    4. ioBroker ham 3.0.1 Global Modus startet nicht
    UNSOLVED ioBroker ham 3.0.1 Global Modus startet nicht
      markvo72 last edited by
      Hi, leider bekomme ich den ioBroker ham 3.0.1 nicht zum Laufen.
      Einstellungen nach der Installation von ham 3.0.1 :
      Homebridge-Adapter-Modus : Globaler Modus
      Verwenden Sie den unsicheren Homebridge-Modus : aktiviert
      Globaler Homebridge-Pfad : /usr/local/lib/node_modules/
      Globaler Homebridge-Konfigurationsverzeichnispfad : /var/homebridge/
      Wertabfrageintervall (sec) : 1
      Homebridge Befehlszeilenparameter : -leer-
      Fehlermeldungen aus dem LOG :
      ham.0 2020-08-08 23:19:03.734 error at checkLocalMode (/opt/iobroker/node_modules/iobroker.ham/main.js:400:25)
      ham.0 2020-08-08 23:19:03.734 error at /opt/iobroker/node_modules/iobroker.ham/main.js:203:13
      ham.0 2020-08-08 23:19:03.734 error at installAllLibraries (/opt/iobroker/node_modules/iobroker.ham/main.js:381:21)
      ham.0 2020-08-08 23:19:03.734 error at /opt/iobroker/node_modules/iobroker.ham/main.js:217:39
      ham.0 2020-08-08 23:19:03.734 error at Object.init (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:63:12)
      ham.0 2020-08-08 23:19:03.734 error at require (internal/modules/cjs/helpers.js:72:18)
      ham.0 2020-08-08 23:19:03.734 error at Module.require (internal/modules/cjs/loader.js:1025:19)
      ham.0 2020-08-08 23:19:03.734 error at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
      ham.0 2020-08-08 23:19:03.734 error at Function.Module._load (internal/modules/cjs/loader.js:841:27)
      ham.0 2020-08-08 23:19:03.734 error at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
      ham.0 2020-08-08 23:19:03.734 error - /opt/iobroker/node_modules/iobroker.ham/main.js
      ham.0 2020-08-08 23:19:03.734 error - /opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js
      ham.0 2020-08-08 23:19:03.734 error Require stack:
      ham.0 2020-08-08 23:19:03.734 error (9729) Error: Cannot find module '/usr/local/lib/node_modules/lib/user'
      ham.0 2020-08-08 23:19:03.732 error - /opt/iobroker/node_modules/iobroker.ham/main.js
      ham.0 2020-08-08 23:19:03.732 error - /opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js
      ham.0 2020-08-08 23:19:03.732 error Require stack:
      ham.0 2020-08-08 23:19:03.732 error (9729) unhandled promise rejection: Cannot find module '/usr/local/lib/node_modules/lib/user'
      Unhandled 2020-08-08 23:19:03.732 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      Kann mir jemand helfen ?
      Vielen Dank im voraus
      Mark der Ahnungslose 😁
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi4
      Arbeitsspeicher: 4GB
      Festplattenart: SD-Karte
      Betriebssystem: Debian GNU/Linux
      Node-Version: 12.18.3
      Nodejs-Version: 10.22.0
      NPM-Version: 6.14.7
      Installationsart: Skript
      Image genutzt: Ja
      Ort/Name der Imagedatei: Github
        Thomas Braun Most Active @markvo72 last edited by Thomas Braun
        @markvo72
        Würde mich auch enorm wundern, wenn das Zeug in '/usr/local/lib/' läge.
        node ist aber sauber? Du gibst oben abweichende Versionen von node und nodejs an. Das wäre falsch.
        Was gibt
        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
        zurück?
        Ein- und Ausgabe in CodeTags posten!
          markvo72 @Thomas Braun last edited by
          @Thomas-Braun
          Hi Thomas, Danke für die schnelle Reaktion.
          Ich bin noch recht neu in diesem Universum.
          So habe ich die Versionen herausbekommen :
          pi@raspberrypi:/usr/local/lib/node_modules $ npm -v
          6.14.7
          pi@raspberrypi:/usr/local/lib/node_modules $ node -v
          v12.18.3
          pi@raspberrypi:/usr/local/lib/node_modules $ nodejs -v
          v10.22.0
          Ist das Falsch ?
          Brauche ich andere Versionen ?
          Habe alles mit Kochbuch installiert 😄
          Danke für die Hilfe
          Gruß Mark
            @Thomas-Braun
            sorry zu spät gesehen , hier der gewünscht Output :
            pi@raspberrypi:/usr/local/lib/node_modules $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            /usr/bin/nodejs
            v10.22.0
            /usr/local/bin/node
            v12.18.3
            /usr/local/bin/npm
            6.14.7
            nodejs:
            Installiert: 10.22.0-1nodesource1
            Installationskandidat: 10.22.0-1nodesource1
            Versionstabelle:
            *** 10.22.0-1nodesource1 500
            500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
            100 /var/lib/dpkg/status
            10.21.0~dfsg-1~deb10u1+rpi1 500
              @markvo72 Wird das Kochbuch weg, das ist Quark.
              So wird node richtig installiert:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
              Da hast du ziemlichen Murks installiert. In /usr/local/bin werden auch keine node-Module abgelegt.
                @Thomas-Braun
                😀 okay Kochbuchwegschmeiss 😳
                Ich schaue mir den Link mal an
                Kann ich das dann einfach so drüber installieren ?
                curl -sL https://deb.nodesource.com/setup_12.x | sudo -E bash –
                sudo apt install nodejs
                  @markvo72 Nein. Ließ den Kram genau, bevor du weiter rumwurschtelst.
                    @Thomas-Braun
                    rumwurschteln ist genau der richtige Ausdruck 😌
                    Ich habe zig YouTube videos gesehen und einfach drauf los ausprobiert.
                    Am Besten wäre wohl, ich starte noch einmal ganz von vorne.
                    Hast Du eine Art neues Kochbuch für mich, wie ich am Besten vorgehe ?
                    Raspberry OS
                    Homebridge
                    ham 3.0.1
                    Vielen Dank für Deine schnelle Hilfe.
                    Ich bin schwer begeistert.
                    LG Mark
                      @markvo72 Vergiss die tollen Videos. Ich hab noch keins gesehen, was einem Anfänger weiterhelfen würde. Meist ist das Gegenteil der Fall. Führt nämlich zu genau so einem rumgewurschtel.
                      Du brauchst eine Anleitung in Textform, in der du zurück blättern kannst und Befehle rauskopieren kannst.
                        @Thomas-Braun
                        ja genau sowas brauche ich, das wäre klasse 👍
                        Vielleicht einen Tipp, wo ich sowas bekommen kann ?
                          @markvo72
                          https://www.iobroker.net/#de/documentation
                            @Thomas-Braun
                            Astrein, das wird meine neue Lektüre 😀
                            Danke nochmals 👍 TOP
                              @Thomas-Braun
                              Nun habe ich alles neu gemacht :
                              SD-Karte formatiert , Raspberry OS Lite neu installiert,
                              Homebridge installiert ( wie hier beschrieben https://github.com/homebridge/homebridge/wiki/Install-Homebridge-on-Raspbian )
                              Ein paar PlugIns installiert und ausprobiert ( FakeBulb, DelaySwitch, Alexa ), funktioniert 🙂
                              ioBroker installiert ( wie hier beschrieben https://www.iobroker.net/#de/documentation/install/linux.md unter "Installation ioBroker" )
                              Leider kann ich jetzt nur noch den ham 1.1.2 installieren ( die Auswahl "installieren eigener URL von GitHub Version 3.0.1 ist nicht mehr zum auswählen )
                              Einstellungen nach der Installation von ham 1.1.2 :
                              Globaler Homebridge-Pfad : /usr/lib/node_modules/
                              Globaler Homebridge-Konfigurationsverzeichnispfad : /var/lib/homebridge/
                              pi@raspberrypi:/usr/lib/node_modules $ which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                              /usr/bin/nodejs
                              v12.18.3
                              /usr/bin/node
                              v12.18.3
                              /usr/bin/npm
                              6.14.7
                              nodejs:
                              Installiert: 12.18.3-1nodesource1
                              Installationskandidat: 12.18.3-1nodesource1
                              Versionstabelle:
                              *** 12.18.3-1nodesource1 500
                              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                              Fehlermeldungen ( wie gehabt ) :
                              ham.0 2020-08-09 19:26:33.670 error at checkLocalMode (/opt/iobroker/node_modules/iobroker.ham/main.js:397:25)
                              ham.0 2020-08-09 19:26:33.670 error at /opt/iobroker/node_modules/iobroker.ham/main.js:203:13
                              ham.0 2020-08-09 19:26:33.670 error at installAllLibraries (/opt/iobroker/node_modules/iobroker.ham/main.js:378:21)
                              ham.0 2020-08-09 19:26:33.670 error at /opt/iobroker/node_modules/iobroker.ham/main.js:217:39
                              ham.0 2020-08-09 19:26:33.670 error at Object.init (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:62:12)
                              ham.0 2020-08-09 19:26:33.670 error at require (internal/modules/cjs/helpers.js:72:18)
                              ham.0 2020-08-09 19:26:33.670 error at Module.require (internal/modules/cjs/loader.js:1025:19)
                              ham.0 2020-08-09 19:26:33.670 error at Function.Module._load (/opt/iobroker/node_modules/mock-require/index.js:30:22)
                              ham.0 2020-08-09 19:26:33.670 error at Function.Module._load (internal/modules/cjs/loader.js:841:27)
                              ham.0 2020-08-09 19:26:33.670 error at Function.Module._resolveFilename (internal/modules/cjs/loader.js:965:15)
                              ham.0 2020-08-09 19:26:33.670 error - /opt/iobroker/node_modules/iobroker.ham/main.js
                              ham.0 2020-08-09 19:26:33.670 error - /opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js
                              ham.0 2020-08-09 19:26:33.670 error Require stack:
                              ham.0 2020-08-09 19:26:33.670 error (3244) Error: Cannot find module '/usr/lib/node_modules/lib/user'
                              ham.0 2020-08-09 19:26:33.669 error - /opt/iobroker/node_modules/iobroker.ham/main.js
                              ham.0 2020-08-09 19:26:33.669 error - /opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js
                              ham.0 2020-08-09 19:26:33.669 error Require stack:
                              ham.0 2020-08-09 19:26:33.669 error (3244) unhandled promise rejection: Cannot find module '/usr/lib/node_modules/lib/user'
                              Unhandled 2020-08-09 19:26:33.668 error promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              Jemand noch eine Idee ?
                              Ich würde sehr gerne den ham Adapter nutzen.
                              Wie komme ich an die neue Version 3.0.1 ?
                              Danke und Gruß
                              Mark
                                @markvo72
                                Ich weiß nicht, warum du dich immer in
                                herumtreibst. Die iobroker-Module liegen in /opt/iobroker
                                  markvo72 @Thomas Braun last edited by markvo72
                                  @Thomas-Braun
                                  der ham möchte doch den globalen Homebridge Pfad haben, und der ist laut Doku von ham hier : /usr/lib/node_modules
                                  pi@raspberrypi:/usr/lib/node_modules $ npm root -g
                                  Hier liegen auch alle Plugins, die ich im Homebridge installiert habe :
                                  pi@raspberrypi:/usr/lib/node_modules $ ls -l
                                  insgesamt 24
                                  drwxr-xr-x 5 root root 4096 Aug 9 18:09 homebridge
                                  drwxr-xr-x 4 root root 4096 Aug 9 18:29 homebridge-alexa
                                  drwxr-xr-x 6 root root 4096 Aug 9 18:09 homebridge-config-ui-x
                                  drwxr-xr-x 3 root root 4096 Aug 9 18:21 homebridge-delay-switch
                                  drwxr-xr-x 3 root root 4096 Aug 9 18:23 homebridge-fakebulb
                                  drwxr-xr-x 9 root root 4096 Aug 9 18:07 npm
                                  Die ioBroker-Module liegen in /opt/iobroker, da muss ich Dir recht geben, das ist auch bei mir so 🙂
                                  Warum der ham Adapter allerdings in diesem Pfad nach etwas sucht, kann ich auch nicht verstehen : Cannot find module '/usr/lib/node_modules/lib/user'
                                  Wie komme ich denn an die neue Version 3.0.1 ?
                                    @markvo72 3.0.1 liegt in 'latest'
                                    Lass die Finger von git-Versionen.
                                    • apollon77
                                      apollon77 last edited by
                                      Die 3.0.1 tut und ja Latest ist das aktuell
                                      Die Challenge beim Global mode ist das der User iobroker Access haben muss ... hier bitte mal die rechte so erweitern das "iobroker" zugreifen und ggf lesen und schreiben darf
                                        Thomas Braun Most Active @apollon77 last edited by
                                        Dann würde ich vermutlich mit setfacl da die Gruppe 'iobroker' reinflicken.
                                        • apollon77
                                          apollon77 @Thomas Braun last edited by
                                          @Thomas-Braun Wenn Ihr ne funktionierende Lösung findet nehm ich gern einen PR für die Doku 🙂 Oder sagt es mir und ich bau es rein. Hilft anderen bestimmt auch
                                            markvo72 @apollon77 last edited by
                                            @apollon77
                                            Habe jetzt folgendes gemacht :
                                            1. sudo usermod -a -G homebridge iobroker
                                            2. sudo chown -R homebridge:homebridge /var/lib/homebridge/
                                            3. sudo chmod -R g+rw /var/lib/homebridge/
                                            Denke mal Punkt 2 ist überflüssig gewesen, aber seit Punkt3 ist der Fehler weg mit der permission 🙂
                                            Habe Raspberry gebooted, aber leider ist die Adapter Lampe immer noch rot 😞
                                            Status der Fake Lampe wird beim Aktvieren immer noch nicht auf "true" gesetzt.
                                            Hier die neuen Fehlermeldungen :
                                            ham.0 2020-08-10 12:46:23.575 info (2553) stateChange ham.0.Alexa.Accessory-Information.Manufacturer {"val":"homebridge-alexa","ack":true,"ts":1597056383539,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":159699646
                                            ham.0 2020-08-10 12:46:23.574 info (2553) stateChange ham.0.Alexa.Accessory-Information.Identify {"val":false,"ack":true,"ts":1597056383539,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1596996469304}
                                            ham.0 2020-08-10 12:46:23.173 info (2553) stateChange ham.0.Alexa.Alexa.Contact-Sensor-State {"val":1,"ack":true,"ts":1597056383064,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1597056383064}
                                            ham.0 2020-08-10 12:46:23.171 info (2553) Terminated (NO_ERROR): Without reason
                                            ham.0 2020-08-10 12:46:23.169 info (2553) terminating
                                            ham.0 2020-08-10 12:46:23.056 warn (2553) Exception: Error: listen EADDRINUSE: address already in use :::51764
                                            ham.0 2020-08-10 12:46:23.054 info (2553) cleaned everything up...
                                            ham.0 2020-08-10 12:46:23.052 error at processTicksAndRejections (internal/process/task_queues.js:97:5)
                                            ham.0 2020-08-10 12:46:23.052 error at /usr/lib/node_modules/homebridge/lib/server.js:82:30
                                            ham.0 2020-08-10 12:46:23.052 error at Server.publishBridge (/usr/lib/node_modules/homebridge/lib/server.js:104:21)
                                            ham.0 2020-08-10 12:46:23.052 error at MyBridge.publish (/opt/iobroker/node_modules/iobroker.ham/lib/global-handler.js:156:35)
                                            ham.0 2020-08-10 12:46:23.052 error at MyBridge.Accessory._this.publish [as _origPublish] (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/dist/lib/Accessory.js:573:27)
                                            ham.0 2020-08-10 12:46:23.052 error at HAPServer._this.listen (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/dist/lib/HAPServer.js:201:31)
                                            ham.0 2020-08-10 12:46:23.052 error at EventedHTTPServer._this.listen (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/dist/lib/util/eventedhttp.js:99:30)
                                            ham.0 2020-08-10 12:46:23.052 error at Server.listen (net.js:1447:7)
                                            ham.0 2020-08-10 12:46:23.052 error at listenInCluster (net.js:1361:12)
                                            ham.0 2020-08-10 12:46:23.052 error at Server.setupListenHandle [as _listen2] (net.js:1313:16)
                                            ham.0 2020-08-10 12:46:23.052 error (2553) Error: listen EADDRINUSE: address already in use :::51764
                                            ham.0 2020-08-10 12:46:23.051 error (2553) uncaught exception: listen EADDRINUSE: address already in use :::51764
                                            ham.0 2020-08-10 12:46:22.843 info (2553) updateState Fake-Licht.Fake-Licht.Supported-Characteristic-Value-Transition-Configuration: value = null /common= {"type":"string","read":true,"write":false,"role":"text","name":"Supported Char
                                            ham.0 2020-08-10 12:46:22.842 info (2553) updateState Fake-Licht.Fake-Licht.Characteristic-Value-Transition-Control: value = null /common= {"type":"string","read":true,"write":true,"role":"text","name":"Characteristic Value Transition
                                            ham.0 2020-08-10 12:46:22.840 info (2553) updateState Fake-Licht.Fake-Licht.Color-Temperature: value = 140 /common= {"type":"number","min":140,"max":500,"read":true,"write":true,"role":"level","name":"Color Temperature","unit":""}
                                            ham.0 2020-08-10 12:46:22.839 info (2553) updateState Fake-Licht.Fake-Licht.Name: value = /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                            host.raspberrypi 2020-08-10 12:46:23.693 error Caught by controller[1]: [2020-8-10 12:46:21] Plugin /usr/lib/node_modules/homebridge/ does not have a package name that begins with 'homebridge-' or '@scope/homebridge-.
                                            host.raspberrypi 2020-08-10 12:46:23.692 error Caught by controller[0]: [2020-8-10 12:46:21] Plugin /opt/iobroker/node_modules/homebridge-plugin-wrapper package.json does not contain the keyword 'homebridge-plugin'.
                                            81.0k
                                            3.0.1 homebridge iobroker problem
                                            3604
