    4. Amazon Dash - "Error: expression rejects all packets"
    UNSOLVED Amazon Dash - "Error: expression rejects all packets"
      adarof last edited by adarof
      Hallo
      Ich habe diverse insb Systemupdates eingespielt und rebootet.
      Dann habe ich das setcap ausgeführt und erhalte vom Dash Adapter nun "Error: expression rejects all packets"
      (also NICHT "Operation not permitted" - das hab ich mit dem setcap schon adressiert!):
      host.RoofServer	2020-07-27 20:42:14.857	info	Restart adapter system.adapter.amazon-dash.0 because enabled
      host.RoofServer	2020-07-27 20:42:14.857	info	instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
      host.RoofServer	2020-07-27 20:42:14.857	error	Caught by controller[0]: at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      host.RoofServer	2020-07-27 20:42:14.857	error	Caught by controller[0]: at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      host.RoofServer	2020-07-27 20:42:14.857	error	Caught by controller[0]: at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
      host.RoofServer	2020-07-27 20:42:14.857	error	Caught by controller[0]: at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6811:25)
      host.RoofServer	2020-07-27 20:42:14.857	error	Caught by controller[0]: at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7114:22)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: at Adapter.emit (events.js:198:13)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:53:9)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:90:29)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:131:12)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:60:39)
      host.RoofServer	2020-07-27 20:42:14.856	error	Caught by controller[0]: Error: expression rejects all packets
      amazon-dash.0	2020-07-27 20:42:14.305	info	(6781) Terminated (NO_ERROR): Without reason
      amazon-dash.0	2020-07-27 20:42:14.304	info	(6781) terminating
      amazon-dash.0	2020-07-27 20:42:14.288	info	(6781) cleaned everything up...
      amazon-dash.0	2020-07-27 20:42:14.287	error	at promise.then (/opt/iobroker/node_modules/standard-as-callback/built/index.js:19:49)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at tryCatcher (/opt/iobroker/node_modules/standard-as-callback/built/utils.js:11:23)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at client.keys (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:684:17)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at states.getKeys (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:6811:25)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at initLogging (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:7114:22)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at Adapter.emit (events.js:198:13)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at Adapter.<anonymous> (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:53:9)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:90:29)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:131:12)
      amazon-dash.0	2020-07-27 20:42:14.287	error	at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:60:39)
      amazon-dash.0	2020-07-27 20:42:14.287	error	(6781) Error: expression rejects all packets
      amazon-dash.0	2020-07-27 20:42:14.286	error	(6781) uncaught exception: expression rejects all packets
      amazon-dash.0	2020-07-27 20:42:13.920	info	(6781) starting pcap session on default interface
      amazon-dash.0	2020-07-27 20:42:13.905	info	(6781) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v10.21.0
      host.RoofServer	2020-07-27 20:42:13.104
      Hat da jemand eine Idee?
      Systemdata Bitte Ausfüllen
      Hardwaresystem: NUC
      Arbeitsspeicher: 16GB
      Festplattenart: M.2 SSD
      Betriebssystem: Ubuntu
      Node-Version: 10.21.0
      Nodejs-Version: 10.21.0
      NPM-Version: 6.14.4
      Installationsart: Repo
      Image genutzt: Nein
      Ort/Name der Imagedatei: -
        A Former User @adarof last edited by
        @adarof Hi,
        gib mal "iobroker fix" im iobroker-verzeichnis ein, und starte danach den iobroker wieder.
        Ansonsten hats wohl was mit der Firewall zu tun, wenn pcap sessions rejected werden.. ( d.h. er kann nicht raus.. )
          adarof @Guest last edited by
          @ilovegym Hi, "iobroker fix" hat nichts gebracht. Hab keine Firewall selber angeschaltet - hat sich da bei Ubuntu was geändert?
          Ich hab irgendwie geschlussfolgert, dass der Dash-Adapter eine falsche Expression übergibt ... aber ich wüsst nicht warum die seit Jahren funktionierenden auf einmal falsch sein sollte 😞
            adarof @adarof last edited by
            Wo stell ich denn ein,welches Interface der Adapter nutzt?
            Das passende Interface scheint bei mir "enp0s25" zu heissen.
            ...hiess das nicht mal "eth0" oder so?
              OKAY ... ich habs:
              • Ich hatte kürzlich wireguard auf dem Rechner in Betrieb genommen.
              • Der AmazonDash-Adapter scheint nun (wenn das Wireguard Device "wg0" oben ist) zu versuchen wg0 zu nutzen.
              • Workaround: "wg-quick down wg0", dann Dash Adapter starten, dann "wg-quick up wg0".
              ...d.h. wenn ich im Amazon-Dash-Adapter den konkreten Netzwerkadapter einsetellen könnte, der verwendet wird...wäre mir geholfen 🙂
              dash amazon
