    4. js-controller 3.1.4 -> 3.1.5: javascript Adapter stürzt ab!
    UNSOLVED js-controller 3.1.4 -> 3.1.5: javascript Adapter stürzt ab!
      aski71 last edited by
      Javascript controller ist nicht mehr lauffähig nach js-controller Upgrade auf 3.1.5.
      Wer kann dringend helfen?
      Danke.
      2020-06-08 15:51:45.344  - error: host.homie Caught by controller[0]: internal/modules/cjs/loader.js:638
      2020-06-08 15:51:45.345  - error: host.homie Caught by controller[0]:     throw err;
      2020-06-08 15:51:45.347  - error: host.homie Caught by controller[0]:     ^
      2020-06-08 15:51:45.348  - error: host.homie Caught by controller[0]: Error: Cannot find module 'typescript'
      2020-06-08 15:51:45.351  - error: host.homie Caught by controller[0]:     at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
      2020-06-08 15:51:45.352  - error: host.homie Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:562:25)
      2020-06-08 15:51:45.354  - error: host.homie Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:692:17)
      2020-06-08 15:51:45.355  - error: host.homie Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
      2020-06-08 15:51:45.356  - error: host.homie Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
      2020-06-08 15:51:45.357  - error: host.homie Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
      2020-06-08 15:51:45.358  - error: host.homie Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      2020-06-08 15:51:45.360  - error: host.homie Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
      2020-06-08 15:51:45.362  - error: host.homie Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      2020-06-08 15:51:45.363  - error: host.homie Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      2020-06-08 15:51:45.365  - error: host.homie Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:692:17)
      2020-06-08 15:51:45.366  - error: host.homie Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
      2020-06-08 15:51:45.367  - error: host.homie Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
      2020-06-08 15:51:45.368  - error: host.homie Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
      2020-06-08 15:51:45.369  - error: host.homie Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      2020-06-08 15:51:45.371  - error: host.homie Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
      2020-06-08 15:51:45.372  - error: host.homie Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      2020-06-08 15:51:45.374  - error: host.homie Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      2020-06-08 15:51:45.375  - error: host.homie Caught by controller[0]:     at Module.require (internal/modules/cjs/loader.js:692:17)
      2020-06-08 15:51:45.376  - error: host.homie Caught by controller[0]:     at require (internal/modules/cjs/helpers.js:25:18)
      2020-06-08 15:51:45.377  - error: host.homie Caught by controller[0]:     at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      2020-06-08 15:51:45.379  - error: host.homie Caught by controller[0]:     at Module._compile (internal/modules/cjs/loader.js:778:30)
      2020-06-08 15:51:45.381  - error: host.homie Caught by controller[0]:     at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      2020-06-08 15:51:45.383  - error: host.homie Caught by controller[0]:     at Module.load (internal/modules/cjs/loader.js:653:32)
      2020-06-08 15:51:45.384  - error: host.homie Caught by controller[0]:     at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      2020-06-08 15:51:45.385  - error: host.homie Caught by controller[0]:     at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      2020-06-08 15:51:45.387  - error: host.homie Caught by controller[0]:     at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
      2020-06-08 15:51:45.388  - error: host.homie Caught by controller[0]:     at startup (internal/bootstrap/node.js:283:19)
      2020-06-08 15:51:45.389  - error: host.homie Caught by controller[0]:     at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      • AlCalzone
        AlCalzone Developer @aski71 last edited by AlCalzone
        @aski71
        cd /opt/iobroker/node_modules/iobroker.javascript
        npm install --production
        Bei einem normalen Update dürften aber nicht einfach so Module verschwinden. Da muss irgendwas schwer schiefgelaufen sein.
          Scheint so, aber was?! 🤔
            Danke jedenfalls für den Tipp. Jetzt läuft es wieder.
              simpixo last edited by simpixo
              Das gleiche Problem hatte ich auch. Dein Tip hat geholfen 👍
              Gruss
              Adrian
              • AlCalzone
                @all: Das Problem hat ne andere Ursache. npm verschiebt ein Modul, welches nicht verschoben werden dürfte. Der JavaScript-Adapter der nächsten Version wird hier dafür sorgen, dass dieses Modul trotzdem arbeiten kann.
                javascript
