    4. Fehler Zigbee Stick
    Fehler Zigbee Stick
      lustig29 last edited by
      kann mir jemand sagen was es mit diesem Fehler auf sich hat und wie ich ihn abstellen kann? Hänge mal einen Auszug aus dem Log an, vielleicht hilft es ja.
      (2956) Zigbee started
      zigbee.0 2020-06-15 16:41:34.689 info (2956) 0x00158d00045dc6fa (addr 44675): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
      zigbee.0 2020-06-15 16:41:34.686 info (2956) 0x00158d0003cd921c (addr 5952): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0 2020-06-15 16:41:34.683 info (2956) 0x00158d0003d01885 (addr 30432): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      zigbee.0 2020-06-15 16:41:34.679 info (2956) 0x00158d0003d01800 (addr 45139): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
      zigbee.0 2020-06-15 16:41:34.676 info (2956) 0x00158d0002b7ceec (addr 14799): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
      zigbee.0 2020-06-15 16:41:34.668 info (2956) Currently 5 devices are joined:
      zigbee.0 2020-06-15 16:41:34.633 info (2956) --> transmitPower : normal
      zigbee.0 2020-06-15 16:41:34.601 info (2956) Coordinator firmware version: {"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190619}}
      zigbee.0 2020-06-15 16:41:32.705 info (2956) Starting Zigbee...
      zigbee.0 2020-06-15 16:41:32.700 error (2956) Serial port not selected! Go to settings page.
      zigbee.0 2020-06-15 16:41:32.639 info (2956) starting. Version 1.0.4 in /opt/iobroker/node_modules/iobroker.zigbee, node: v12.18.0, js-controller: 3.1.4
      host.raspberrypi 2020-06-15 16:41:29.442 info instance system.adapter.zigbee.0 started with pid 2956
      host.raspberrypi 2020-06-15 16:40:59.359 info Restart adapter system.adapter.zigbee.0 because enabled
      host.raspberrypi 2020-06-15 16:40:59.344 info instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      zigbee.0 2020-06-15 16:40:58.733 info (2939) Terminated (NO_ERROR): Without reason
      zigbee.0 2020-06-15 16:40:58.731 info (2939) terminating
      zigbee.0 2020-06-15 16:40:58.671 info (2939) Zigbee: disabling joining new devices.
      zigbee.0 2020-06-15 16:40:58.667 info (2939) cleaned everything up...
      zigbee.0 2020-06-15 16:40:58.665 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
      zigbee.0 2020-06-15 16:40:58.665 error at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:199:19)
      zigbee.0 2020-06-15 16:40:58.665 error at Array.forEach (<anonymous>)
      zigbee.0 2020-06-15 16:40:58.665 error at /opt/iobroker/node_modules/iobroker.zigbee/main.js:213:95
      zigbee.0 2020-06-15 16:40:58.665 error (2939) ReferenceError: stateKey is not defined
      zigbee.0 2020-06-15 16:40:58.664 error (2939) unhandled promise rejection: stateKey is not defined
      Unhandled 2020-06-15 16:40:58.662 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().zigbee.0 2020-06-15 16:30:38.175 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
      zigbee.0 2020-06-15 16:30:38.175 error at runMicrotasks (<anonymous>)
      zigbee.0 2020-06-15 16:30:38.175 error at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:199:19)
      zigbee.0 2020-06-15 16:30:38.175 error at Array.forEach (<anonymous>)
      zigbee.0 2020-06-15 16:30:38.175 error at /opt/iobroker/node_modules/iobroker.zigbee/main.js:213:95
      zigbee.0 2020-06-15 16:30:38.175 error (1805) ReferenceError: stateKey is not defined
      zigbee.0 2020-06-15 16:30:38.174 error (1805) unhandled promise rejection: stateKey is not defined
      Unhandled 2020-06-15 16:30:38.172 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        bob der 1. @lustig29 last edited by bob der 1.
        @lustig29
        Was ich lese.
        Dein Port stimmt nicht.
          lustig29 @bob der 1. last edited by
          @bob-der-1 Stick funktioniert ja, wenn auch nur teilweise. Startet öfters neu und heute Nacht hat sich mein Led Stripe selbstständig eingeschaltet. Wie kann ich denn das Problem beheben?
            @lustig29
            Bin da kein Profi,da ich den unproblematischen Conbee 2 Stick nutze.
            Ich würde nun einfach den Adapter Löschen und dann erst mal da sehen.....wenn es nicht besser wird.....Stick rauswerfen bzw. Mal nach der Firmware sehen ob die Up to date ist.
            Wenn das nicht hilft selektieren wie weit die Geräte auseinander sind wg. Empfangsproblemen etc.
            Das mit dem Port würde ich eben als Indiz sehen das es am Adapter liegt.
              @lustig29 sagte in Fehler Zigbee Stick:
              Version 1.0.4 i
              installiere bitte die Version 1.1.1 von GIT..
              L LichtAn 2 Replies Last reply Reply Quote 0
                lustig29 @arteck last edited by
                @arteck hast du Mal den Link für mich da?
                • Glasfaser
                  Glasfaser @lustig29 last edited by Glasfaser
                  @lustig29
                  https://github.com/ioBroker/ioBroker.zigbee
                  Hinweis:
                  Link Text
                    lustig29 @Glasfaser last edited by
                    @Glasfaser super, danke. Irgendwie hab ich das Gefühl, er wird nicht richtig installiert. Unter dem Adaptern wird mir angezeigt, dass die Version 1.1 installiert. Bei den Instanzen taucht allerdings nichts auf
                    Glasfaser Meister Mopper 2 Replies Last reply Reply Quote 0
                    • Glasfaser
                      @lustig29
                      Du hast Ihn doch zuvor als Version 1.04 gehabt (dein Log ) , hast du Ihn zuvor gelöscht !?
                      Du solltest doch nur ein Update machen .
                      • Meister Mopper
                        Meister Mopper @lustig29 last edited by Meister Mopper
                        @lustig29 Du hast über github den Adapter installiert. Jetzt musst Du noch eine Instanz des Adapters installieren.
                          Adapter läuft jetzt wieder. Nun kommt folgender Fehler im Log:
                          1. No converter available for 'lumi.sensor_motion' with key 'occupancy'
                            Andre R. last edited by
                            Hat schon jemand ne Lösung hab das geiche Problem mit 2 BWM.
                            • LichtAn
                              LichtAn @arteck last edited by
                              @arteck
                              Hab seit gestern auch 2 neue Bewegungsmelder und bekomme auch diese Meldung.
                              (14535) No converter available for 'RTCGQ11LM' with key 'occupancy'
                              Hab den CC2538 + CC259 Stick von dimaiv
                              Adapter ist der aktuelle 1.2.1
                              Hab die Teile jetzt schon mal gelöscht und neu gepairt. Hat aber nix gebracht. Was mir aufgefallen ist das der BW ewig um pairen braucht. Bin ich seit der der Version mit dem herdsman Converter gar nicht mehr gewohnt. Sonst geht Pairen immer innerhalb von Sekunden.
                                arteck Developer Most Active @LichtAn last edited by
                                @LichtAn sagte in Fehler Zigbee Stick:
                                na einfach so kommt die meldung nicht
                                zigbee
                                1201
