    4. Installation jeglicher Adapter failed
    UNSOLVED Installation jeglicher Adapter failed
      PierrePetite last edited by PierrePetite
      Systemdata Bitte Ausfüllen
      Hardwaresystem: Pi3B+
      Arbeitsspeicher: 1GB
      Festplattenart: SD-Karte
      Betriebssystem: RaspiOS
      Hey, seit 3 Tagen stürzt der Pi bei der Installation von jedem Adapter ab. Vorhin versucht de Landroid-Adapter zu installieren:
      $ ./iobroker add worx  --host raspberrypi
      NPM version: 6.14.6npm install iobroker.worx@1.0.0 --loglevel error --prefix "/opt/iobroker" (System call)
      In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      ../src/linux/BluetoothSerialPort.cc: At global scope:../src/linux/BluetoothSerialPort.cc:18:14: error: variable or field ‘InitAll’ declared void void InitAll(Handle<Object> exports) {              ^~~~~~../src/linux/BluetoothSerialPort.cc:18:14: error: ‘Handle’ was not declared in this scope
      ../src/linux/BluetoothSerialPort.cc:18:14: note: suggested alternative: ‘rand_r’ void InitAll(Handle<Object> exports) {              ^~~~~~              rand_r../src/linux/BluetoothSerialPort.cc:18:27: error: expected primary-expression before ‘>’ token void InitAll(Handle<Object> exports) {                           ^../src/linux/BluetoothSerialPort.cc:18:29: error: ‘exports’ was not declared in this scope void InitAll(Handle<Object> exports) {                             ^~~~~~~In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc:23:34: error: ‘InitAll’ was not declared in this scope NODE_MODULE(BluetoothSerialPort, InitAll)                                  ^~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
      make: *** [BluetoothSerialPort.target.mk:115: Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o] Error 1
      gyp
      ERR! build error
      gyp
       ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
      gyp
       ERR! System Linux 4.19.118-v7+gyp ERR! command "/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      Jemand eine Idee?
      da_Woody Thomas Braun 2 Replies Last reply Reply Quote 0
      • da_Woody
        da_Woody @PierrePetite last edited by
        @PierrePetite nuja, ubuntu, wahrscheinlich level 5, 1GB ram, bisschen wenig platz.
          Thomas Braun Most Active @PierrePetite last edited by Thomas Braun
          @PierrePetite sagte in Installation jeglicher Adapter failed:
          /usr/local/bin/node
          NodeJS falsch installiert.
          Schau hier wie man das wieder gerade fummelt:
          https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
          Den Pi könntest du auch mal aktualisieren, RaspberryOS (ich vermute Ubuntu ist eine Falschangabe) läuft mittlerweile mit einem Kernel 5.4.
            Ja, Ubuntu war tatsächlich eine Falschangabe. Es ist RaspiOS.
            Problem ist behoben.
            sudo apt update
            sudo apt upgrade
            Hat es gelöst. Danke euch! Hoffentlich ist es nun auch vorbei, dass der Gute jeden zweiten Tag abstürzt und rebootet werden muss.
            Danke!
            Glasfaser Thomas Braun 2 Replies Last reply Reply Quote 0
            • Glasfaser
              Glasfaser @PierrePetite last edited by
              sudo apt update
              sudo apt upgrade
              Hat es gelöst.
              aber nicht deine Falschinstallation in :
              /usr/local/............
                @PierrePetite Das ist aber nur die halbe Miete.
                who -r
                sagt? Und wie gesagt muss die node-Installation auch korrigiert werden.
                iobroker absturz
