    4. Amazon dash
    Amazon dash
    • DirkK
      DirkK last edited by
      Hallo Zusammen,
      Ich hab gestern meinen dash bekommen und hab diesen aktiviert. Nun wollte ich den Adapter installieren und bekam eine Fehlermeldung,
      sowohl auf dem Raspi II mit node 6.7.0, wie auch auf dem Raspi III mit node 4.4.2
      Hier die Fehlermeldung:
      $ ./iobroker add amazon-dash
      npm install iobroker.amazon-dash –production --prefix "/opt/iobroker" (System call)
      ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: Datei oder Verzeichnis nicht gefunden #include <pcap pcap.h="">^
      compilation terminated.
      make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
      gyp
      ERR! build error
      gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack at emitTwo (events.js:106:13)gyp ERR! stack
      at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
      gyp ERR! System Linux 4.1.19-v7+
      gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/pcap
      gyp ERR! node -v v6.7.0
      gyp ERR! node-gyp -v v3.3.1
      gyp ERR! not ok
      npm
      WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/authenticate-pam/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.vis/package.json'
      npm
      ERR! Linux 4.1.19-v7+
      npm
      ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.amazon-dash" "–production" "--prefix" "/opt/iobroker"npm
      ERR!
      node v6.7.0npm ERR!
      npm v3.10.3npm ERR! code ELIFECYCLE
      npm ERR! pcap@2.0.0 install: node-gyp rebuild
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the pcap@2.0.0 install script 'node-gyp rebuild'.
      npm ERR! Make sure you have the latest version of node.js and npm installed.
      npm ERR! If you do, this is most likely a problem with the pcap package,
      npm ERR! not with npm itself.
      npm ERR! Tell the author that this fails on your system:
      npm ERR! node-gyp rebuild
      npm ERR! You can get information on how to open an issue for this project with:
      npm ERR! npm bugs pcap
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR! npm owner ls pcap
      npm ERR! There is likely additional logging output above.
      npm ERR! Please include the following file with any support request:
      npm
      ERR! /npm-debug.log
      ERROR: host.RPi2 Cannot install iobroker.amazon-dash: 1
      ERROR: process exited with code 25
      Hat vieleicht schon jemand Erfahrung und eine Idee?</pcap>
        Da gibt es schon einigesczu.
        Node 6 läuft nicht immer und npm 3 schon gar nicht.
        Empfohlen ist node 4.5 und npm 2.x
        • DirkK
          Na das war fix,
          was ist~~@Homoran:~~
          Empfohlen ist node 4.5 und npm 2.x `
          npm ?
            Steht beivdir im error log
            @DirkK:
            node v6.7.0npm ERR!
            npm v3.10.3npm ERR `
            Benutzt du zum installieren: " npm install iobroker…. "
            Node package manager, wird auch bei Debian mit node installiert.
            • DirkK
              OK, Danke, jetzt muß ich "erst mal in mich gehen", kann man andere Versionen drüberbügeln? Mein Ahne hat gerade das selbe Problem, aber irgendwie kriegt der keine
              Vorgängerversion drauf.
                Node steht auf der Website unter Jessie schnellstart.
                Npm hat Bluefox hier im forum schon öfter geschrieben.
