    4. Pythonfehler beim Update der Adapter
    UNSOLVED Pythonfehler beim Update der Adapter
      Joker971 last edited by
      neuerdings bekomme ich beim updaten meiner Adapter folgendes im Log angezeigt, hier jetzt beispielhaft beim Tradfri Adapter, aber spielt keine Rolle da es bei allen Adaptern angezeigt wird:
      ERR! find Python gyp ERR! find Python Python is not set from command line or npm configurationgyp ERR! find Python Python is not set from environment variable PYTHONgyp ERR! find Python checking if "python" can be usedgyp ERR! find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR!
      find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR!
      find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR!
      find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp
      ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR!
      find Python gyp ERR! find Python **********************************************************gyp ERR!
      find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp
      ERR! find Python - Set the environment variable PYTHONgyp
      ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"
      gyp ERR! find Python For more information consult the documentation at:gyp
      ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR!
      find Python
      gyp
      ERR! configure error gyp ERR! stack Error: Could not find any Python installation to usegyp ERR!
      stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp
      ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR!
      stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:301:5)
      gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp ERR!
      stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:246:12)
      gyp ERR! stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR!
      stack     at process._tickCallback (internal/process/next_tick.js:63:19)gyp ERR! System Windows_NT 6.1.7601
      gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\diskusage
      gyp ERR! node -v v10.18.0gyp ERR!
      node-gyp -v v5.0.5gyp ERR! not ok
      gyp
      find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR!
      find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR!
      find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR! find Python gyp ERR! find Python **********************************************************gyp ERR! find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp ERR! find Python - Set the environment variable PYTHONgyp ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"gyp ERR! find Python For more information consult the documentation at:gyp ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR! find Python
      gyp
      gyp ERR! stack Error: Could not find any Python installation to usegyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
      gyp ERR! stack     at exithandler (child_process.js:301:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp
      ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:246:12)gyp ERR! stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR!
      gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\mdnsgyp ERR! node -v v10.18.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
      gyp
      find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR! find Python
      - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python
      gyp ERR!
      ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:301:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp
      stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR! stack     at process._tickCallback (internal/process/next_tick.js:63:19)gyp
      gyp ERR! cwd C:\ioBroker\node_modules\unix-dgramgyp ERR! node -v v10.18.0gyp
      Update "system.adapter.tradfri.0"
      upload [20] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/remote_dimmer.png icons/remote_dimmer.png image/png
      upload [19] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/remote.png icons/remote.png image/png
      upload [18] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/plug.png icons/plug.png image/png
      upload [17] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel_ws.png icons/panel_ws.png image/png
      upload [16] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel_rgb.png icons/panel_rgb.png image/png
      upload [15] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel.png icons/panel.png image/png
      upload [14] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/motion_sensor.png icons/motion_sensor.png image/png
      upload [13] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/gu10_ws.png icons/gu10_ws.png image/png
      upload [12] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/gu10_2700k.png icons/gu10_2700k.png image/png
      Trotz der angezeigten Pythonfehler ist das update immer erfolgreich und alle Adapter laufen Problemlos aber irgendwie nervt das. Soweit ich weiss ist Python auch nicht explizit auf meinem Windows installiert. Zudem kommen diese Fehler auch erst seit kurzer Zeit.
      python
