    4. Zigbee mit LaunchXL CC26X2R1
      rudiraz last edited by
      ich bin von dem CC2531 auf den CC26X2R1 umgestiegen.
      Hat anfangs auch wunderbar geklappt. Alles lief.
      Bis gestern versehentlich der Raspi mit dem Zigbee-Adapter hart vom Netz getrennt wurde. Ich habe den Raspi wieder gestartet.
      Allerdings bleibt die Zigbee-Instanz Gelb
      Weitere Info:
      pi@zigbee:~ $ ls -l /dev/serial/by-id
      insgesamt 0
      lrwxrwxrwx 1 root root 13 Aug 16 22:20 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100G3L-if00 -> ../../ttyACM0
      lrwxrwxrwx 1 root root 13 Aug 16 22:20 usb-Texas_Instruments_XDS110__03.00.00.13__Embed_with_CMSIS-DAP_L1100G3L-if03 -> ../../ttyACM1
      Fehlermeldung:
      zigbee.0 2020-08-17 05:49:18.490 error at process._tickCallback (internal/process/next_tick.js:68:7))
      zigbee.0 2020-08-17 05:49:18.490 error at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:306:33)
      zigbee.0 2020-08-17 05:49:18.490 error at Controller.stop (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:182:16)
      zigbee.0 2020-08-17 05:49:18.490 error at __awaiter (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:23:12)
      zigbee.0 2020-08-17 05:49:18.490 error at new Promise (<anonymous>)
      zigbee.0 2020-08-17 05:49:18.490 error at /opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:27:71
      zigbee.0 2020-08-17 05:49:18.490 error at Generator.next (<anonymous>)
      zigbee.0 2020-08-17 05:49:18.490 error at Controller.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:186:49)
      zigbee.0 2020-08-17 05:49:18.490 error at Function.all (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:88:15)
      zigbee.0 2020-08-17 05:49:18.490 error at Function.loadFromDatabaseIfNecessary (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/model/group.js:76:55)
      zigbee.0 2020-08-17 05:49:18.490 error (15628) Failed to stop zigbee (TypeError: Cannot read property 'getEntries' of null
      Kann mir hier jemand helfen?
      qqolli 1 Reply Last reply Reply Quote 0
      • qqolli
        qqolli @rudiraz last edited by
        @rudiraz
        leider kann ich Dir bei diesem speziellen Problem nicht helfen, da ich den Conbee II Stick benutzte. Da ich aber großes Interesse an einer CC26X2R1-Lösung habe, wollte ich mal fragen welche Lösung, bzw. welches Modell Du genommen hast?
        Gibt übrigens ein sehr gutes Video von Matthias zu diesem Thema: https://www.youtube.com/watch?v=UKn5hBwCxoQ
          rudiraz @qqolli last edited by
          @qqolli
          ich nutze den LAUNCHXL-CC26X2R1 von hier:
          https://www.mouser.de/ProductDetail/Texas-Instruments/LAUNCHXL-CC26X2R1?qs=pfd5qewlna7NQQI%2B7L2KoA==&gclid=Cj0KCQjwsuP5BRCoARIsAPtX_wG5CioqcCVInZao_sKtc57Ug-5Fc7aknx5DT7l20xpQSCM9biCj9UwaAhRwEALw_wcB
          • qqolli
            @rudiraz
            Ok, danke. Ist der gleiche wie aus dem Video. Wenn ich mich recht erinnere, war in den Kommentaren des Videos oder im Video selbst eine Quelle für ein Gehäuse genannt; falls das für Dich von Interesse sein sollte.
              @qqolli Gehäuse ist bereits gedruckt
              Ich hab -wie gesagt- nur das Problem, dass die Instanz nicht mehr Grün wird. Nach dem Crash
              Und ich weiß nicht, wie ich den Fehler beheben soll
                @rudiraz
                1. pack den LOG in Code Tag dann ist es besser lesbar
                dann
                das ist die Fehlermeldung vom Stoppen des Adapters... das hat nix mit dem Start zu tun.. wenn dann musst du den richtigen LOG Posten.. und dann im genze und nicht so ein schnippsel.. da kann ich nix draus erkennen
                  rudiraz @arteck last edited by
                  @arteck
                  zigbee.0	2020-08-17 10:10:58.761	error	(646) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port' at Znp.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp
                  zigbee.0	2020-08-17 10:10:58.759	error	(646) Failed to start Zigbee
                  zigbee.0	2020-08-17 10:10:58.481	debug	(646) Starting zigbee-herdsman...
                  zigbee.0	2020-08-17 10:10:58.480	info	(646) Starting Zigbee...
                  zigbee.0	2020-08-17 10:10:58.478	info	(646) Try to reconnect. 1 attempts left
                  zigbee.0	2020-08-17 10:10:54.050	debug	(646) system.adapter.admin.0: logging true
                  zigbee.0	2020-08-17 10:10:48.474	error	at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:25:65)
                  zigbee.0	2020-08-17 10:10:48.474	error	at Generator.throw (<anonymous>)
                  zigbee.0	2020-08-17 10:10:48.474	error	at /opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/startZnp.js:171:23
                  zigbee.0	2020-08-17 10:10:48.474	error	(646) Error: Coordinator failed to start, probably the panID is already in use, try a different panID or channel
                  zigbee.0	2020-08-17 10:10:48.472	error	(646) Failed to start Zigbee
                  Dann wohl das 🙂
                    arteck Developer Most Active @rudiraz last edited by arteck
                    @rudiraz sagte in Zigbee mit LaunchXL CC26X2R1:
                    hängt da noch was dran an dem usb port ?
                    und da ist was faul.... wie viele router hast du im Netz ?? die müssen alle raus.. vielleicht bekommen wir das so wieder hin
                    also ALLES WAS AM STROM HÄNGT MAL EBEN vom STROM und dann das Board kurz trennen.. dann wieder rein und adapter starten.. dann warten.. dann kannst du nach und nach die Router wieder am Strom packen.
                    NICHT LÖSCHEN .. die müssen vom strom getrennt werden.
                    das Board schein die PanID verloren zu haben.. und die Router funken da jetzt dazwischen..
                    oder du lernst alles neu an .. das geht auch
                      @arteck
                      Super! Der Router war der Übeltäter!
                      Hab ihn vom Strom genommen und nun wird die Instanz wieder Grün.
                      Geräte sind zwar offline, aber die kann ich fix wieder anlernen.
                      Hab vielleicht zu viel daran gespielt 🙂
                      Vielen Dank für die schnelle Hilfe
                      cc26x2r zigbee zigbee 3.0
