    2. English
    3. Visualization
    4. Vis displays deleted objects
    • kadircanaksoy
      kadircanaksoy last edited by
      Hi everyone!
      I'm building a VIS page for an adapter I am developing. However, I've just realized something while binding a widget to an object in the system. I can see some of the objects I've deleted from my database in the selector. Example below:
      Objects in my database, just two modules and nothing else:
      Objects that I can select in Vis, lots of artifacts from a bug I had a while ago!
      Does this mean ioBroker keeps a copy of the objects I delete? If not, how can VIS have access to them?
      Thanks a bunch in advance for the responses!
        Wildbill @kadircanaksoy last edited by
        @kadircanaksoy
        Just restart the VIS-adapter and it should read newer objects and forget those you have deleted.
        Greetings, Jürgen
        kadircanaksoy 1 Reply Last reply Reply Quote 0
        • kadircanaksoy
          kadircanaksoy @Wildbill last edited by
          @Wildbill Hi Jürgen!
          Thanks for the reply, but unfortunately restarting didn't really help, the objects are still visible
            @kadircanaksoy
            Sorry, if a restart of VIS-adapter doesn't help, there seems to be a problem within the json-file, i which iobroker stores all the objects. But strange, that you only see them in the VIS-adapter and not in the real objects.
            Reboot of hole iobroker didn't help also? Then, I'm sorry, I have no more idea how I could help you.
            Greetings, Jürgen
            • kadircanaksoy
              @Wildbill
              Yep, iobroker reboot doesn't do it either 😕 Thanks a lot for the effort though!
              Cheers
                Homoran Global Moderator Administrators @kadircanaksoy last edited by
                @kadircanaksoy did you try to clear the browser's cache?
                (CTRL-F5)
                own project vis
