    2. English
    3. Visualization
    4. Adapter time-switch
    Adapter time-switch
    • Vraanaa
      Vraanaa last edited by
      Im new on Iobroker community and have installed Iobroker on Raspberry Pi. I use many of useful adapters and system is running great.
      I've found discussion od German part of forum LINK for time-switch adapter which sounds great and useful - I've installed it trough external link as it is decried on forum, but I cant get it work from my Visualization Runtime.
      I've got it in Runtime and I can open settings, but settings wont be accepted after I press save.
      The changes are accepted only if I go to the object of the Instance and make edit of the point there:
      Does anyone use this adapter so far and know something how I can get it run on my system?
      I run Iobroker on RaspberryPi4
      Platform: linux
      os: linux
      Architecture: arm
      CPUs: 4
      Speed: 1500 MHz
      Model: ARMv7 Processor rev 3 (v7l)
      RAM: 3.8 GB
      System uptime: 17:13:47
      Node.js: v12.18.3
      NPM: 6.14.6
      adapters count: 303
      Disk size: 58.3 GiB
      Disk free: 51.2 GiB
      Uptime: 17:13:41
      Active instances: 20
      Thank you in advance
      • liv-in-sky
        liv-in-sky @Vraanaa last edited by
        @Vraanaa
        i will add @walli545 to this thread - he is the owner of this adapter and maybe he could help you
        Vraanaa 1 Reply Last reply Reply Quote 1
        • Vraanaa
          Vraanaa @liv-in-sky last edited by
          @liv-in-sky
          I solved the problem. Everything is OK with adapter, problem was in my browser. Ive use another PC fresh installed and tried, now everything is OK.
          Thanks
          • liv-in-sky
            @Vraanaa good to hear - have a anice day
            vis
