    4. Probleme mit Bluetooth Adapter
    UNSOLVED Probleme mit Bluetooth Adapter
      raspberry last edited by Negalein
      |Hardwaresystem:| NUC
      |Arbeitsspeicher:| 4GB |
      |Festplattenart:| SSD/HDD |
      |Betriebssystem:| Ubuntu
      |Node-Version:| 12.18.2
      |Nodejs-Version:| 8.10.0
      |NPM-Version:| 6.14.5
      |Installationsart:| Skript
      |Image genutzt:| Nein |
      ich habe folgendes Problem mit dem BLE Adapter. Wenn ich versuche ihn zu starten erscheint folgendes im Log.
      ble.0	2020-07-06 00:41:57.442	info	(14856) Terminated (NO_ERROR): Without reason
      ble.0	2020-07-06 00:41:57.441	info	(14856) terminating
      ble.0	2020-07-06 00:41:57.431	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
      ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:8147:76
      ble.0	2020-07-06 00:41:57.431	error	at Object.ready (/opt/iobroker/node_modules/iobroker.ble/build/main.js:39:18)
      ble.0	2020-07-06 00:41:57.431	error	at __awaiter (/opt/iobroker/node_modules/iobroker.ble/build/main.js:4:12)
      ble.0	2020-07-06 00:41:57.431	error	at new Promise (<anonymous>)
      ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:8:71
      ble.0	2020-07-06 00:41:57.431	error	at Generator.next (<anonymous>)
      ble.0	2020-07-06 00:41:57.431	error	at /opt/iobroker/node_modules/iobroker.ble/build/main.js:43:39
      ble.0	2020-07-06 00:41:57.431	error	at new ObjectCache (/opt/iobroker/node_modules/iobroker.ble/build/lib/object-cache.js:25:33)
      ble.0	2020-07-06 00:41:57.431	error	(14856) TypeError: sorted_list_1.SortedList is not a constructor
      ble.0	2020-07-06 00:41:57.429	error	(14856) unhandled promise rejection: sorted_list_1.SortedList is not a constructor
      Unhandled	2020-07-06 00:41:57.429	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      ble.0	2020-07-06 00:41:57.416	info	(14856) starting. Version 0.11.6 in /opt/iobroker/node_modules/iobroker.ble, node: v12.18.2, js-controller: 3.1.6
      Ich vermute es liegt am Update auf node 12.18.2, aber eigentlich sollte es damit keine Probleme geben.
      Der Bluetooth Dongle funktioniert, wenn ich damit nach Geräten über die Konsole scanne.
      Der "fixer" oder Neuinstallation des Adapters brachte keine Abhilfe.
        Thomas Braun Most Active @raspberry last edited by Thomas Braun
        @raspberry
        Wenn das stimmt, dann ist node falsch installiert. Die Versionen müssen gleich sein.
        Schau nach:
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        Konsolenausgaben bitte als Text in CodeTags </> hier rein
        • AlCalzone
          AlCalzone Developer last edited by AlCalzone
          Die Ursache ist zwar kein Node-Problem, sondern ein Problem mit dem Adapter bzw. einem installierten Modul - geradebiegen sollte man es aber.
          Zum eigentlichen Problem:
          Installiere mal den Adapter neu drüber, am besten nachdem ihr die Node-Versionen geradegezogen habt:
          cd /opt/iobroker
          npm i iobroker.ble
            Danke für die schnelle Hilfe.
            Es lag an der falschen Nodejs Version. Ich dachte diese würde auch mittel "n <version>" aktualisiert.
            Ich habe aber eine Anleitung gefunden Nodejs auch auf die 12.18.2 zu bringen und dann ble neu installiert, wie beschrieben. Jetzt geht alles wieder.
            Danke für die Tipps.
              @raspberry Mein Reden...
              Auf Ubuntu und sonstigen Debian-Derivativen am besten immer über den Paketmanager installieren. Was kommt denn jetzt bei
              herum?
              ble ble adapter error errorproblem
