    4. Sending messages to iobroker instance
    • I
      iobroker-6043 last edited by
      Hello community
      I have my NodeMCU sketch up and running. In the serial monitor it looks ok, but the controller (iobroker with mysensors instance)
      does not receive any messages. I can read the temperature, but then the sketch runs into an exception and does a stack trace.
      ?? Best regards and any help is appreciated.
      connected with ho….., channel 1
      dhcp client start...
      chg_B1:-40
      .ip:192.168.1.103,mask:255.255.0.0,gw:192.168.1.1
      .IP: 192.168.1.103
      –------------------------------------------>Temperature for the device 1 (index 0) is: 24.00
      Fatal exception 9(LoadStoreAlignmentCause):
      epc1=0x402026c0, epc2=0x00000000, epc3=0x00000000, excvaddr=0x0000002f, depc=0x00000000
      Exception (9):
      epc1=0x402026c0 epc2=0x00000000 epc3=0x00000000 excvaddr=0x0000002f depc=0x00000000
      ctx: cont
      sp: 3ffef410 end: 3ffef680 offset: 01a0
      stack>>>
      3ffef5b0: 3ffef600 3ffee638 00000008 40205ca0
      3ffef5c0: 3ffe8750 00000000 000000ff 40207270
      3ffef5d0: ffffffff 00000080 3ffee638 00000004
      3ffef5e0: 000000e7 3ffef990 3ffef6f8 3ffee650
      3ffef5f0: 3fffdad0 3ffef70f 3ffef6f8 402039c8
      3ffef600: 3ffef710 00000000 3ffef6cc 40204095
      3ffef610: 3fffdad0 00000000 00000006 40202336
      3ffef620: 3ffe892c 3ffee61c 3fff0d6c 3ffee650
      3ffef630: 3fffdad0 00000000 00000005 40204365
      3ffef640: 3fffdad0 00000000 3ffee5f0 402044f5
      3ffef650: 00000000 00000000 3ffee5f0 40204720
      3ffef660: 3fffdad0 00000000 3ffee5f0 4020474c
      3ffef670: feefeffe feefeffe 3ffee660 40100114
      <<<stack<<<< r=""></stack<<<<>
      • I
        unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)
        OneWire oneWire(ONE_WIRE_BUS); // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
        DallasTemperature sensors(&oneWire); // Pass the oneWire reference to Dallas Temperature.
        float lastTemperature[MAX_ATTACHED_DS18B20];
        int numSensors=0;
        bool receivedConfig = false;
        bool metric = true;
        // Initialize temperature message
        MyMessage msg(0,V_TEMP);
        ! void setup()
        // Startup up the OneWire library
        sensors.begin();
        // requestTemperatures() will not block current thread
        sensors.setWaitForConversion(false);
        ! void presentation() {
        // Send the sketch version information to the gateway and Controller
        // sendSketchInfo("Temperature Sensor", "1.1");
        // Fetch the number of attached temperature sensors
        numSensors = sensors.getDeviceCount();
        // Present all sensors to controller
        present(0, S_TEMP);
        ! void loop()
        // Fetch temperatures from Dallas sensors
        sensors.requestTemperatures();
        Serial.print("-------------------------------------------->Temperature for the device 1 (index 0) is: ");
        Serial.println(sensors.getTempCByIndex(0));
