    4. zigbee bleibt gelb (Error: SRSP - SYS - ping after 6000ms)
    UNSOLVED zigbee bleibt gelb (Error: SRSP - SYS - ping after 6000ms)
    • s.bormann
      s.bormann Most Active last edited by
      seit einigen Stunden bleibt mein zigbee-Adapter gelb (ohne, dass ich was geändert habe). Neustart, CC2531-Stick rausziehen, Router stromlos schalten hat alles nichts gebracht. Hier das Log:
      2020-08-18 00:06:39.913 - info: host.tinkerboard "system.adapter.zigbee.0" enabled
      2020-08-18 00:06:39.940 - info: host.tinkerboard instance system.adapter.zigbee.0 started with pid 19252
      2020-08-18 00:06:41.689 - debug: zigbee.0 (19252) Redis Objects: Use Redis connection: 127.0.0.1:9001
      2020-08-18 00:06:41.736 - debug: zigbee.0 (19252) Objects client ready ... initialize now
      2020-08-18 00:06:41.742 - debug: zigbee.0 (19252) Objects create System PubSub Client
      2020-08-18 00:06:41.743 - debug: zigbee.0 (19252) Objects create User PubSub Client
      2020-08-18 00:06:41.744 - debug: zigbee.0 (19252) Objects client initialize lua scripts
      2020-08-18 00:06:41.766 - debug: zigbee.0 (19252) Objects connected to redis: 127.0.0.1:9001
      2020-08-18 00:06:41.777 - debug: zigbee.0 (19252) objectDB connected
      2020-08-18 00:06:41.780 - debug: zigbee.0 (19252) Redis States: Use Redis connection: 127.0.0.1:9000
      2020-08-18 00:06:41.792 - debug: zigbee.0 (19252) States create User PubSub Client
      2020-08-18 00:06:41.795 - debug: zigbee.0 (19252) States create System PubSub Client
      2020-08-18 00:06:41.811 - debug: zigbee.0 (19252) States connected to redis: 127.0.0.1:9000
      2020-08-18 00:06:41.813 - debug: zigbee.0 (19252) statesDB connected
      2020-08-18 00:06:42.336 - info: zigbee.0 (19252) starting. Version 1.2.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v10.22.0, js-controller: 3.1.6
      2020-08-18 00:06:42.372 - debug: zigbee.0 (19252) Using zigbee-herdsman with settings: {"network":{"panID":xxxx,"extendedPanID":[xxxx],"channelList":[11],"networkKey":[xxxx]},"databasePath":"/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db","serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"}}
      2020-08-18 00:06:42.375 - info: zigbee.0 (19252) Starting Zigbee...
      2020-08-18 00:06:42.376 - debug: zigbee.0 (19252) Starting zigbee-herdsman...
      2020-08-18 00:06:42.827 - debug: zigbee.0 (19252) zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
      2020-08-18 00:06:42.846 - debug: zigbee.0 (19252) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[xxxx],"panID":xxxx,"extendedPanID":[xxxx],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":null,"adapter":null,"acceptJoiningDeviceHandler":null}'
      2020-08-18 00:06:42.855 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      2020-08-18 00:06:42.869 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:log Serialport opened
      2020-08-18 00:06:43.330 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:log Writing skip bootloader payload
      2020-08-18 00:06:43.332 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:unpi:writer --> buffer [239]
      2020-08-18 00:06:44.342 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      2020-08-18 00:06:44.348 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      2020-08-18 00:06:50.357 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      2020-08-18 00:06:50.358 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      2020-08-18 00:06:56.360 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:SREQ --> SYS - ping - {"capabilities":1}
      2020-08-18 00:06:56.361 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,0,33,1,32]
      2020-08-18 00:07:02.364 - error: zigbee.0 (19252) Failed to start Zigbee
      2020-08-18 00:07:02.366 - error: zigbee.0 (19252) Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      at ZStackAdapter. (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:89:31)
      at Generator.throw ()
      at rejected (/opt/iobroker/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
      2020-08-18 00:07:12.368 - info: zigbee.0 (19252) Try to reconnect. 1 attempts left
      2020-08-18 00:07:12.368 - info: zigbee.0 (19252) Starting Zigbee...
      2020-08-18 00:07:12.369 - debug: zigbee.0 (19252) Starting zigbee-herdsman...
      2020-08-18 00:07:12.571 - debug: zigbee.0 (19252) zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'ZStackAdapter'
      2020-08-18 00:07:12.572 - debug: zigbee.0 (19252) zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[xxxx],"panID":xxxx,"extendedPanID":[xxxx],"channelList":[11]},"serialPort":{"baudRate":115200,"rtscts":false,"path":"/dev/ttyACM0","adapter":"zstack"},"databasePath":"/opt/iobroker/node_modules/iobroker.js-controller/../../iobroker-data/zigbee_0/shepherd.db","databaseBackupPath":null,"backupPath":null,"adapter":null,"acceptJoiningDeviceHandler":null}'
      2020-08-18 00:07:12.576 - debug: zigbee.0 (19252) zigbee-herdsman:adapter:zStack:znp:log Opening SerialPort with /dev/ttyACM0 and {"baudRate":115200,"rtscts":false,"autoOpen":false}
      2020-08-18 00:07:17.669 - error: zigbee.0 (19252) Failed to start Zigbee
      2020-08-18 00:07:17.670 - error: zigbee.0 (19252) Error: Error while opening serialport 'Error: Error Resource temporarily unavailable Cannot lock port'
      @arteck Kannst Du, oder jemand anderer, helfen?
      Schon mal vielen Dank!!
        arteck Developer Most Active @s.bormann last edited by
        @s-bormann sagte in zigbee bleibt gelb (Error: SRSP - SYS - ping after 6000ms):
        es steht ja da
        wo steck der stick ?? pi ?? nas ?? nuc ?
        s.bormann JLeg 2 Replies Last reply Reply Quote 0
        • s.bormann
          s.bormann Most Active @arteck last edited by
          @arteck Hi, steckt direkt im tinkerboard. Habe folgendes beobachtet: Die LED am Stick leuchtet nach einem Reboot bzw. wenn man den Stick rauszieht und neu einsteckt. Beim Versuch den Zigbee-Adapter zu starten, geht die LED am Stick aus.
            @s-bormann ist da noch was im USB port
            s.bormann 2 Replies Last reply Reply Quote 0
            • s.bormann
              @arteck Nein, der Stick ist das einzige USB-Gerät.
              ``test -w /dev/ttyACM0 && echo success || echo failure```
              gibt auch success aus, also Schreibrechte auf den Port bestehen.
              Der Stick reagiert ja auch, indem die LED ausgeht, wenn der Adapter startet.
              • s.bormann
                @arteck wenn ich dmesg -w eintippe, kommt folgendes:
                Hab aber keine Ahnung, was das heißt...
                  arteck Developer Most Active @s.bormann last edited by arteck
                  @s-bormann die reaktion des stick ist egall wenn der serialport nicht aufgeht.. dann kann blinken oder nicht was es will
                  machmal
                  ls -l /dev/serial/by-id
                  und trage den vollen qualifizierten Namen in den Einstellungen ein
                  p.s: welche Adapterversion ?
                  s.bormann 1 Reply Last reply Reply Quote 0
                  • s.bormann
                    @arteck
                    Habe sowohl das usb-Texax...., als auch ../../ttyACM0 eingetragen, beides geht nicht:
                    Habe die aktuelle Version aus dem latest (1.2.1). Ein downgrade auf 1.2.0 hat auch nichts gebracht.
                    • JLeg
                      JLeg @arteck last edited by
                      @arteck sagte in zigbee bleibt gelb (Error: SRSP - SYS - ping after 6000ms):
                      es steht ja da
                      glaube nicht, dass es am "üblichen" Portproblem liegt (8 Sekunden vorher wurde der ja auch erfolgreich geöffnet) - das hier deutet wohl eher auf ein "Stick-Problem" hin:
                      https://github.com/Koenkk/zigbee2mqtt/issues/2997
                      Bei einigen hat "Reflash" geholfen...
                      fantasyjqc created this issue in Koenkk/zigbee2mqtt
                      closed Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms) #2997
                      • s.bormann
                        s.bormann Most Active @JLeg last edited by
                        @JLeg Hi, glaube inzwischen auch, dass der Stick hin ist... Habe leider keinen CC-Debugger da, um ihn neu zu flashen. Habe mir jetzt diesen Stick hier bestellt:
                        https://slae.sh/projects/cc2652/
                        Ich war mit dem alten eh nicht so zufrieden (geringe Reichweite, wenig Speicher).
                        Danke für Eure Hilfe (wenn noch jemandem was einfällt, ich probiere gerne trotzdem alles aus - leider hat der neue Stick über 1 Woche Lieferzeit - und bis dahin ist hier wieder das Mittelalter eingekehrt 🙂 )
                        VG!
                          dirkhe Developer @s.bormann last edited by
                          @s-bormann ich habe den o.g. Stick auf einem Pi 3+ und mir ist letztes Wochenende genau das gleiche passiert. Bei meinem leuchtet mittlerweile nicht mal mehr die powerleuchte. Ich bekomme ihn noch per LS angezeigt, aber flashen geht leider auch nicht mehr.
                          • s.bormann
                            s.bormann Most Active @dirkhe last edited by
                            @dirkhe Du meinst denn slae.sh - Stick? Das wäre natürlich blöd... Dann gehe ich vielleicht doch lieber auf ConBee??
                              @s-bormann ja schon, aber ich glaube nicht, dass es am stick liegt. Ich hatte vorger auch ein cc2531. Ich hatte mich nur gewundert, dass du quasi zeitgleich das selbe Problem hast. Ich stehe im Kontakt mit dem Entwickler des Sticks, vlt hat er ja noch enie Idee. Ich wollte den Stick nicht schlecht machen
                              • s.bormann
                                @dirkhe Alles klar, danke.
                                Noch mal eine Frage zu ConBee: Weiß jemand, ob man da auch alle Geräte neu anlernen muss, wenn der Stick abrauscht? Oder kann ConBee die Konfiguration von Stick zu Stick übertragen?
                                  surfer90 last edited by surfer90
                                  @s-bormann
                                  @dirkhe Ich habe das gleiche Problem(bild). Folgende Kombis erfolglos versucht:
                                  • cc2531 mit altem Pi 3b
                                  • conbee II mit altem Pi 3b
                                  • umgezogen auf Pi4 4GB und conbee II, ebenfalls der gleiche Fehler
                                  • Version 1.2.1 von Git gezogen statt der stable -> ging einmal kurz zu starten, allerdings nach neustart des Adapters 5 Minuten später wieder der gleiche Fehler angezeigt...
                                  Gibt es noch weitere Erkenntnisse inzwischen?
                                  • s.bormann
                                    s.bormann Most Active @surfer90 last edited by
                                    @surfer90 Hast Du das Problem auch jetzt erst kürzlich bekommen? Dann könnte da ja wirklich irgendwo ein Zusammenhang bestehen?!
                                      derbaum123 last edited by
                                      bei mir ähnlich. es dauert keine 24h, dann sind meine zigbee Geräte nicht mehr erreichbar. Bisher hat es geholfen, des USB Stick rauszuziehen und wieder einzustecken. Danach funktionierte es meistens. Falls nicht, habe ich auch den Adapter nochmal nue gestartet. Bei mir tritt das Problem gefühlt auch seit dem Update auf die neueste Zigbee adapter Version aus.
                                        dirkhe Developer last edited by
                                        Hallo zusammen, ich habe mittlerweile einen Austausch Stick von Slae.sh bekommen. Er wollte sich den anderen mal anschauen, mal sehen, ob er was findet. Ist auf jeden Fall super Support von ihm finde ich
                                        Ich bin echt begeistert, wie geil der Stick funktioniert, vor alledem das Anlernen geht bei den Geräten, dort wo sie sind. Bei dem cc2531 musste ich mit jedem Teil direkt zum Stick laufen zum pairen
                                          stopbit @dirkhe last edited by
                                          Hallo zusammen
                                          Da ich seit kurzem (nach letztem Zigbee Update???) auch davon betroffen bin, Fragen an die Profis:
                                          Ein zeitnahes "Massensterben" der 2531 ist doch eher unwahrscheinlich, oder wie seht ihr das?
                                          Kann ein Update die Sticks "grillen"?
                                          Ich stecke noch nicht tief genug in in der Materie, bin aber gewillt zu lernen.
                                          Thx
                                          • s.bormann
                                            s.bormann Most Active @stopbit last edited by
                                            @stopbit sagte in zigbee bleibt gelb (Error: SRSP - SYS - ping after 6000ms):
                                            Hallo zusammen
                                            Thx
                                            Ich finde es schon auffällig - allerdings ist es aus so einem Thread schwer abzulesen, ob es sich um die normale "sterberate" handelt, oder ob es tatsächlich ein neues Phänomen ist, dass sich Sticks verabschieden. Vielleicht weiß @arteck oder ein anderer Zigbee-Profi dazu etwas?
                                            Ich warte aktuell noch auf meinen neuen Stick von slae.sh.
                                            Ich hoffe, es ist kein Adapter bzw. zigbee-herdsman-Problem!
                                            VG!
                                            moelski arteck 2 Replies Last reply Reply Quote 0
                                            cc2531 gelb zigbee
                                            10
                                            30
                                            7341
