    4. Node-Red
    5. Rechnen in Node Red
    Rechnen in Node Red
      Has3nb3inMH last edited by
      mache Gehversuche mit Node Red und würde gerne was Rechnen.
      Ich verstehe aber nicht warum da nur mist bei rum kommt 🤷‍♂️
      Beste Grüße
      Daniel
              "id": "c05d6044.8035e",
              "type": "tab",
              "label": "Flow 1",
              "disabled": false,
              "info": ""
              "id": "a31cc993.a28758",
              "type": "ioBroker get",
              "z": "c05d6044.8035e",
              "name": "Außenfühler Temperature",
              "topic": "zigbee.0.00158d0002ca05ad.temperature",
              "attrname": "Temperatur",
              "payloadType": "value",
              "x": 470,
              "y": 240,
              "wires": [
                      "8daf2546.310878"
              "id": "345fc725.3bd6d8",
              "name": "Außenfühler Humidity",
              "topic": "zigbee.0.00158d0002ca05ad.humidity",
              "attrname": "Luftfeuchte",
              "x": 520,
              "y": 380,
              "wires": [
                      "8daf2546.310878"
              "id": "5626f9b9.f054f8",
              "type": "inject",
              "name": "",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "",
              "payloadType": "date",
              "x": 420,
              "y": 160,
              "wires": [
                      "345fc725.3bd6d8",
                      "a31cc993.a28758"
              "id": "8daf2546.310878",
              "type": "function",
              "name": "Luftfeuchte",
              "func": "var Test = {};\nTest = Number(msg.Luftfeuchte) - Number(msg.Temperatur);\nmsg.payload = Test;\nreturn msg;",
              "outputs": 1,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "x": 810,
              "y": 340,
              "wires": [
                      "b9c676f0.b95a98"
              "id": "b9c676f0.b95a98",
              "type": "debug",
              "name": "Ausgabe",
              "active": true,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "payload",
              "targetType": "msg",
              "statusVal": "",
              "statusType": "auto",
              "x": 980,
              "y": 340,
              "wires": []
      Folgende Spukt der Debugger aus:
      2.8.2020, 11:12:40node: Ausgabe
      zigbee.0.00158d0002ca05ad.humidity : msg.payload : number
      NaN
      zigbee.0.00158d0002ca05ad.temperature : msg.payload : number
      NaN
        frankyboy73 @Has3nb3inMH last edited by
        @Has3nb3inMH
        Hi, als erstes musst du die Node in eine Reihe setzten, also hintereinander, dann werden beide Input Node durchlaufen und du bekommst eine Nachricht mit Temperatue und Feuchtigkeit. So wie du die Input Node (parallel) eingefügt hast bekommst du zwei Nachrichten zur Funktion Node, mit jeweils nur Temperatur und nur Feuchtigkeit und mit nur einem Wert kann das nicht berechnet werden. Zudem muss in der Funktion Node noch math für Mathematische Funktion rein.
                "id": "fd168a68.a54ce8",
                "z": "aa77b2e2.7ea12",
                "x": 470,
                "y": 360,
                "wires": [
                        "32adbecc.66add2"
                "id": "32adbecc.66add2",
                "x": 660,
                "y": 280,
                "wires": [
                        "b243e8ca.b1efb8"
                "id": "e5dc2454.e91218",
                "type": "inject",
                "name": "",
                "props": [
                        "p": "payload"
                        "p": "topic",
                        "vt": "str"
                "repeat": "",
                "crontab": "",
                "once": false,
                "onceDelay": 0.1,
                "topic": "",
                "payload": "",
                "x": 420,
                "y": 160,
                "wires": [
                        "fd168a68.a54ce8"
                "id": "b243e8ca.b1efb8",
                "type": "function",
                "func": "msg.payload = math = Number(msg.Luftfeuchte) - Number(msg.Temperatur);\nreturn msg;\n",
                "outputs": 1,
                "noerr": 0,
                "initialize": "",
                "finalize": "",
                "x": 810,
                "y": 340,
                "wires": [
                        "a5cbebe5.024d48"
                "id": "a5cbebe5.024d48",
                "type": "debug",
                "name": "Ausgabe",
                "active": true,
                "tosidebar": true,
                "console": false,
                "tostatus": false,
                "statusVal": "",
                "x": 980,
                "y": 340,
                "wires": []
          Has3nb3inMH @frankyboy73 last edited by
          @frankyboy73 vielen Dank. Es hat genügt die Reihenfolge zu ändern.
          Das leben könnte so einfach sein. 😊
            @Has3nb3inMH
            Ah, ok, ich dachte man müsste immer mit "math" arbeiten. Werde es mal ohne testen. Danke für die Rückmeldung. Schön das es jetzt bei dir funktioniert.
