    4. Homekit Verbindungs Abbrüche
      bz7i last edited by
      Moin,
      habe mir Heute, auf meinen RaspberryPi, den HomeKit Adapter installiert.
      Nach einigen Anlaufschwierigkeiten, läuft es jetzt einigermaßen. Das einzige Problem welches Ich noch habe,
      das die Verbindung hin und wieder abbricht.
      host-raspberrypi	2016-10-02 19:15:56.721	info	Restart adapter system.adapter.homekit.0 because enabled
      host-raspberrypi	2016-10-02 19:15:56.720	error	instance system.adapter.homekit.0 terminated with code 0 (OK)
      TypeError:	2016-10-02 19:15:56.647	error	at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
      TypeError:	2016-10-02 19:15:56.647	error	at HAPServer.emit (events.js:175:7)
      TypeError:	2016-10-02 19:15:56.647	error	at emitThree (events.js:97:13)
      TypeError:	2016-10-02 19:15:56.647	error	at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
      TypeError:	2016-10-02 19:15:56.647	error	at Array.forEach (native)
      TypeError:	2016-10-02 19:15:56.647	error	at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
      TypeError:	2016-10-02 19:15:56.647	error	at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
      TypeError:	2016-10-02 19:15:56.647	error	at emit (events.js:172:7)
      TypeError:	2016-10-02 19:15:56.647	error	at emitTwo (events.js:87:13)
      TypeError:	2016-10-02 19:15:56.647	error	at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
      TypeError:	2016-10-02 19:15:56.647	error	Cannot read property 'val' of undefined
      uncaught	2016-10-02 19:15:56.639	error	exception: Cannot read property 'val' of undefined
      homekit-0	2016-10-02 19:15:53.616	info	Bridge 'ioBroker Bridge' successfully published
      homekit-0	2016-10-02 19:15:52.964	info	hap-nodejs starting...
      homekit-0	2016-10-02 19:15:50.128	info	starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
      host-raspberrypi	2016-10-02 19:15:46.564	info	instance system.adapter.homekit.0 started with pid 4362
      host-raspberrypi	2016-10-02 19:15:16.533	info	Restart adapter system.adapter.homekit.0 because enabled
      Ich vermute es hängt mit den CUxD Objekten zusammen. Kann mir da jemand helfen ??
      Gruß Sebastian
        bz7i last edited by
        Moin,
        hab es hinbekommen. Habe alle meine Geräte, die noch nicht in den HomeKit Adapter settings aufgelistet waren, besten gewissens hinzugefügt.
        Gut möglich das Ich das Falsch interprtiert habe. Wäre über jede Fehler inc. Erklärung dankbar. Aber so funktioniert es vorerst.
        Switch	State	HM-LC-Sw1-FM		 .STATE
        Switch	State	HM-LC-Sw2-FM		 .STATE
        Switch	State	HM-LC-Sw4-DR		 .STATE
        Switch	State	HM-LC-Sw1-Pl		 .STATE
        Switch	State	HM-LC-Sw4-PCB		.STATE
        Switch	State	HM-MOD-Re-8		  .STATE
        Switch	State	HM-LC-Sw4-Ba-PCB	.STATE
        Switch	State	HM-LC-Dim1T-CV	  1.LEVEL
        Switch	State	HM-LC-Dim1L-CV	  .LEVEL
        Switch	State	HM-RC-P1			  .LEVEL
        Switch	State	HM-Sec-SCo		   1.STATE
        Switch	State	HM-SCI-3-FM		  .STATE
        Switch	State	HM-LC-Bl1PBU-FM	 1.LEVEL
        Switch	State	HM-RC-2-PBU-FM	  1.PRESS_SHORT
        Switch	State	HM-PB-2-FM		   1.PRESS_SHORT
        Switch	State	HM-Sen-EP		    .STATE
        Switch	State	HM-RCV-50		    .LEVEL
        Thermostat	CurrentTemperature	HM-CC-TC	1.TEMPERATURE
        Thermostat	CurrentTemperature	BC-RT-TRX-CyG-3	1.ACTUAL_TEMPERATURE
        Thermostat	CurrentTemperature	HM-CC-RT-DN	4.ACTUAL_TEMPERATURE
        Thermostat	CurrentTemperature	OpenWeatherMap	1.TEMPERATURE
        Thermostat	CurrentTemperature	HM-WDS10-TH-O	1.TEMPERATURE
        Thermostat	TargetTemperature	HM-CC-TC	2.SETPOINT
        Thermostat	TargetTemperature	BC-RT-TRX-CyG-3	1.SET_TEMPERATURE
        Thermostat	TargetTemperature	HM-CC-RT-DN	4.SET_TEMPERATURE
        Thermostat	State	HM-CC-TC	2.STATE
        Thermostat	CurrentRelativeHumidity	HM-CC-TC	1.HUMIDITY
        Thermostat	CurrentRelativeHumidity	OpenWeatherMap	1.HUMIDITY
        Thermostat	CurrentRelativeHumidity	HM-WDS10-TH-O	1.HUMIDITY
        Temperature	CurrentTemperature	OpenWeatherMap	1.TEMPERATURE
        Temperature	CurrentTemperature	HM-WDS10-TH-O	1.TEMPERATURE
        Humidity	CurrentRelativeHumidity	OpenWeatherMap	1.HUMIDITY
        Humidity	CurrentRelativeHumidity	HM-WDS10-TH-O	1.HUMIDITY
