    4. Iobroker, Wert von mysensors an CCU übergeben
    • I
      iobroker-6043 last edited by
      Hallo Community
      Kriege meine Temperaturwerde von mysensors/nodeMCU TempSensor.
      Möchte diesen Wert in eine CCU Systemvariable schreiben.
      setState('hm-rega.0.5237', '"mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP"/192_168_1_103.0.0_TEMP.V_TEMP/');
      "common": {
      "name": "192_168_1_103.0.0_TEMP.V_TEMP",
      "type": "string",
      "role": "value.temperature",
      "min": 0,
      "def": 0,
      "read": true,
      "write": false
      "native": {
      "ip": "192.168.1.103",
      "id": "0",
      "childId": "0",
      "subType": "S_TEMP",
      "varType": "V_TEMP",
      "subTypeNum": 6,
      "varTypeNum": 0
      "acl": {
      "object": 1638,
      "owner": "system.user.admin",
      "ownerGroup": "system.group.administrator",
      "state": 1638
      "_id": "mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP",
      "type": "state"
        paul53 last edited by
        Das Datenpunktobjekt hat eine falschen "type": "string"; es sollte "type": "number" sein. Außerdem fehlt "unit": "°C".
        "common": {
        "type": "number",
        "min": 0,
        "def": 0,
        "read": true,
        "write": false,
        "unit": "°C"
        "native": {
        "id": "0",
        "childId": "0",
        "subTypeNum": 6,
        "varTypeNum": 0
        "acl": {
        "object": 1638,
        "state": 1638
        "type": "state"
        Wenn die Werte vom Typ "number" sind:
        setState('hm-rega.0.5237', getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val);
        Wenn die Werte aber vom Typ "string" sind, dann:
        setState('hm-rega.0.5237', parseFloat(getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val));
        Den Typ kann man testen:
        log('Typ: ' + typeof getState('mysensors.0.192_168_1_103.0.0_TEMP.V_TEMP').val);
