    4. Fehler- Hinweismeldungen bei Adapterupdates
    UNSOLVED Fehler- Hinweismeldungen bei Adapterupdates
    • surfer09
      surfer09 last edited by
      ich habe jetzt schon länger beobachtet, dass ich bei Adapter-Updates immer wieder Fehler- bzw. Hinweismeldungen bekomme.
      2020-06-12 19:56:20.194 - info: host.IO-Broker-Server iobroker upgrade simple-api
      2020-06-12 19:56:21.313 - info: host.IO-Broker-Server iobroker Update simple-api from @2.4.5 to @2.4.6
      2020-06-12 19:56:21.319 - info: host.IO-Broker-Server iobroker host.IO-Broker-Server Adapter "system.adapter.simple-api.0" is stopped.
      2020-06-12 19:56:21.325 - info: host.IO-Broker-Server "system.adapter.simple-api.0" disabled
      2020-06-12 19:56:21.326 - info: host.IO-Broker-Server stopInstance system.adapter.simple-api.0 (force=false, process=true)
      2020-06-12 19:56:21.326 - info: host.IO-Broker-Server stopInstance system.adapter.simple-api.0 send kill signal
      2020-06-12 19:56:21.328 - info: simple-api.0 (11696) Got terminate signal TERMINATE_YOURSELF
      2020-06-12 19:56:21.332 - info: simple-api.0 (11696) terminating http server on port 8087
      2020-06-12 19:56:21.333 - info: simple-api.0 (11696) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2020-06-12 19:56:21.859 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2020-06-12 19:56:21.944 - info: host.IO-Broker-Server iobroker NPM version: 6.13.4
      2020-06-12 19:56:21.945 - info: host.IO-Broker-Server iobroker npm install iobroker.simple-api@2.4.6 --loglevel error (System call)
      2020-06-12 19:56:47.986 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:47.989 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:47.990 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:47.991 - info: host.IO-Broker-Server iobroker build error
      2020-06-12 19:56:47.992 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:47.994 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:47.995 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:47.996 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:47.997 - info: host.IO-Broker-Server iobroker stack
      2020-06-12 19:56:48.001 - info: host.IO-Broker-Server iobroker Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
      2020-06-12 19:56:48.001 - info: host.IO-Broker-Server iobroker gyp ERR! stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)gyp
      2020-06-12 19:56:48.002 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.002 - info: host.IO-Broker-Server iobroker ERR! stack
      2020-06-12 19:56:48.003 - info: host.IO-Broker-Server iobroker at ChildProcess.emit (events.js:311:20)
      2020-06-12 19:56:48.004 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:48.005 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.006 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.007 - info: host.IO-Broker-Server iobroker stack
      2020-06-12 19:56:48.008 - info: host.IO-Broker-Server iobroker at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      2020-06-12 19:56:48.009 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:48.010 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.010 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.011 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.012 - info: host.IO-Broker-Server iobroker System
      2020-06-12 19:56:48.012 - info: host.IO-Broker-Server iobroker Windows_NT 10.0.19041
      2020-06-12 19:56:48.013 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:48.014 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.014 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.015 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.015 - info: host.IO-Broker-Server iobroker command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      2020-06-12 19:56:48.016 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:48.016 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.017 - info: host.IO-Broker-Server iobroker cwd I:\iobroker\node_modules\mdnsgyp
      2020-06-12 19:56:48.017 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.018 - info: host.IO-Broker-Server iobroker node -v
      2020-06-12 19:56:48.018 - info: host.IO-Broker-Server iobroker v12.16.1gyp
      2020-06-12 19:56:48.019 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:56:48.019 - info: host.IO-Broker-Server iobroker ERR! node-gyp -v
      2020-06-12 19:56:48.019 - info: host.IO-Broker-Server iobroker v5.0.5
      2020-06-12 19:56:48.020 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:56:48.020 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:56:48.020 - info: host.IO-Broker-Server iobroker not ok
      2020-06-12 19:56:49.726 - info: host.IO-Broker-Server iobroker upload [3] simple-api.admin I:/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
      2020-06-12 19:56:49.746 - info: host.IO-Broker-Server iobroker Update "system.adapter.simple-api.0"
      2020-06-12 19:56:49.817 - info: host.IO-Broker-Server iobroker upload [2] simple-api.admin I:/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
      2020-06-12 19:56:49.879 - info: host.IO-Broker-Server iobroker upload [1] simple-api.admin I:/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
      2020-06-12 19:56:49.942 - info: host.IO-Broker-Server iobroker upload [0] simple-api.admin I:/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
      2020-06-12 19:56:50.004 - info: host.IO-Broker-Server iobroker Adapter "simple-api" updated
      2020-06-12 19:56:50.006 - info: host.IO-Broker-Server iobroker host.IO-Broker-Server Adapter "system.adapter.simple-api.0" is started
      2020-06-12 19:56:50.015 - info: host.IO-Broker-Server "system.adapter.simple-api.0" enabled
      2020-06-12 19:56:50.035 - info: host.IO-Broker-Server instance system.adapter.simple-api.0 started with pid 8380
      2020-06-12 19:56:50.582 - info: simple-api.0 (8380) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2020-06-12 19:56:50.587 - info: simple-api.0 (8380) starting. Version 2.4.6 in I:/iobroker/node_modules/iobroker.simple-api, node: v12.16.1, js-controller: 3.1.5
      2020-06-12 19:56:50.602 - info: simple-api.0 (8380) simpleAPI server listening on port 8087
      2020-06-12 19:56:50.603 - info: simple-api.0 (8380) Allow states only when user is owner: false
      2020-06-12 19:56:50.605 - info: simple-api.0 (8380) http server listening on port 8087
      2020-06-12 19:56:51.046 - info: host.IO-Broker-Server iobroker exit 0
      2020-06-12 19:56:56.726 - info: host.IO-Broker-Server iobroker upgrade sayit
      2020-06-12 19:56:57.933 - info: host.IO-Broker-Server iobroker Update sayit from @1.9.6 to @1.9.8
      2020-06-12 19:56:58.601 - info: host.IO-Broker-Server iobroker NPM version: 6.13.4
      2020-06-12 19:56:58.602 - info: host.IO-Broker-Server iobroker npm install iobroker.sayit@1.9.8 --loglevel error (System call)
      2020-06-12 19:57:27.960 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.961 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.962 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.963 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.964 - info: host.IO-Broker-Server iobroker build error
      2020-06-12 19:57:27.965 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.966 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.967 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.970 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.971 - info: host.IO-Broker-Server iobroker stack
      2020-06-12 19:57:27.971 - info: host.IO-Broker-Server iobroker Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
      2020-06-12 19:57:27.973 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.974 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.974 - info: host.IO-Broker-Server iobroker stack at ChildProcess.onExit (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\build.js:194:23)
      2020-06-12 19:57:27.975 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.976 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.978 - info: host.IO-Broker-Server iobroker stack
      2020-06-12 19:57:27.979 - info: host.IO-Broker-Server iobroker at ChildProcess.emit (events.js:311:20)
      2020-06-12 19:57:27.982 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.983 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.987 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.988 - info: host.IO-Broker-Server iobroker stack
      2020-06-12 19:57:27.988 - info: host.IO-Broker-Server iobroker at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      2020-06-12 19:57:27.989 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.989 - info: host.IO-Broker-Server iobroker ERR! System Windows_NT 10.0.19041gyp
      2020-06-12 19:57:27.990 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.990 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.990 - info: host.IO-Broker-Server iobroker command
      2020-06-12 19:57:27.991 - info: host.IO-Broker-Server iobroker "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
      2020-06-12 19:57:27.991 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.992 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.992 - info: host.IO-Broker-Server iobroker cwd
      2020-06-12 19:57:27.992 - info: host.IO-Broker-Server iobroker I:\iobroker\node_modules\mdns
      2020-06-12 19:57:27.993 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.993 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.994 - info: host.IO-Broker-Server iobroker node -v
      2020-06-12 19:57:27.994 - info: host.IO-Broker-Server iobroker v12.16.1
      2020-06-12 19:57:27.994 - info: host.IO-Broker-Server iobroker gyp
      2020-06-12 19:57:27.995 - info: host.IO-Broker-Server iobroker
      2020-06-12 19:57:27.995 - info: host.IO-Broker-Server iobroker ERR!
      2020-06-12 19:57:27.995 - info: host.IO-Broker-Server iobroker node-gyp -v
      2020-06-12 19:57:27.996 - info: host.IO-Broker-Server iobroker v5.0.5
      2020-06-12 19:57:27.996 - info: host.IO-Broker-Server iobroker gyp ERR!
      2020-06-12 19:57:27.997 - info: host.IO-Broker-Server iobroker not ok
      2020-06-12 19:57:28.708 - info: sayit.0 (8632) Plugin sentry Sentry Plugin disabled for this process because sending of statistic data is disabled for the system
      2020-06-12 19:57:28.713 - info: sayit.0 (8632) starting. Version 1.9.8 in I:/iobroker/node_modules/iobroker.sayit, node: v12.16.1, js-controller: 3.1.5
      2020-06-12 19:57:28.713 - info: sayit.0 (8632) Install process. Upload files and stop.
      2020-06-12 19:57:28.714 - info: sayit.0 (8632) Upload announce mp3 files
      2020-06-12 19:57:28.736 - info: sayit.0 (8632) All files uploaded
      2020-06-12 19:57:28.736 - info: sayit.0 (8632) stopping...
      2020-06-12 19:57:29.245 - info: sayit.0 (8632) Terminated (NO_ERROR): Without reason
      2020-06-12 19:57:29.749 - info: sayit.0 (8632) stopping...
      2020-06-12 19:57:30.974 - info: host.IO-Broker-Server iobroker upload [15] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/words.js words.js application/javascript
      2020-06-12 19:57:31.064 - info: host.IO-Broker-Server iobroker upload [14] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/sayit.png sayit.png image/png
      2020-06-12 19:57:31.127 - info: host.IO-Broker-Server iobroker upload [13] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/index_m.html index_m.html text/html
      2020-06-12 19:57:31.189 - info: host.IO-Broker-Server iobroker upload [12] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/index.html index.html text/html
      2020-06-12 19:57:31.252 - info: host.IO-Broker-Server iobroker upload [11] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
      2020-06-12 19:57:31.316 - info: host.IO-Broker-Server iobroker upload [10] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
      2020-06-12 19:57:31.378 - info: host.IO-Broker-Server iobroker upload [9] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
      2020-06-12 19:57:31.441 - info: host.IO-Broker-Server iobroker upload [8] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
      2020-06-12 19:57:31.503 - info: host.IO-Broker-Server iobroker upload [7] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
      2020-06-12 19:57:31.567 - info: host.IO-Broker-Server iobroker upload [6] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/it/translations.json i18n/it/translations.json application/json
      2020-06-12 19:57:31.630 - info: host.IO-Broker-Server iobroker upload [5] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
      2020-06-12 19:57:31.692 - info: host.IO-Broker-Server iobroker upload [4] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/es/translations.json i18n/es/translations.json application/json
      2020-06-12 19:57:31.755 - info: host.IO-Broker-Server iobroker upload [3] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/en/translations.json i18n/en/translations.json application/json
      2020-06-12 19:57:31.819 - info: host.IO-Broker-Server iobroker upload [2] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/i18n/de/translations.json i18n/de/translations.json application/json
      2020-06-12 19:57:31.882 - info: host.IO-Broker-Server iobroker upload [1] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/engines.js engines.js application/javascript
      2020-06-12 19:57:31.944 - info: host.IO-Broker-Server iobroker upload [0] sayit.admin I:/iobroker/node_modules/iobroker.sayit/admin/blockly.js blockly.js application/javascript
      2020-06-12 19:57:32.006 - info: host.IO-Broker-Server iobroker Adapter "sayit" updated
      2020-06-12 19:57:33.023 - info: host.IO-Broker-Server iobroker exit 0
      Hier habe ich mal den Sayit Adapter geupdatet und im LOG meine ich spezielle die Zeilen 14-60. Manchmal tauchen diese Meldungen auch mehrfach beim Update auf, das Adapter-Update an sich funktioniert jedoch. Kann mir vielleicht jemand erläutern, ob ich etwas machen muss, damit diese Meldungen nicht mehr auftreten?
      Solange die Updates funktionieren, habe ich eigentlich keine Bauchschmerzen, aber ich möchte eigentlich ungern, dass mir das an anderer Stelle mal auf die Füßre fällt.
      Zum System: Windows 10 64bit, js-Controller 3.1.5, Node 12.16.1, NPM 6.13.4
      Gruß surfer 😉
      log windows 10
