    4. Fehlermeldung bei Adapterupdate
    UNSOLVED Fehlermeldung bei Adapterupdate
      Beowolf last edited by
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SSD
      Betriebssystem: Linux
      Nodejs-Version: 14.5.0
      NPM-Version: 6.14.5
      Installationsart: Skript
      Image genutzt: Nein
      ich habe immer diese Meldungen bevor der Adapter den ich updaten möchte.
      z.B. dieser:
      $ ./iobroker upgrade luftdaten
      Update luftdaten from @0.0.15 to @0.0.17
      NPM version: 6.14.5
      npm install iobroker.luftdaten@0.0.17 --loglevel error --prefix "/opt/iobroker" (System call)
      Package pixman-1 was not found in the pkg-config search path.Perhaps you should add the directory containing `pixman-1.pc'to the PKG_CONFIG_PATH environment variableNo package 'pixman-1' found
      gyp: Call to 'pkg-config pixman-1 --libs' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
      gyp
       ERR! configure error
      gyp ERR! stack Error: `gyp` failed with exit code: 1
      gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:351:16)gyp ERR! stack     at ChildProcess.emit (events.js:314:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)gyp
      ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node" "--module_name=canvas" "--module_path=/opt/iobroker/node_modules/canvas/build/Release" "--napi_version=6" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"gyp ERR! cwd /opt/iobroker/node_modules/canvasgyp ERR! node -v v14.5.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      node-pre-gyp
       ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/canvas/build/Release/canvas.node --module_name=canvas --module_path=/opt/iobroker/node_modules/canvas/build/Release --napi_version=6 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/node-pre-gyp/lib/util/compile.js:83:29)node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:314:20)node-pre-gyp
       ERR! stack     at maybeClose (internal/child_process.js:1051:16)node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:287:5)node-pre-gyp
      ERR! System Linux 4.19.118-v7l+node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /opt/iobroker/node_modules/canvasnode-pre-gyp ERR! node -v v14.5.0node-pre-gyp ERR! node-pre-gyp -v v0.11.0node-pre-gyp ERR! not ok
      upload [4] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/words.js words.js application/javascript
      Update "system.adapter.luftdaten.0"
      upload [3] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/style.css style.css text/css
      upload [2] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/luftdaten.png luftdaten.png image/png
      upload [1] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/index_m.html index_m.html text/html
      upload [0] luftdaten.admin /opt/iobroker/node_modules/iobroker.luftdaten/admin/admin.d.ts admin.d.ts video/mp2t
      Adapter "luftdaten" updated
      process exited with code 0
      Ich habe keine Ahnung wo bzw. was ich da machen soll.
      Manfred
        Thomas Braun Most Active @Beowolf last edited by
        @Beowolf canvas von Hand installieren. Steht mehrfach hier im Forum, wie das geht.
        Und an deiner Stelle würde ich auch nicht node14, sondern node12 einsetzen.
          Danke, läuft wieder alles.
          fehlermeldung adapterupdate
