Gelöst: SMARTGARDEN Adapter: Adapter bleibt gelb
Hallo bislang lieg der Adapter hervor ragend.
Seit ein paar Tagen bleibt der Adapter GELB. Folgendes finde ich im LOG:smartgarden.0 2020-09-15 20:18:54.158 info (12520) 3/ ---> State change by device smartgarden.0 2020-09-15 20:18:54.157 info (12520) 3/ state smartgarden.0.info.connection changed: false (ack = true) smartgarden.0 2020-09-15 20:18:54.151 error (12520) Error: getlocations: no data smartgarden.0 2020-09-15 20:18:53.557 info (12520) 3/ ---> State change by device smartgarden.0 2020-09-15 20:18:53.557 info (12520) 3/ state smartgarden.0.info.connection changed: true (ack = true) smartgarden.0 2020-09-15 20:18:53.556 info (12520) 3/ ---> State change by device smartgarden.0 2020-09-15 20:18:53.556 info (12520) 3/ state smartgarden.0.info.connection changed: true (ack = true) smartgarden.0 2020-09-15 20:18:53.549 info (12520) 3/ get_locations ... smartgarden.0 2020-09-15 20:18:53.548 info (12520) 3/ connected ... auth_data=eyJhXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX.XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX smartgarden.0 2020-09-15 20:18:53.547 info (12520) 3/ sgSetState: info.connection value=true ack=true smartgarden.0 2020-09-15 20:18:53.546 info (12520) 3/ Connection: successful: response.statusCode / statusMessage=200 / OK smartgarden.0 2020-09-15 20:18:53.198 info (12520) 3/ ---> Command should be sent to device smartgarden.0 2020-09-15 20:18:53.198 info (12520) 3/ state smartgarden.0.testVariable changed: true (ack = false) smartgarden.0 2020-09-15 20:18:53.198 info (12520) 3/ ---> State change by device smartgarden.0 2020-09-15 20:18:53.197 info (12520) 3/ state smartgarden.0.info.revision changed: Main: 2160 / API: 2250 (ack = true) smartgarden.0 2020-09-15 20:18:53.197 info (12520) 3/ ---> State change by device smartgarden.0 2020-09-15 20:18:53.197 info (12520) 3/ state smartgarden.0.info.connection changed: false (ack = true) smartgarden.0 2020-09-15 20:18:53.174 info (12520) 3/ Gardena Smart System Service hosts at: smart_host: https://api.smart.gardena.dev authentication_host: https://api.authentication.husqvarnagroup.dev smartgarden.0 2020-09-15 20:18:53.173 info (12520) 3/ sgSetState: info.revision value=Main: 2160 / API: 2250 ack=true smartgarden.0 2020-09-15 20:18:53.164 info (12520) starting. Version 1.0.2 in C:/iobroker/SmartHome/node_modules/iobroker.smartgarden, node: v12.18.3, js-controller: 3.1.6Habe die Version 1.02 installiert.
Was kann ich tun?
MichaelEDIT: Ein neuer API Schlüssel hat geholfen
