    4. CC2531 startet nicht mehr
    UNSOLVED CC2531 startet nicht mehr
      HockeyHomy last edited by HockeyHomy
      mein CC2531 lief einwandfrei und plötzlich bleibt die Instanz im iobroker rot. Sie wechsel nur noch von gelb auf rot. Ich habe den CC2531 bereits mehrfach ab und wieder angesteckt und sogar erneut geflasht. Nichts hat geholfen. Im iobroker sehe ich folgende Logs:
      Über einen Rat wäre ich sehr dankbar
      host.iobroker 2020-09-01 23:28:53.029 info Restart adapter system.adapter.zigbee.0 because enabled
      host.iobroker 2020-09-01 23:28:53.029 info instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
      zigbee.0 2020-09-01 23:28:52.993 error (7987) TypeError: Cannot read property 'mapped' of undefined at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:197:36) at processTicksAndRejections (internal/proce
      zigbee.0 2020-09-01 23:28:52.993 error (7987) unhandled promise rejection: Cannot read property 'mapped' of undefined
      zigbee.0 2020-09-01 23:28:52.992 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0 2020-09-01 23:28:52.989 error (7987) TypeError: Cannot read property 'mapped' of undefined at Zigbee.publishFromState (/opt/iobroker/node_modules/iobroker.zigbee/main.js:197:36) at processTicksAndRejections (internal/proce
      zigbee.0 2020-09-01 23:28:52.989 error (7987) unhandled promise rejection: Cannot read property 'mapped' of undefined
      zigbee.0 2020-09-01 23:28:52.988 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0 2020-09-01 23:28:52.502 info (7987) Terminated (NO_ERROR): Without reason
      zigbee.0 2020-09-01 23:28:52.501 info (7987) terminating
      mickym O 2 Replies Last reply Reply Quote 0
      • mickym
        mickym Most Active @HockeyHomy last edited by
        @HockeyHomy Ich hatte auch so ein Problem - und bei mir hatte leider wirklich der Stick die Grätsche gemacht und nur ein neuer Ersatz hat Abhilfe gebracht.
        Zigbee Adapter mit C2531 startet PLÖTZLICH nicht mehr
        • O
          obakuhl Developer @HockeyHomy last edited by
          @HockeyHomy
          Dieser Tipp soll jetzt nicht blöd daher kommen, aber grade beim ZigBee Stick habe ich sehr gute Erfahrungen mit einem kompletten Neustart des Systems gemacht 🤓
          Die FW-Version auf deinem Stick ist die vom 08.06.2019?
          cc2531
