    4. Chromecast Adapter stürzt ab :(
    UNSOLVED Chromecast Adapter stürzt ab :(
    • JackDaniel
      JackDaniel last edited by JackDaniel
      hi,
      der adapter läuft mit allen meinen 4 google home minis, 1 x google home, 1 x chromecast und einmal android tv 7 ohne probleme, aber sobad ich meinen androd tv 9 aus dem standby hole crasht der adapter 😞
      chromecast.0	2020-08-10 19:02:39.681	error	at Client.emit (events.js:327:22)
      chromecast.0	2020-08-10 19:02:39.681	error	at Client.onmessage (/opt/iobroker/node_modules/castv2/lib/channel.js:23:10)
      chromecast.0	2020-08-10 19:02:39.681	error	at Channel.emit (events.js:315:20)
      chromecast.0	2020-08-10 19:02:39.681	error	at Channel.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/controller.js:16:10)
      chromecast.0	2020-08-10 19:02:39.681	error	at fn.emit (events.js:327:22)
      chromecast.0	2020-08-10 19:02:39.681	error	at fn.onmessage (/opt/iobroker/node_modules/castv2-client/lib/controllers/media.js:21:12)
      chromecast.0	2020-08-10 19:02:39.681	error	at fn.emit (events.js:315:20)
      chromecast.0	2020-08-10 19:02:39.681	error	at fn.onstatus (/opt/iobroker/node_modules/castv2-client/lib/senders/default-media-receiver.js:16:10)
      chromecast.0	2020-08-10 19:02:39.681	error	at DefaultMediaReceiver.emit (events.js:315:20)
      chromecast.0	2020-08-10 19:02:39.681	error	at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58)
      chromecast.0	2020-08-10 19:02:39.681	error	(18101) TypeError: Cannot read property 'contentId' of undefined
      chromecast.0	2020-08-10 19:02:39.679	error	(18101) uncaught exception: Cannot read property 'contentId' of undefined
      chromecast.0	2020-08-10 19:02:39.634	info	(18101) TV Schlafzimmer - Player joint
      chromecast.0	2020-08-10 19:02:39.623	info	(18101) TV Schlafzimmer - Connected player
      chromecast.0	2020-08-10 19:02:39.617	info	(18101) TV Schlafzimmer - Try to join player
      jemand eine idee warum/wieso?
      danke im voraus
      Mojito Joe 1 Reply Last reply Reply Quote 0
      • Mojito Joe
        Mojito Joe @JackDaniel last edited by
        @JackDaniel Habe das gleiche Problem...
        host.DHH6SmartHome	2020-09-26 16:34:17.720	info	instance system.adapter.chromecast.0 started with pid 23928
        host.DHH6SmartHome	2020-09-26 16:33:47.702	info	Restart adapter system.adapter.chromecast.0 because enabled
        host.DHH6SmartHome	2020-09-26 16:33:47.702	info	instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
        chromecast.0	2020-09-26 16:33:47.181	info	(23844) Terminated (NO_ERROR): Without reason
        chromecast.0	2020-09-26 16:33:47.180	info	(23844) terminating
        chromecast.0	2020-09-26 16:33:47.080	info	(23844) Unload completed sucesfully
        chromecast.0	2020-09-26 16:33:47.079	info	(23844) Arbeitszimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.079	info	(23844) Wohnzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.078	info	(23844) Badezimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.078	info	(23844) Schlafzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.062	info	(23844) TV Wohnzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.059	info	(23844) TV Wohnzimmer - Detached player
        chromecast.0	2020-09-26 16:33:47.058	info	(23844) TV Wohnzimmer - Detached player
        chromecast.0	2020-09-26 16:33:47.057	info	(23844) Google-Home-Schlafzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.057	info	(23844) Google-Home-Bad - client disconnected
        chromecast.0	2020-09-26 16:33:47.056	info	(23844) Google-Home-Arbeitszimmer - client disconnected
        chromecast.0	2020-09-26 16:33:47.055	info	(23844) Google-Home-Max - client disconnected
        chromecast.0	2020-09-26 16:33:47.050	info	(23844) Destroying chromecast scanner
        chromecast.0	2020-09-26 16:33:47.050	info	(23844) Unload triggered
        chromecast.0	2020-09-26 16:33:47.049	error	(23844) TypeError: Cannot read property 'contentId' of undefined at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58) at DefaultMediaRece
        chromecast.0	2020-09-26 16:33:47.048	error	(23844) uncaught exception: Cannot read property 'contentId' of undefined
        chromecast.0	2020-09-26 16:33:46.990	info	(23844) TV Wohnzimmer - Player joint
        chromecast.0	2020-09-26 16:33:46.989	info	(23844) TV Wohnzimmer - Connected player
        chromecast.0	2020-09-26 16:33:46.987	info	(23844) TV Wohnzimmer - Try to join player
        chromecast.0	2020-09-26 16:33:46.980	info	(23844) Arbeitszimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.977	info	(23844) Wohnzimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.976	info	(23844) Google-Home-Max - Connected client
        chromecast.0	2020-09-26 16:33:46.973	info	(23844) Schlafzimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.972	info	(23844) Badezimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.967	info	(23844) Google-Home-Arbeitszimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.965	info	(23844) Google-Home-Bad - Connected client
        chromecast.0	2020-09-26 16:33:46.961	info	(23844) Google-Home-Schlafzimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.931	info	(23844) TV Wohnzimmer - Connected client
        chromecast.0	2020-09-26 16:33:46.390	info	(23844) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v10.22.1, js-controller: 3.1.6
        host.DHH6SmartHome	2020-09-26 16:33:45.552	info	instance system.adapter.chromecast.0 started with pid 23844
        host.DHH6SmartHome	2020-09-26 16:33:15.532	info	Restart adapter system.adapter.chromecast.0 because enabled
        host.DHH6SmartHome	2020-09-26 16:33:15.532	info	instance system.adapter.chromecast.0 terminated with code 0 (NO_ERROR)
        chromecast.0	2020-09-26 16:33:15.014	info	(23787) Terminated (NO_ERROR): Without reason
        chromecast.0	2020-09-26 16:33:15.014	info	(23787) terminating
        chromecast.0	2020-09-26 16:33:14.827	info	(23787) Unload completed sucesfully
        chromecast.0	2020-09-26 16:33:14.815	info	(23787) HiFi Musikanlage - client disconnected
        chromecast.0	2020-09-26 16:33:14.814	info	(23787) Arbeitszimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.814	info	(23787) Wohnzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.813	info	(23787) Badezimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.812	info	(23787) Schlafzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.811	info	(23787) TV Wohnzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.810	info	(23787) TV Wohnzimmer - Detached player
        chromecast.0	2020-09-26 16:33:14.804	info	(23787) TV Wohnzimmer - Detached player
        chromecast.0	2020-09-26 16:33:14.791	info	(23787) Google-Home-Schlafzimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.790	info	(23787) Google-Home-Bad - client disconnected
        chromecast.0	2020-09-26 16:33:14.786	info	(23787) Google-Home-Arbeitszimmer - client disconnected
        chromecast.0	2020-09-26 16:33:14.785	info	(23787) Google-Home-Max - client disconnected
        chromecast.0	2020-09-26 16:33:14.781	info	(23787) Destroying chromecast scanner
        chromecast.0	2020-09-26 16:33:14.774	info	(23787) Unload triggered
        chromecast.0	2020-09-26 16:33:14.773	error	(23787) TypeError: Cannot read property 'contentId' of undefined at PersistentPlayer._playerStatus (/opt/iobroker/node_modules/castv2-player/lib/persistentPlayer.js:719:58) at DefaultMediaRece
        chromecast.0	2020-09-26 16:33:14.772	error	(23787) uncaught exception: Cannot read property 'contentId' of undefined
        chromecast.0	2020-09-26 16:33:14.731	info	(23787) Wohnzimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.725	info	(23787) TV Wohnzimmer - Player joint
        chromecast.0	2020-09-26 16:33:14.724	info	(23787) TV Wohnzimmer - Connected player
        chromecast.0	2020-09-26 16:33:14.721	info	(23787) TV Wohnzimmer - Try to join player
        chromecast.0	2020-09-26 16:33:14.713	info	(23787) Arbeitszimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.647	info	(23787) Badezimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.645	info	(23787) HiFi Musikanlage - Connected client
        chromecast.0	2020-09-26 16:33:14.644	info	(23787) Schlafzimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.641	info	(23787) TV Wohnzimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.374	info	(23787) Google-Home-Max - Connected client
        chromecast.0	2020-09-26 16:33:14.336	info	(23787) Google-Home-Arbeitszimmer - Connected client
        chromecast.0	2020-09-26 16:33:14.331	info	(23787) Google-Home-Bad - Connected client
        chromecast.0	2020-09-26 16:33:14.301	info	(23787) Google-Home-Schlafzimmer - Connected client
        chromecast.0	2020-09-26 16:33:13.935	info	(23787) starting. Version 2.3.1 in /opt/iobroker/node_modules/iobroker.chromecast, node: v10.22.1, js-controller: 3.1.6
        und leider auch keine Lösung. Es macht wohl Sinn, sich hier ranzuhängen und das Problem sichtbarer werden zu lassen.
          Thomas Braun Most Active @Mojito Joe last edited by
          @Mojito-Joe Unabhängig vom konkreten Problem würde ich node12 empfehlen.
          Mojito Joe 1 Reply Last reply Reply Quote 1
          • Mojito Joe
            Mojito Joe @Thomas Braun last edited by
            @Thomas-Braun Löst zwar dieses Problem nicht, aber ein paar andere errors mit anderen Adaptern. War mir nicht bewusst, dass diese an der nodeJS Version liegen. Danke!
            • JackDaniel
              ich hab nun einfach den tv deaktiviert da ich eh nur die google home im adapter benötige.
              Mojito Joe David G. 2 Replies Last reply Reply Quote 0
              • Mojito Joe
                @JackDaniel Schau mal hier, wurde bereits beim Adapter als Issue gemeldet. Nun muss es nur noch jemand fixen, dafür reichen meine Fähigkeiten nicht.
                Schaue ich mir den Zeitpunkt des letzten Updates dieses Repositories an, habe ich da meine Zweifel, dass dies demnächst geschieht 😉
                • David G.
                  David G. @JackDaniel last edited by
                  @jackdaniel sagte in Chromecast Adapter stürzt ab 😞:
                  Das Thema ist zwar schon was älter, hänge mich aber mal dran.
                  Das Problem scheint ja noch nicht gefixt zu sein.
                  Wue hast du deinen Fernseher deaktiviert? Finde da keine Settings IM Adapter.
                  JackDaniel 1 Reply Last reply Reply Quote 0
                  • JackDaniel
                    JackDaniel @David G. last edited by
                    @david-g
                    wenn ich mich recht erinnere ist das unter den objekten vom gerät zu finden
                    David G. C 2 Replies Last reply Reply Quote 1
                    • David G.
                      @jackdaniel
                      Gefunden, danke.
                        chefffe @JackDaniel last edited by
                        @jackdaniel
                        hab das gleiche Problem.....
                        Das Deaktivieren des TVs geht über den Datenpunkt "Enabled" auf false setzen?
                        Oder hast du den ganzen Datenpunkt gelöscht?
                        • JackDaniel
                          Ja genau, sollte aber mit der neuen Version eh nicht mehr vorkommen
                          adapter android tv chromecast crash
                          687
