    4. GELÖST: Nach Update javascript ROT
    UNSOLVED GELÖST: Nach Update javascript ROT
      ChrisXY last edited by ChrisXY
      Edit:
      Problem behoben mit:
      cd /opt/iobroker/node_modules/iobroker.javascript
      npm install --production
      heute morgen iobroker selbst geupdatet. Danach auch der FIX... aber javascript bleibt rot
      host.iobroker	2020-06-14 06:47:16.442	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at startup (internal/bootstrap/node.js:283:19)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:35:24)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.iobroker	2020-06-14 06:47:16.441	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/index.js:3:18)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.iobroker	2020-06-14 06:47:16.440	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/virtual-tsc/build/compiler.js:3:10)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:562:25)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: Error: Cannot find module 'typescript'
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: ^
      host.iobroker	2020-06-14 06:47:16.439	error	Caught by controller[0]: throw err;
      host.iobroker	2020-06-14 06:47:16.438	error	Caught by controller[0]: internal/modules/cjs/loader.js:638
      Soundy 1 Reply Last reply Reply Quote 0
      • Soundy
        Soundy @ChrisXY last edited by
        @chrisxy
        nach Updates von ioBroker hatte ich selbiges Problem und konnte mit diesem Tipp das Problem lösen. Jetzt habe ich im Protokoll nurmehr diese Warnung:
        javascript.0 2022-07-15 16:28:39.092	error	WARN config production Use `--omit=dev` instead.
        javascript.0 2022-07-15 16:28:39.090	error	npm
        Ich lass es aber mal lieber, bevor ich mir irgendwas verballere. 🙂 Eigentlich könnte ich
        npm install --omit=dev
        machen, aber dafür habe ich zu viel Angst, dass ich mir ioBroker zerknalle. Momentan fehlt mir auch die Zeit, dass ich mich ggf. mit einer langwierigen Fehlersuche oder sogar eine Neuinstallation beschäftige. 😉
        Danke und Lg, Jürgen
        Thomas Braun Glasfaser 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @Soundy last edited by Thomas Braun
          @soundy sagte in GELÖST: Nach Update javascript ROT:
          javascript.0 2022-07-15 16:28:39.092	error	WARN config production Use --omit=dev instead.
          Das ist nur ein (zu kurzer) Ausschnitt des Logs. Ich vermute, die Meldungen kommen im Zusammenhang mit zusätzlich im javascript-Adapter eingetragenen Modules und npm>6.
          Sind dann harmlos und können überlesen werden.
          • Glasfaser
            Glasfaser @Soundy last edited by Glasfaser
            bezieht sich das auch hierzu , in einem neuen Thread !?
            https://forum.iobroker.net/topic/56426/fehler-file-tab-html-not-found-bei-menüpunkt-skripte
            javascript update
