    4. [Gelöst] Zigbee Instanz startet nicht mehr...
    SOLVED [Gelöst] Zigbee Instanz startet nicht mehr...
      CrazyCarlton last edited by CrazyCarlton
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte/SSD/HDD
      Betriebssystem: Ubuntu
      Node-Version: 10.x.x
      Nodejs-Version: v10.22.0
      NPM-Version: 6.14.6
      Hi zusammen, nach einem Update vom ioBroker startet die Zigbee Instanz nichtmehr. Folgendes steht im Log:
      host.raspberrypi	2020-08-28 15:42:43.994	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.raspberrypi	2020-08-28 15:42:43.994	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
      host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:25:18)
      host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:692:17)
      host.raspberrypi	2020-08-28 15:42:43.993	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
      host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:653:32)
      host.raspberrypi	2020-08-28 15:42:43.992	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
      host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:778:30)
      host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
      host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
      host.raspberrypi	2020-08-28 15:42:43.991	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v64-linux-arm/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.990	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/10.22.0/linux/arm/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.989	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.988	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.987	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
      host.raspberrypi	2020-08-28 15:42:43.986	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
      host.raspberrypi	2020-08-28 15:42:43.986	error	Caught by controller[0]: ^
      host.raspberrypi	2020-08-28 15:42:43.985	error	Caught by controller[0]: throw err;
      host.raspberrypi	2020-08-28 15:42:43.984	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
      hat wer eine Ahnung wo ich hier ansetzen kann?
      Vielen Dank 🙂
      • Asgothian
        Asgothian Developer @CrazyCarlton last edited by
        @CrazyCarlton
        hast du nach dem Update von Node im Verzeichnis /opt/iobroker nen "npm rebuild" durchlaufen lassen ?
        A.
          Thomas Braun Most Active @CrazyCarlton last edited by
          @CrazyCarlton
          which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
            CrazyCarlton @Thomas Braun last edited by
            @Thomas-Braun said in Zigbee Instanz startet nicht mehr nach iobroker update:
            /usr/bin/nodejs
            v10.22.0
            /home/pi/.nvm/versions/node/v12.16.3/bin/node
            v12.16.3
            /home/pi/.nvm/versions/node/v12.16.3/bin/npm
            6.14.4
            nodejs:
              Installed: 10.22.0-1nodesource1
              Candidate: 10.22.0-1nodesource1
              Version table:
             *** 10.22.0-1nodesource1 500
                    500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                    100 /var/lib/dpkg/status
                 10.21.0~dfsg-1~deb10u1+rpi1 500
              Thomas Braun Most Active @CrazyCarlton last edited by Thomas Braun
              @CrazyCarlton nodejs ist falsch bzw. doppelt installiert.
              Schau hier rein:
              https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
                CrazyCarlton @Thomas Braun last edited by CrazyCarlton
                @Thomas-Braun Super, danke!
                habe es jetzt gerade gezogen. Leider noch immer der gleiche Fehler.
                /usr/bin/nodejs
                v12.18.3
                /usr/bin/node
                v12.18.3
                /usr/bin/npm
                6.14.6
                nodejs:
                  Installed: 12.18.3-1nodesource1
                  Candidate: 12.18.3-1nodesource1
                  Version table:
                 *** 12.18.3-1nodesource1 500
                        500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                host.raspberrypi	2020-08-28 16:32:14.790	error	instance system.adapter.zigbee.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
                host.raspberrypi	2020-08-28 16:32:14.789	error	Caught by controller[0]: }
                host.raspberrypi	2020-08-28 16:32:14.788	error	Caught by controller[0]: ]
                host.raspberrypi	2020-08-28 16:32:14.788	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node'
                host.raspberrypi	2020-08-28 16:32:14.787	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.787	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.786	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.786	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.785	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.784	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.783	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.782	error	Caught by controller[0]: '/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node',
                host.raspberrypi	2020-08-28 16:32:14.782	error	Caught by controller[0]: tries: [
                host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30) {
                host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/index.js:14:22)
                host.raspberrypi	2020-08-28 16:32:14.781	error	Caught by controller[0]: at require (internal/modules/cjs/helpers.js:72:18)
                host.raspberrypi	2020-08-28 16:32:14.780	error	Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1025:19)
                host.raspberrypi	2020-08-28 16:32:14.777	error	Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:878:14)
                host.raspberrypi	2020-08-28 16:32:14.777	error	Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:985:32)
                host.raspberrypi	2020-08-28 16:32:14.776	error	Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1157:10)
                host.raspberrypi	2020-08-28 16:32:14.776	error	Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1137:30)
                host.raspberrypi	2020-08-28 16:32:14.775	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/linux.js:2:36)
                host.raspberrypi	2020-08-28 16:32:14.775	error	Caught by controller[0]: at bindings (/opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:126:9)
                host.raspberrypi	2020-08-28 16:32:14.774	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/lib/binding/node-v72-linux-arm/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.774	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/default/install-root/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.773	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/debug/install-root/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.773	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/addon-build/release/install-root/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.772	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/compiled/12.18.3/linux/arm/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.772	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/default/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.771	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Release/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.771	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Release/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.770	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/Debug/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.770	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/out/Debug/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.769	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Release/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.769	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/Debug/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.768	error	Caught by controller[0]: → /opt/iobroker/node_modules/zigbee-herdsman/node_modules/@serialport/bindings/build/bindings.node
                host.raspberrypi	2020-08-28 16:32:14.767	error	Caught by controller[0]: Error: Could not locate the bindings file. Tried:
                host.raspberrypi	2020-08-28 16:32:14.767	error	Caught by controller[0]: ^
                host.raspberrypi	2020-08-28 16:32:14.766	error	Caught by controller[0]: throw err;
                host.raspberrypi	2020-08-28 16:32:14.758	error	Caught by controller[0]: /opt/iobroker/node_modules/zigbee-herdsman/node_modules/bindings/bindings.js:135
                • Asgothian
                  @CrazyCarlton
                  A.
                    CrazyCarlton @Asgothian last edited by
                    @Asgothian
                    Das wars! Vielen Dank! 🙂
                    iobroker app iobroker update
