-flavour-png": 0.1.0
      Adapter    "ical"          : 1.2.0    , installed 1.2.0
      Adapter    "hmm"           : 1.0.1
      Adapter    "homepilot"     : 0.0.7
      Adapter    "homekit"       : 0.1.4
      Adapter    "hue"           : 0.5.8
      Adapter    "hm-rpc"        : 1.3.1    , installed 1.3.1
      Adapter    "hm-rega"       : 1.3.0    , installed 1.3.0
      Adapter    "history"       : 1.3.0    , installed 1.3.0
      Adapter    "harmony"       : 0.5.6
      Adapter    "geofency"      : 0.1.4
      Adapter    "fritzbox"      : 0.2.1
      Adapter    "feiertage"     : 0.3.2
      Adapter    "flot"          : 1.4.1    , installed 1.4.1
      Adapter    "fhem"          : 0.2.2
      Adapter    "epson_stylus_px830": 0.0.2
      Adapter    "email"         : 0.2.1    , installed 0.2.1
      Adapter    "dwd"           : 2.1.1    , installed 2.1.1
      Adapter    "cul"           : 0.0.4
      Adapter    "cloud"         : 0.1.0
      Adapter    "chromecast"    : 1.1.0
      Adapter    "botvac"        : 0.5.0
      Adapter    "b-control-em"  : 0.1.1
      Adapter    "artnet"        : 0.0.3
      Adapter    "amazon-dash"   : 0.0.5
      Adapter    "admin"         : 1.6.2    , installed 1.6.1 [Updateable]
      Deinstallieren und installieren des Sonos Adapter hat nicht geholfen. Node Version v4.4.7 auf Ubuntu.
      Kann es mit dem Web Adapter zusammenhängen?
      Ich habe gesehen es gibt Sonos 0.2, läuft es evtl. damit und wie kann ich es installieren, bekomme nur die 0.1.10 angezeigt.
      Danke und Gruß.
      • I
        iben last edited by
        Sonos 0.2.0 hat geholfen, installiert mit:
         ./iobroker url "https://github.com/ioBroker/ioBroker.sonos" --debug
        81.0k
