    4. [Frage]Nach Fehler bei Redis-Anmeldung startet ioBroker immer wieder neu
      pix last edited by
      hatte größere Probleme mit meinem Server. Nun ist er wieder flott, allerdings startet iobroker nicht sauber:
      2016-10-26 18:20:09.264  - [32minfo[39m: iobroker exit 0
      2016-10-26 18:20:09.367  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
      2016-10-26 18:20:09.368  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
      2016-10-26 18:20:15.393  - [32minfo[39m: host.MacMini-Ethernet.fritz.box iobroker.js-controller version 0.12.3 js-controller starting
      2016-10-26 18:20:15.401  - [32minfo[39m: host.MacMini-Ethernet.fritz.box Copyright (c) 2014-2016 bluefox, hobbyquaker
      2016-10-26 18:20:15.402  - [32minfo[39m: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
      2016-10-26 18:20:15.403  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ip addresses: fe80::ca2a:14ff:fe58:bcd 192.168.178.38 fe80::bd31:d67e:532a:4255 fd26:78a9:c46b:bf48:bd31:d67e:532a:4255
      2016-10-26 18:20:15.439  - [32minfo[39m: host.MacMini-Ethernet.fritz.box States connected to redis 127.0.0.1:6379
      2016-10-26 18:20:15.442  - [32minfo[39m: host.MacMini-Ethernet.fritz.box InRedisDB connected
      2016-10-26 18:20:15.464  - [31merror[39m: uncaught exception: that._clone is not a function
      2016-10-26 18:20:15.468  - [31merror[39m: TypeError: that._clone is not a function
          at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:1135:36
          at Command.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:602:49)
          at normal_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:714:21)
          at RedisClient.return_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:816:9)
          at JavascriptRedisParser.Parser.returnReply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:188:18)
          at JavascriptRedisParser.execute (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/node_modules/redis-parser/lib/parser.js:415:12)
          at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:267:27)
          at emitOne (events.js:77:13)
          at Socket.emit (events.js:169:7)
          at readableAddChunk (_stream_readable.js:153:18)
      2016-10-26 18:20:15.471  - [32minfo[39m: iobroker _restart
      2016-10-26 18:20:15.487  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
      2016-10-26 18:20:15.672  - [32minfo[39m: iobroker Starting node restart.js
      2016-10-26 18:20:15.683  - [32minfo[39m: iobroker exit 0
      2016-10-26 18:20:15.792  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
      2016-10-26 18:20:15.793  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
      2016-10-26 18:20:21.431  - [32minfo[39m: host.MacMini-Ethernet.fritz.box iobroker.js-controller version 0.12.3 js-controller starting
      2016-10-26 18:20:21.439  - [32minfo[39m: host.MacMini-Ethernet.fritz.box Copyright (c) 2014-2016 bluefox, hobbyquaker
      2016-10-26 18:20:21.440  - [32minfo[39m: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
      2016-10-26 18:20:21.441  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ip addresses: fe80::ca2a:14ff:fe58:bcd 192.168.178.38 fe80::bd31:d67e:532a:4255 fd26:78a9:c46b:bf48:bd31:d67e:532a:4255
      2016-10-26 18:20:21.478  - [32minfo[39m: host.MacMini-Ethernet.fritz.box States connected to redis 127.0.0.1:6379
      2016-10-26 18:20:21.480  - [32minfo[39m: host.MacMini-Ethernet.fritz.box InRedisDB connected
      2016-10-26 18:20:21.501  - [31merror[39m: uncaught exception: that._clone is not a function
      2016-10-26 18:20:21.505  - [31merror[39m: TypeError: that._clone is not a function
      2016-10-26 18:20:21.507  - [32minfo[39m: iobroker _restart
      2016-10-26 18:20:21.519  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated</anonymous></anonymous>
      Irgendwas stimmt mit redis wohl nicht. Redis Server läuft aber.
      ./iobroker setup custom
      ````auch schon ausgeführt und alles auf redis umgestellt. Kein Erfolg
      Ebenso führ der controller ein "restart" aus. Damit startet eine Schleife aus Start und Absturz, die ich mit````
      ./iobroker stop
      ````nicht beenden kann.
      Jemand ne Idee?
      Pix
        Hat es dir beim Crash ein Script zerschossen?
        @pix:
        at readableAddChunk (_stream_readable.js:153:18)</anonymous> `
        Vielleicht hilft es in den Sekunden, die ioBroker hoch ist mal den Js-Adapter zu stoppen.
          @pix:
          ./iobroker stop
          Jemand ne Idee?
          Pix `
          Es ist nicht klar, wie es früher lief. Probiere die aktuellste 0.13.0 Version.
            pix last edited by
            So, nach Tagen das Ding immer noch nicht wieder zum Laufen gekriegt :evil:
            Server platt gemacht und komplett neu installiert, inklusive node, npm, iobroker.
            Dann iobroker-data Ordner zurückkopiert.
            Fehler wie oben.
            Dann JS-Controller 0.13 installiert, dann kommt````
            MacMini-Ethernet:iobroker pix$ ./iobroker start
            Starting iobroker controller daemon...
            iobroker controller daemon failed to start: 2
            Error: 2
            Tipps?
            Pix
              pix last edited by
              Okay, habe mein Timemachine Backup des iobroker Ordners vom letzten Sonntag! (5 Tage) wieder eingespielt.
              Alles fährt wieder hoch 😛 , leider sind aber alle States weg 😢
              Manche sind wichtig für die Funktion von Skripts. Leider lassen sie sich nicht einfach per wiederherstellen. Weiß da jemand Rat?
                pix last edited by
                Habe die States von Hand wieder mit Werten gefüllt. War natürlich etwas Arbeit. 😢
                Gibt es ein Skript, dass alle States durchgeht, ob sie "undefined" sind und dann in InfluxDB nachsieht, ob es einen Wert gibt und diesen schließlich in den State schreibt?
                Pix
